1522|0
3836
MSP430占空比可变的PWM波程序 [复制链接]
MSP430占空比可变的PWM波程序
//  Description: 设定一个变量来选择初始占空比,然后通过Timer_B定时1s,每隔一秒
//  改变一次占空比,生成占空比可变的PWM波。
//  ACLK= TACLK = 32768Hz, MCLK= SMCLK= default DCO ~ 800kHz
//  Daquan. Liu
//  China University of Geosciences(Wuhan)
//  2010.12.27
//  Built with IAR Embedded Workbench Version: V3.42A
#include
unsigned char v=5;
void  Init_TIMER_B();
void main(void)
  WDTCTL = WDTPW + WDTHOLD; // Stop WDT
   P1DIR |= 0x0C; // P1.2 and P1.3 output
   P1SEL |= 0x0C; // P1.2 and P1.3 TA1/2 options
   Init_TIMER_B();
   TACTL = TASSEL_2 + TACLR; // SMCLK, up mode
   CCR0 = 512-1; // PWM Period
   CCTL1 = OUTMOD_7 ; // CCR1 reset/set
   CCTL2 = OUTMOD_7 ; //CCR2 reset/set
   if(v==5)
     CCR1 = 128; // CCR1 PWM duty cycle
     CCR2 = 384; // CCR2 PWM duty cycle
   else if (v==12)
     CCR1 = 384; // CCR1 PWM duty cycle
     CCR2 = 128; // CCR2 PWM duty cycle
   else
   TACTL |= MC_1;      // Start Timer_A in up mode
   TBCTL |= MC_1;      // Start Timer_B in up mode
   _EINT();         //开全局中断
   _BIS_SR(LPM0_bits); // Enter LPM0
void  Init_TIMER_B()
    TBCTL |= TBSSEL0 +TBCLR; //ACLK
    TBCCTL0 = CCIE;
    TBCCR0 =32768;  //定时1s
// Timer B0 interrupt service routine
#pragma vector=TIMERB0_VECTOR
__interrupt void Timer_B (void)
if(CCR1 >511)
   CCR1 = 64;
else CCR1 += 32;      // 调整占空比
if(CCR2 < 10)
   CCR2 = 448;
else  CCR2 -= 32;
//此程序不能用定时器A中断定时
