2067|0
3836
c6000 DSP 锁相环(PLL)编程范例 [复制链接]
C6000 DSP 锁相环(PLL)编程范例
  1. /* Initialize PLL Registers */
  2.   /* Put PLL in bypass */
  3. PLL_bypass();
  4. PLLdelay(20);
  5.   /* Reset PLL */
  6. PLL_reset();
  7. PLLdelay(20);
  8.   /* Set main multiplier/divisor */
  9.     PLL_RSET(PLLM,18);      //25MHz×18=450MHz
  10.     PLL_RSET(PLLDIV0,PLL_PLLDIV0_RMK(1,0));  //450MHz/1=450MHz
  11.     PLL_RSET(OSCDIV1,PLL_OSCDIV1_RMK(1,0));  //25MHz/1=25MHz(CLKOUT3)
  12.      /* Set DSP clock */
  13.     PLL_RSET(PLLDIV1,PLL_PLLDIV1_RMK(1,1));  //450MHz/2=225MHz
  14.     PLLdelay(20);
  15.      /* Set peripheral clock */
  16.     PLL_RSET(PLLDIV2,PLL_PLLDIV2_RMK(1,3));  //450MHz/4=112.5MHz(CLKOUT2)
  17.     PLLdelay(20);
  18.      /* Set EMIF clock */
  19.     PLL_RSET(PLLDIV3,PLL_PLLDIV3_RMK(1,4));  //450MHz/5=90MHz(ECLKOUT)
  20.     PLLdelay(20);
  21.      /* Take PLL out of reset */
  22.     PLL_deassert();
  23.     PLLdelay(1500);
  24.      /* Enalbe PLL */
  25.     PLL_enable();
  26.     PLLdelay(20);
复制代码
