3653|1
STM8S003F3P6串口无法进入接收中断,定时器中断是可以进入的。 [复制链接]
2芯积分
恳请大家半个忙,解决这个问题,困扰我一段时间了!
一、串口配置如下:
void Uart1Init()
                UART1_CR2=0x00;//使发送禁用TEN=0;
                UART1_CR1=0x00;//设置M字长,8位数据位
                UART1_CR3=0x00;//1位停止位
                UART1_BRR2=0x02;
                UART1_BRR1=0x68;
                UART1_CR2|=0x2C;//0x08  0x2c
二、中断服务函数
@far @interrupt void UART1RECE_Intterupt(void)
        RxBuffer=UART1_DR;//Store the received byte in RxBuffe
        if(RxBuffer==0x45)
                        //PC_ODR&=0xdf;
                        UartCompleteFlag=1;
                        //UartGetdata=0x37;
        if(RxBuffer==0x46)
                        UartCompleteFlag=0;
                        //PC_ODR|=0x20;
                        //UartGetdata=0x82;
        //UartGetdata=0x95;
        return;
三、中断向量号
struct interrupt_vector const _vectab[] =
        {0x82, (interrupt_handler_t)_stext}, /* reset */
        {0x82, NonHandledInterrupt}, /* trap  */
        {0x82, NonHandledInterrupt}, /* irq0  */
        {0x82, NonHandledInterrupt}, /* irq1  */
        {0x82, NonHandledInterrupt}, /* irq2  */
        {0x82, NonHandledInterrupt}, /* irq3  */
        {0x82, NonHandledInterrupt}, /* irq4  */
        {0x82, NonHandledInterrupt}, /* irq5  */
        {0x82, NonHandledInterrupt}, /* irq6  */
        {0x82, NonHandledInterrupt}, /* irq7  */
        {0x82, NonHandledInterrupt}, /* irq8  */
        {0x82, NonHandledInterrupt}, /* irq9  */
        {0x82, NonHandledInterrupt}, /* irq10 */
        {0x82, TIM1_Intterupt}, /* irq11 */
        {0x82, NonHandledInterrupt}, /* irq12 */
        {0x82, NonHandledInterrupt}, /* irq13 */
        {0x82, NonHandledInterrupt}, /* irq14 */
        {0x82, NonHandledInterrupt}, /* irq15 */
        {0x82, NonHandledInterrupt}, /* irq16 */
        {0x82, NonHandledInterrupt}, /* irq17 */
        {0x82, UART1RECE_Intterupt}, /* irq18 */
        {0x82, NonHandledInterrupt}, /* irq19 */
        {0x82, NonHandledInterrupt}, /* irq20 */
        {0x82, NonHandledInterrupt}, /* irq21 */
        {0x82, NonHandledInterrupt}, /* irq22 //ADC_Intterupt},*/
        {0x82, TIM4_Intterupt}, /* irq23 //TIM4_Intterupt},*/
        {0x82, NonHandledInterrupt}, /* irq24 */
        {0x82, NonHandledInterrupt}, /* irq25 */
        {0x82, NonHandledInterrupt}, /* irq26 */
        {0x82, NonHandledInterrupt}, /* irq27 */
        {0x82, NonHandledInterrupt}, /* irq28 */
        {0x82, NonHandledInterrupt}, /* irq29 */
四、时钟配置
void CLK_Init(void)
  CLK_CKDIVR = 0x00;
  //CLK_PCKENR1=0xff;
        //CLK_PCKENR2=0xff;
以上,请大家帮忙,解解,万分感谢!
此帖出自stm32/stm8论坛
高人都潜水了吗!
此帖出自stm32/stm8论坛
