2646|6
37
谁能解释下为什么这么设置数值吗?谢谢!!!(标红处) [复制链接]
#include "hall.h"
unsigned char FaultF=0;//故障标志
unsigned char Run_dir=1;//运转方向,0-1对立
unsigned char bHallStartStep;
unsigned int OutPwmValue=0;
unsigned char bHallSteps[2][8]={.
{7,5,3,4,1,0,2,7},
{7,2,0,1,4,3,5,7}
const unsigned char PWM_EN1_TAB[6]={0x01,0x01,0x10,0x10,0x00,0x00};
const unsigned char PWM_EN2_TAB[6]={0x0,0x00,0x00,0x0,0x1,0x1};
void Init_TIM2(void)
        //counter disabled, ARR preload register disabled, up counting, edge aligned mode
        TIM2->CR1 = BIT2;
        //disable all interrupts
        TIM2->IER = 0;//禁止中断
        TIM2->CCMR1 = 0x01;//通道配置为输入
        TIM2->CCMR2 = 0x01;
        TIM2->CCMR3 = 0x01;
        #define IC_FILTER (u8)(5 << 4)//0101 0000
        TIM2->CCMR1 |= IC_FILTER; //输入捕获滤波器
        TIM2->CCMR2 |= IC_FILTER;
        TIM2->CCMR3 |= IC_FILTER;
        //prescale = div3 @ 16MHz -> 0.5us/count * 24MHz -> 0.33us/count
        //   8/16MHz=0.5us, 8/24MHz=0.33us
        TIM2->PSCR = 0;
        TIM2->ARRH=0xff;//计数周期设为最大
        TIM2->ARRL=0xff;
        TIM2->CCER1 |= 0x01;//使能捕获功能
        TIM2->CCER1 |= 0x10;
        TIM2->CCER2 |= 0x01;
        TIM2->CR1 |= 0x01;//使能定时器
void TIM2_InitCapturePolarity(void)
                u8 bHStatus = 0;
                GPIOD->DDR &= (u8)(~(0x1c));
        //        GPIOD->CR1|=(u8)(0x1c);
                // Read status of H1 and set the expected polarity
        if (H1_PORT & H1_PIN)
                TIM2->CCER1 |= BIT1;
                bHStatus |= BIT2;
        else
                TIM2->CCER1 &= (u8)(~(BIT1));
        // Read status of H2 and set the expected polarity
        if (H2_PORT & H2_PIN)
                TIM2->CCER1 |= BIT5;
                bHStatus |= BIT1;
        else
                TIM2->CCER1 &= (u8)(~(BIT5));
                // Read status of H3 and set the expected polarity
        if (H3_PORT & H3_PIN)
                        TIM2->CCER2 |= BIT1;
                        bHStatus |= BIT0;
        else
                        TIM2->CCER2 &= (u8)(~(BIT1));
                bHallStartStep = bHallSteps[Run_dir][bHStatus];
                if (bHallStartStep == 7)//不该出现的HALL状态
                        FaultF=1;
                        return;
                TIM2->SR1=(u8)~(TIM2_IT_CC3|TIM2_IT_CC2|TIM2_IT_CC1);
                TIM2->IER = 0x0e;//使能输入捕获中断
                ComHandler();
@near @interrupt @svlreg void TIM2_CAP_COM_IRQHandler(void)
        u8 bHStatus = 0;
                bHStatus |= BIT2;
        else
                bHStatus |= BIT1;
        else
                bHStatus |= BIT0;
        else
        if (TIM2->SR1 & BIT2)
                TIM2->SR1=(u8)(~TIM2_IT_CC2);
        if (TIM2->SR1 & BIT1)
                TIM2->SR1=(u8)(~TIM2_IT_CC1);
        if (TIM2->SR1 & BIT3)
                TIM2->SR1=(u8)(~TIM2_IT_CC3);
                FaultF=1;
        ComHandler();
        return;
void         ComHandler(void)
        TIM1->BKR &= (uint8_t)(~TIM1_BKR_MOE);//禁止PWM输出
        PWM_A_OFF;
        PWM_B_OFF;
        PWM_C_OFF;
        if(FaultF!=0)return;
        if(bHallStartStep==0)//AB
                TIM1->CCR1H = (uint8_t)(OutPwmValue >> 8);
    TIM1->CCR1L = (uint8_t)(OutPwmValue);
                PWM_B_ON;
  else if(bHallStartStep==1)        //AC
          PWM_C_ON;
        else if(bHallStartStep==2)        //BC
                TIM1->CCR2H = (uint8_t)(OutPwmValue >> 8);
    TIM1->CCR2L = (uint8_t)(OutPwmValue);
          PWM_C_ON;
        else if(bHallStartStep==3)        //BA
          PWM_A_ON;
        else if(bHallStartStep==4)//CA
                TIM1->CCR3H = (uint8_t)(OutPwmValue >> 8);
    TIM1->CCR3L = (uint8_t)(OutPwmValue);
          PWM_A_ON;
        else if(bHallStartStep==5)        //CB
          PWM_B_ON;
        TIM1->CCER1=PWM_EN1_TAB[bHallStartStep];
        TIM1->CCER2=PWM_EN2_TAB[bHallStartStep];
        TIM1->BKR|=TIM1_BKR_MOE;//使能PWM输出
此帖出自stm32/stm8论坛
你把这几个数字转成2进制就明白了,估计驱动的步进,需要看datesheet时序,7,5,3,4,1,0,2,7 ,   0x0111,0x0101,0x0011,0x0100,0x0001,0x0000,0x0010,0x0111,  详情 回复 发表于 2017-9-1 22:17
9798
24
在声明时直接初始化 你是指这个吗
此帖出自stm32/stm8论坛
37
littleshrimp 发表于 2017-9-1 12:49
在声明时直接初始化 你是指这个吗
就是标红的地方,那些初始值怎么来的?
此帖出自stm32/stm8论坛
具体还应该看电路图吧 那个数值是霍尔传感器的数据吗? [attachimg]319694[/attachimg]  详情 回复 发表于 2017-9-1 14:58
9798
24
KCP 发表于 2017-9-1 14:40
就是标红的地方,那些初始值怎么来的?
具体还应该看电路图吧
那个数值是霍尔传感器的数据吗?
此帖出自stm32/stm8论坛
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
37
littleshrimp 发表于 2017-9-1 14:58
具体还应该看电路图吧
那个数值是霍尔传感器的数据吗?
是霍尔传感器的
此帖出自stm32/stm8论坛
如果有电路的话,你参照一下电路 如果弄不明白最好把原理图发上来让网友帮你看看  详情 回复 发表于 2017-9-1 15:52
9798
24
KCP 发表于 2017-9-1 15:37
是霍尔传感器的
如果有电路的话,你参照一下电路
此帖出自stm32/stm8论坛
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
2774
此帖出自stm32/stm8论坛
