1407|0
3836
FFT的DSP实现 [复制链接]
使用C语言实现的FFT及IFFT算法实例,能计算任意以2为对数底的采样点数的FFT,算法参考上面给的流程图。
[cpp] view plain copy
print?
  • * zx_fft.h
  • *  Created on: 2013-8-5
  • *      Author: monkeyzx
  • #ifndef ZX_FFT_H_
  • #define ZX_FFT_H_
  • typedef float          FFT_TYPE;
  • #ifndef PI
  • #define PI             (3.14159265f)
  • #endif
  • typedef struct complex_st {
  •     FFT_TYPE real;
  •     FFT_TYPE img;
  • } complex;
  • int fft(complex *x, int N);
  • int ifft(complex *x, int N);
  • void zx_fft(void);
  • #endif /* ZX_FFT_H_ */
print?
  • * zx_fft.c
  • * Implementation of Fast Fourier Transform(FFT)
  • * and reversal Fast Fourier Transform(IFFT)
  • #include "zx_fft.h"
  • #include
  • #include
  • * Bit Reverse
  • * === Input ===
  • * x : complex numbers
  • * n : nodes of FFT. @N should be power of 2, that is 2^(*)
  • * l : count by bit of binary format, @l=CEIL{log2(n)}
  • * === Output ===
  • * r : results after reversed.
  • * Note: I use a local variable @temp that result @r can be set
  • * to @x and won't overlap.
  • static void BitReverse(complex *x, complex *r, int n, int l)
  •     int i = 0;
  •     int j = 0;
  •     short stk = 0;
  •     static complex *temp = 0;
  •     temp = (complex *)malloc(sizeof(complex) * n);
  •     if (!temp) {
  •         return;
  •     for(i=0; i
  •         stk = 0;
  •         j = 0;
  •         do {
  •             stk |= (i>>(j++)) & 0x01;
  •             if(j
  •                 stk <<= 1;
  •         }while(j
  •         if(stk < n) {             /* 满足倒位序输出 */
  •             temp[stk] = x;
  •     /* copy @temp to @r */
  •     for (i=0; i
  •         r = temp;
  •     free(temp);
  • * FFT Algorithm
  • * === Inputs ===
  • * N : nodes of FFT. @N should be power of 2, that is 2^(*)
  • * === Output ===
  • * the @x contains the result of FFT algorithm, so the original data
  • * in @x is destroyed, please store them before using FFT.
  •     int i,j,l,ip;
  •     static int M = 0;
  •     static int le,le2;
  •     static FFT_TYPE sR,sI,tR,tI,uR,uI;
  •     M = (int)(log(N) / log(2));
  •      * bit reversal sorting
  •     BitReverse(x,x,N,M);
  •      * For Loops
  •     for (l=1; l<=M; l++) {   /* loop for ceil{log2(N)} */
  •         le = (int)pow(2,l);
  •         le2 = (int)(le / 2);
  •         uR = 1;
  •         uI = 0;
  •         sR = cos(PI / le2);
  •         sI = -sin(PI / le2);
  •         for (j=1; j<=le2; j++) {   /* loop for each sub DFT */
  •             //jm1 = j - 1;
  •             for (i=j-1; i<=N-1; i+=le) {  /* loop for each butterfly */
  •                 ip = i + le2;
  •                 tR = x[ip].real * uR - x[ip].img * uI;
  •                 tI = x[ip].real * uI + x[ip].img * uR;
  •                 x[ip].real = x.real - tR;
  •                 x[ip].img = x.img - tI;
  •                 x.real += tR;
  •                 x.img += tI;
  •             }  /* Next i */
  •             tR = uR;
  •             uR = tR * sR - uI * sI;
  •             uI = tR * sI + uI *sR;
  •         } /* Next j */
  •     } /* Next l */
  •     return 0;
  • * Inverse FFT Algorithm
  • * === Inputs ===
  • * === Output ===
  •     int k = 0;
  •     for (k=0; k<=N-1; k++) {
  •         x[k].img = -x[k].img;
  •     fft(x, N);    /* using FFT */
  •         x[k].real = x[k].real / N;
  •         x[k].img = -x[k].img / N;
  •     return 0;
  • * Code below is an example of using FFT and IFFT.
  • #define  SAMPLE_NODES              (128)
  • complex x[SAMPLE_NODES];
  • int INPUT[SAMPLE_NODES];
  • int OUTPUT[SAMPLE_NODES];
  • static void MakeInput()
  •     int i;
  •     for ( i=0;i
  •         x.real = sin(PI*2*i/SAMPLE_NODES);
  •         x.img = 0.0f;
  •         INPUT=sin(PI*2*i/SAMPLE_NODES)*1024;
  • static void MakeOutput()
  •     int i;
  •     for ( i=0;i
  •         OUTPUT = sqrt(x.real*x.real + x.img*x.img)*1024;
  • void zx_fft(void)
  •     MakeInput();
  •     fft(x,128);
  •     MakeOutput();
  •     ifft(x,128);
  •     MakeOutput();
