1895|3
33
vhdl编译错误 [复制链接]
LIBRARY ieee;
   USE ieee.std_logic_1164.all;
   USE ieee.std_logic_unsigned.all;
ENTITY fdiv2 IS
   PORT (
      CLK   : IN STD_LOGIC;
      PM    : OUT STD_LOGIC;
      D     : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
      DOUT  : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
      RST   : IN STD_LOGIC
END fdiv2;
ARCHITECTURE trans OF fdiv2 IS
   SIGNAL Q1   : STD_LOGIC_VECTOR(3 DOWNTO 0);
   SIGNAL FULL : STD_LOGIC;
   SIGNAL LD   : STD_LOGIC;
BEGIN
   PROCESS (CLK, LD, RST)
   BEGIN
      IF ((NOT(RST)) = '1') THEN
         Q1 <= "0000";
         FULL <= '0';
      ELSIF (LD = '1') THEN
         Q1 <= D;
         FULL <= '1';
      ELSIF (CLK'EVENT AND CLK = '1') THEN
         Q1 <= Q1 + "0001";
         FULL <= '0';
      END IF;
   END PROCESS;
   LD <= to_stdlogic((Q1 = "0001"));
   PM <= FULL;
   DOUT <= Q1;
END trans;
此帖出自FPGA/CPLD论坛
33
占楼
此帖出自FPGA/CPLD论坛
33
别沉啊
此帖出自FPGA/CPLD论坛
33
LD <= to_stdlogic((Q1 = "0001"));提示to_stdlogic 没有定义
此帖出自FPGA/CPLD论坛
【直播时间】5月28日(周三)上午10:00
