DH22在STC15F2K60S2单片机下只显示湿度,温度却没有
温度:0湿度:768
温度:0湿度:768
温度:0湿度:768
是这个样子,温度显示为零,湿度正常显示
#include
#include
#define dht22_io P20
#define MAIN_Fosc 12000000L
#define baud_rate 115200L
#define Timer1_Reload (65536UL -(MAIN_Fosc / 4 / baud_rate))
u8 U8FLAG;
u8 U8temp;
u8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
u8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
u8 U8comdata;
u8 datas=0;
u8 data1=0;
u8 DATAQ[100];
u8 DATA[100];
void Delay30us();
void Delay40us();
void Delay18ms();
void Delay1000ms();
void Delay1ms();
void read_byte();
u8 read_temp();
u8 read_humi();
void serial_init();
void serial_send_byte(u8 dat);
void serial_send_string(u8 *dat);
void main()
Delay1000ms();
serial_init();
dht22_io = 1;
while(1)
data1=read_temp();
sprintf(DATA,"温度:%d",data1);
serial_send_string((u8 *)DATA);
datas=read_humi();
sprintf(DATAQ,"湿度:%d",datas);
serial_send_string((u8 *)DATAQ);
serial_send_string("\r\n");
Delay1000ms();
void read_byte()
u8 i;
for(i=0;i<8;i++)
U8FLAG=2;
while((!dht22_io)&&U8FLAG++);
Delay30us();
U8temp=0;
if(dht22_io)U8temp=1;
U8FLAG=2;
while((dht22_io)&&U8FLAG++);
if(U8FLAG==1)break;
U8comdata<<=1;
U8comdata|=U8temp;
u8 read_temp()
dht22_io=0;
Delay1ms();
dht22_io=1;
Delay40us();
dht22_io=1;
if(!dht22_io)
U8FLAG=2;
U8FLAG=2;
read_byte();
U8RH_data_H_temp=U8comdata;
read_byte();
U8RH_data_L_temp=U8comdata;
read_byte();
U8T_data_H_temp=U8comdata;
read_byte();
U8T_data_L_temp=U8comdata;
read_byte();
U8checkdata_temp=U8comdata;
dht22_io=1;
U8temp=(U8RH_data_H_temp+U8RH_data_L_temp+U8T_data_H_temp+U8T_data_L_temp);
if(U8temp==U8checkdata_temp)
U8RH_data_H=U8RH_data_H_temp;
U8RH_data_L=U8RH_data_L_temp;
U8T_data_H=U8T_data_H_temp;
U8T_data_L=U8T_data_L_temp;
U8checkdata=U8checkdata_temp;
return U8T_data_H;
u8 read_humi()
dht22_io=0;
Delay1ms();
dht22_io=1;
Delay40us();
dht22_io=1;
if(!dht22_io)
U8FLAG=2;
U8FLAG=2;
read_byte();
read_byte();
read_byte();
read_byte();
read_byte();
dht22_io=1;
return U8RH_data_H;
void serial_init()
SCON = 0x50; //8位数据,可变波特率
AUXR |= 0x40; //定时器1时钟为Fosc,即1T
AUXR &= 0xFE; //串口1选择定时器1为波特率发生器
TMOD &= 0x0F; //设定定时器1为16位自动重装方式
TL1 = 0xE6; //设定定时初值
TH1 = 0xFF; //设定定时初值
ET1 = 0; //禁止定时器1中断
TR1 = 1;
SBUF=dat;
while(!TI);
TI=0;
while(*dat)
serial_send_byte(*dat++);
void UART1_int (void) interrupt UART1_VECTOR
if(RI)
RI = 0;
if(TI)
void Delay30us() //@12.000MHz
unsigned char i;
_nop_();
_nop_();
i = 87;
while (--i);
void Delay40us() //@12.000MHz
unsigned char i;
_nop_();
_nop_();
i = 117;
while (--i);
void Delay18ms() //@12.000MHz
unsigned char i, j, k;
_nop_();
_nop_();
i = 1;
j = 211;
k = 24;
do
do
while (--k);
} while (--j);
} while (--i);
void Delay1000ms() //@12.000MHz
_nop_();
_nop_();
i = 46;
j = 153;
k = 245;
do
do
while (--k);
} while (--j);
} while (--i);
void Delay1ms() //@12.000MHz
unsigned char i, j;
i = 12;
j = 169;
do
while (--j);
} while (--i);
