4147|8
2656
STM32L4用按键(外部中断)翻转一个灯 [复制链接]
  1. #include "stm32l4xx_hal.h"
  2. #include "periph.h"
  3. void SystemClock_Config(void);
  4. void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin);
  5. int main()
  6. {
  7.
  8.         HAL_Init();
  9.         SystemClock_Config();
  10.         Gpio_Inits();
  11.         while(1)
  12.         {
  13.         }
  14. }
  15. void EXTI15_10_IRQHandler(void) //外部中断入口
  16. {
  17.   HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_13);
  18. }
  19. void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
  20. {
  21.   if (GPIO_Pin == GPIO_PIN_13)
  22.   {
  23.     HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_5);
  24.   }
  25. }
复制代码
此内容由EEWORLD论坛网友xutong原创,如需转载或用于商业用途需征得作者同意并注明出处
此帖出自stm32/stm8论坛
诶.......... 手机啊手机啊,可见以后搞东西,搞到微信上就算了,反正阿里腾讯双雄天下  详情 回复 发表于 2017-9-12 15:09
希望做一些大家觉得好用的东西!
2656
  1. #include "periph.h"
  2. void Gpio_Inits(void)
  3. {
  4.         GPIO_InitTypeDef  GPIO_InitStruct;
  5.         __HAL_RCC_GPIOA_CLK_ENABLE();
  6.         __HAL_RCC_GPIOC_CLK_ENABLE();
  7.         GPIO_InitStruct.Mode  = GPIO_MODE_OUTPUT_PP;
  8.   GPIO_InitStruct.Pull  = GPIO_PULLUP;
  9.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  10.   GPIO_InitStruct.Pin = GPIO_PIN_5 ;
  11.   HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  12.
  13.         GPIO_InitStruct.Mode =GPIO_MODE_IT_RISING; //设置为上升沿中断触发
  14.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  15.   GPIO_InitStruct.Pin = GPIO_PIN_13;
  16.         HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  17.          /* Enable and set EXTI lines 10 to 15 Interrupt to the lowest priority */
  18.   HAL_NVIC_SetPriority(EXTI15_10_IRQn, 2, 0);  //设置外部中断15——10优先级
  19.   HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);           //使能外部中断
  20. }
  21. void SystemClock_Config(void)
  22. {
  23.   RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  24.   RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  25.   /* MSI is enabled after System reset, activate PLL with MSI as source */
  26.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_MSI;
  27.   RCC_OscInitStruct.MSIState = RCC_MSI_ON;
  28.   RCC_OscInitStruct.MSIClockRange = RCC_MSIRANGE_6;
  29.   RCC_OscInitStruct.MSICalibrationValue = RCC_MSICALIBRATION_DEFAULT;
  30.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  31.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_MSI;
  32.   RCC_OscInitStruct.PLL.PLLM = 1;
  33.   RCC_OscInitStruct.PLL.PLLN = 40;
  34.   RCC_OscInitStruct.PLL.PLLR = 2;
  35.   RCC_OscInitStruct.PLL.PLLP = 7;
  36.   RCC_OscInitStruct.PLL.PLLQ = 4;
  37.   if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  38.   {
  39.     /* Initialization Error */
  40.     while(1);
  41.   }
  42.
  43.   /* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
  44.      clocks dividers */
  45.   RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
  46.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  47.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  48.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  49.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  50.   if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_4) != HAL_OK)
  51.   {
  52.     /* Initialization Error */
  53.     while(1);
  54.   }
  55. }
复制代码
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
2656
  1. #ifndef __PERIPH_H
  2. #define __PERIPH_H
  3. #include "stm32l4xx_hal.h"
  4. void Gpio_Inits(void);
  5. void SystemClock_Config(void);
  6. #endif
复制代码
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
2656
比较常用的写在子程序里面了,这样主程序更加容易读
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
7815
54
裸片初长成(中级)
建议使用 code,这样代码合适看着不乱,尤其手机。
此帖出自stm32/stm8论坛
2656
是用这个<>么?
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
7815
54
裸片初长成(中级)
是哒
此帖出自stm32/stm8论坛
强者为尊,弱者,死无葬身之地
2656
的确是用这个,可能你手机显示得关系
此帖出自stm32/stm8论坛
希望做一些大家觉得好用的东西!
7815
54
裸片初长成(中级)
xutong 发表于 2017-9-12 10:09
的确是用这个,可能你手机显示得关系
诶..........
此帖出自stm32/stm8论坛
强者为尊,弱者,死无葬身之地
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 12
