3127|0
2014
【DSP】TMS320F28035 ADC例程(ePWM+中断) [复制链接]
#include "DSP28x_Project.h"
interrupt void adc_isr(void);
Uint16 ConversionCount;
Uint16 Voltage1[10];
Uint16 Voltage2[10];
main()
   InitSysCtrl();
   DINT;
   InitPieCtrl();
   IER = 0x0000;
   IFR = 0x0000;
   InitPieVectTable();
   EALLOW;
   PieVectTable.ADCINT1 = &adc_isr; //映射ADC中断
   EDIS;
   InitAdc();
   PieCtrlRegs.PIEIER1.bit.INTx1 = 1;   //使能PIE级INT1.1中断
   IER |= M_INT1;                       //使能CPU级INT1中断
   EINT;                                //使能总中断
   ConversionCount = 0;
    EALLOW;
    AdcRegs.ADCCTL1.bit.INTPULSEPOS = 1;    //转换完成前一个ADC时钟周期产生EOC
    AdcRegs.INTSEL1N2.bit.INT1E     = 1;    //使能ADCINT1
    AdcRegs.INTSEL1N2.bit.INT1CONT  = 0;    //关闭连续模式
    AdcRegs.INTSEL1N2.bit.INT1SEL   = 1;    //将ADCINT1映射到EOC1
    AdcRegs.ADCSOC0CTL.bit.CHSEL    = 0;    //将ADCINA0映射到通道0
    AdcRegs.ADCSOC1CTL.bit.CHSEL    = 1;    //将ADCINA1映射到通道1
    AdcRegs.ADCSOC0CTL.bit.TRIGSEL  = 5;    //ePWM1A触发SOC0
    AdcRegs.ADCSOC1CTL.bit.TRIGSEL  = 5;    //ePWM1A触发SOC1
    AdcRegs.ADCSOC0CTL.bit.ACQPS    = 6;    //设置窗口采样次数
    AdcRegs.ADCSOC1CTL.bit.ACQPS    = 6;    //设置窗口采样次数
    EDIS;
    //还没开始研究ePWM
   EPwm1Regs.ETSEL.bit.SOCAEN   = 1;        // Enable SOC on A group
   EPwm1Regs.ETSEL.bit.SOCASEL  = 4;        // Select SOC from from CPMA on upcount
   EPwm1Regs.ETPS.bit.SOCAPRD   = 1;        // Generate pulse on 1st event
   EPwm1Regs.CMPA.half.CMPA     = 0x0080;   // Set compare A value
   EPwm1Regs.TBPRD              = 0xFFFF;   // Set period for ePWM1
   EPwm1Regs.TBCTL.bit.CTRMODE  = 0;        // count up and start
   for(;;)
  Voltage1[ConversionCount] = AdcResult.ADCRESULT0;
  Voltage2[ConversionCount] = AdcResult.ADCRESULT1;
  if(ConversionCount == 9)
  else ConversionCount++;
  AdcRegs.ADCINTFLGCLR.bit.ADCINT1 = 1;     //清除EOC1信号(ADCINT1)
  PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;   //写1清0,写0无效
【直播时间】5月28日(周三)上午10:00
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
