2667|4
2625
STM32L4用串口2给PC 发送hello word [复制链接]
  1. #include "stm32l4xx_hal.h"
  2. #include "periph.h"
  3. UART_HandleTypeDef UartHandle;
  4. int main()
  5. {
  6.         char ch[]="hello word";
  7.         HAL_Init();
  8.         SystemClock_Config();
  9.   __HAL_RCC_USART2_CLK_ENABLE();
  10.         Gpio_Inits();
  11.         UartHandle.Instance        = USART2;
  12.   UartHandle.Init.BaudRate   = 9600;
  13.   UartHandle.Init.WordLength = UART_WORDLENGTH_8B;
  14.   UartHandle.Init.StopBits   = UART_STOPBITS_1;
  15.   UartHandle.Init.Parity     = UART_PARITY_NONE;
  16.   UartHandle.Init.HwFlowCtl  = UART_HWCONTROL_NONE;
  17.   UartHandle.Init.Mode       = UART_MODE_TX_RX;
  18.         HAL_UART_DeInit(&UartHandle);
  19.         HAL_UART_Init(&UartHandle);
  20.         HAL_UART_Transmit(&UartHandle, (uint8_t *)&ch, 10, 0xFFFF);
  21.         while(1)
  22.         {
  23.
  24.                  HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_5);
  25.                 HAL_Delay(500);
  26.         }
  27. }
复制代码
此内容由EEWORLD论坛网友xutong原创,如需转载或用于商业用途需征得作者同意并注明出处
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
2625
晚上有点晚了明天在完善下
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
2625
  1. #include "periph.h"
  2. void Gpio_Inits(void)
  3. {
  4.         GPIO_InitTypeDef  GPIO_InitStruct;
  5.         __HAL_RCC_GPIOA_CLK_ENABLE();
  6.         __HAL_RCC_GPIOC_CLK_ENABLE();
  7.         GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
  8.   GPIO_InitStruct.Pull  = GPIO_PULLUP;
  9.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  10.   GPIO_InitStruct.Pin = GPIO_PIN_5 ;
  11.   HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  12.
  13.         GPIO_InitStruct.Mode =GPIO_MODE_IT_RISING; //设置为上升沿中断触发
  14.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  15.   GPIO_InitStruct.Pin = GPIO_PIN_13;
  16.         HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  17.
  18.         //串口2引脚功能配置
  19.         GPIO_InitStruct.Mode=GPIO_MODE_AF_PP;
  20.         GPIO_InitStruct.Pin=GPIO_PIN_2;
  21.   GPIO_InitStruct.Speed=GPIO_SPEED_FAST;
  22.         GPIO_InitStruct.Alternate=GPIO_AF7_USART1;
  23.         GPIO_InitStruct.Pull=GPIO_PULLUP;
  24.         HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  25.         GPIO_InitStruct.Pin=GPIO_PIN_3;
  26.         HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  27. //串口2引脚功能配置
  28.
  29.          /* Enable and set EXTI lines 10 to 15 Interrupt to the lowest priority */
  30.   HAL_NVIC_SetPriority(EXTI15_10_IRQn, 2, 0);  //设置外部中断15——10优先级
  31.   HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);           //使能外部中断
  32. }
  33. void SystemClock_Config(void)
  34. {
  35.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  36.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  37.   /* MSI is enabled after System reset, activate PLL with MSI as source */
  38.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  39.   RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  40.   RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
  41.   RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
  42.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  43.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
  44.   RCC_OscInitStruct.PLL.PLLM = 1;
  45.   RCC_OscInitStruct.PLL.PLLN = 40;
  46.   RCC_OscInitStruct.PLL.PLLR = 2;
  47.   RCC_OscInitStruct.PLL.PLLP = 7;
  48.   RCC_OscInitStruct.PLL.PLLQ = 4;
  49.   if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  50.   {
  51.     /* Initialization Error */
  52.     while(1);
  53.   }
  54.
  55.   /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
  56.      clocks dividers */
  57.   RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  58.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  59.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  60.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  61.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  62.   if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
  63.   {
  64.     /* Initialization Error */
  65.     while(1);
  66.   }
  67. }
复制代码
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
2625
主要是串口2引脚功能配置,其他是之前几个程序的可以不用管他
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
2625
  3. #include "stdio.h"
  4. UART_HandleTypeDef UartHandle;
  5. int main()
  6. {
  7.         char ch[]="hello word\n";
  8.         HAL_Init();
  9.         SystemClock_Config();
  10.   __HAL_RCC_USART2_CLK_ENABLE();
  11.         Gpio_Inits();
  12.         UartHandle.Instance        = USART2;
  13.   UartHandle.Init.BaudRate   = 9600;
  14.   UartHandle.Init.WordLength = UART_WORDLENGTH_8B;
  15.   UartHandle.Init.StopBits   = UART_STOPBITS_1;
  16.   UartHandle.Init.Parity     = UART_PARITY_NONE;
  17.   UartHandle.Init.HwFlowCtl  = UART_HWCONTROL_NONE;
  18.   UartHandle.Init.Mode       = UART_MODE_TX_RX;
  19.         HAL_UART_DeInit(&UartHandle);
  20.         HAL_UART_Init(&UartHandle);
  21.         HAL_UART_Transmit(&UartHandle, (uint8_t *)&ch, 12, 0xFFFF);
  22.         printf("hello word");
  23.         while(1)
  24.         {
  25.
  26.                  HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_5);
  27.                 HAL_Delay(500);
  28.         }
  29. }
复制代码
加入了换行,按一下复位按键发送一次hello word
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
