3805|0
arria10的soc,用quartus16.1能在windows上编译吗,有这个错误是啥原因 [复制链接]
Info (16260): Previously generated files were detected in the Qsys file generation directory ("C:/work/debug/a10_soc_devkit_ghrd_qspi/ghrd_10as066n2/").
Info (16261): Skipped generation of the Qsys file "C:/work/debug/a10_soc_devkit_ghrd_qspi/ghrd_10as066n2.qsys" based on the current IP regeneration policy. You can review your IP regeneration policy in the IP Settings page of the Settings dialog box.
Error (12317): QIP file "C:/work/debug/a10_soc_devkit_ghrd_qspi/ghrd_10as066n2/ghrd_10as066n2.qip" that is being generated from a Qsys file already exists in the project.
Info (12021): Found 1 design units, including 1 entities, in source file ghrd_10as066n2/synth/ghrd_10as066n2.v
Info (12023): Found entity 1: ghrd_10as066n2
Info (12127): Elaborating entity "ghrd_a10_top" for the top level hierarchy
Error (12153): Can't elaborate top-level user hierarchy
Info (144001): Generated suppressed messages file C:/work/debug/a10_soc_devkit_ghrd_qspi/output_files/ghrd_10as066n2.map.smsg
Error: Quartus Prime Analysis & Synthesis was unsuccessful. 2 errors, 2 warnings
Error: Peak virtual memory: 724 megabytes
Error: Processing ended: Thu Aug 17 22:06:56 2017
Error: Elapsed time: 00:01:50
Error: Total CPU time (on all processors): 00:02:04
Error (293001): Quartus Prime Full Compilation was unsuccessful. 4 errors, 2 warnings
看网上有人说可以在windows上编译硬件工程,然后拷贝到linux上去编译uboot,但是怎么windows上编译有这个错误
此帖出自FPGA/CPLD论坛
