1211|0
3836
TI的MSP430单片机官网实例问题 [复制链接]
在官网上看到的实例,是MSP430G2553的,程序如下:
//   MSP430G2xx3 Demo - USCI_A0, 115200 UART Echo ISR, DCO SMCLK
//   Description: Echo a received character, RX ISR used. Normal mode is LPM0.
//   USCI_A0 RX interrupt triggers TX Echo.
//   Baud rate divider with 1MHz = 1MHz/115200 = ~8.7
//   ACLK = n/a, MCLK = SMCLK = CALxxx_1MHZ = 1MHz
//                MSP430G2xx3
//         /|\|              XIN|-
//          --|RST          XOUT|-
//            |     P1.2/UCA0TXD|------------>
//            |                 | 115200 - 8N1
//            |     P1.1/UCA0RXD|<------------
//   D. Dang
//   Texas Instruments Inc.
//   February 2011
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include
int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  if (CALBC1_1MHZ==0xFF)        // If calibration constant erased
    while(1);                               // do not load, trap CPU!!
  DCOCTL = 0;                               // Select lowest DCOx and MODx settings
  BCSCTL1 = CALBC1_1MHZ;                    // Set DCO
  DCOCTL = CALDCO_1MHZ;
  P1SEL = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P1SEL2 = BIT1 + BIT2;
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 = 8;                              // 1MHz 115200
  UCA0BR1 = 0;                              // 1MHz 115200
  UCA0MCTL = UCBRS2 + UCBRS0;               // Modulation UCBRSx = 5
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM0_bits + GIE);       // Enter LPM0, interrupts enabled
// Echo back RXed character, confirm TX buffer is ready first
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  while (!(IFG2&UCA0TXIFG));                // USCI_A0 TX buffer ready?
  UCA0TXBUF = UCA0RXBUF;                    // TX -> RXed character
