用B键或者用pin2做触摸键,发送信号。pin0控制蜂鸣器,pin1控制马达。A键显示或清楚显示。
- # v 1.0 Initial Public Release
- # This is a working CW Radio. 'B' is key. 'A' shows message received in text.
- # Connect Speaker or Headphones to Pin 0 and Ground
- # Or connect Piezo Buzzer or Haptic Motor for Silent operation to pin1 and ground
- # pin2 is capacitive touch keying.
- # Copyright (C) 2017 Revd. John Goodman M0RVJ,
- # This program is free software: you can redistribute it and/or modify
- # it under the terms of the GNU General Public License as published by
- # the Free Software Foundation, either version 3 of the License, or
- # (at your option) any later version.
- # This program is distributed in the hope that it will be useful,
- # but WITHOUT ANY WARRANTY; without even the implied warranty of
- # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- # GNU General Public License for more details.
- # You should have received a copy of the GNU General Public License
- # along with this program. If not, see <[url]http://www.gnu.org/licenses/>L[/url]
- # This uses some public domain code by Giles Booth.
- # See here [url]http://www.suppertime.co.uk/blogmywiki/2016/05/microbit-morse-code-transmitter/[/url]
- from microbit import *
- import radio
- import music
- radio.on()
- radio.reset()
- #Customise these settings for tx, pwr, channel and speed.
- radio.config(power=7)
- radio.config(channel=98)
- WPM = 15
- txenabled = True #in case you want to practice without sending
- sidetone = 550
- dotlength = int( 60000 / ( WPM * 50 ) )
- dashlength = dotlength * 3
- interelement = dotlength
- interletter = dotlength * 2
- interword = dotlength * 7
- DOT_THRESHOLD = dotlength * 2
- DASH_THRESHOLD = dotlength * 5
- WORD_THRESHOLD = dotlength * 7
- DOT = Image("00000:00000:00900:00000:00000")
- DASH = Image("00000:00000:09990:00000:00000")
- ANT = Image("90909:09990:00900:00900:00900")
- morse = {
- "A":".-",
- "B":"-...",
- "C":"-.-.",
- "D":"-..",
- "E":".",
- "F":"..-.",
- "G":"--.",
- "H":"....",
- "I":"..",
- "J":".---",
- "K":"-.-",
- "L":".-..",
- "M":"--",
- "N":"-.",
- "O":"---",
- "P":".--.",
- "Q":"--.-",
- "R":".-.",
- "S":"...",
- "T":"-",
- "U":"..-",
- "V":"...-",
- "W":".--",
- "X":"-..-",
- "Y":"-.--",
- "Z":"--..",
- "0":"-----",
- "1":".----",
- "2":"..---",
- "3":"...--",
- "4":"....-",
- "5":".....",
- "6":"-....",
- "7":"--...",
- "8":"---..",
- "9":"----.",
- # reverse dict.
- decodemorse = {v: k for k, v in morse.items()}
- # convert string to cw
- def EncodeMorse(message):
- m = message.upper()
- enc = ""
- for c in m:
- enc = enc + morse.get(c," ")
- if morse.get(c," ") != " ":
- enc = enc + " "
- return enc
- # function to flash and play cw
- def FlashMorse(pattern):
- for c in pattern:
- if c == ".":
- display.show(DOT)
- pin1.write_digital(1)
- music.pitch(sidetone, dotlength)
- display.clear()
- pin1.write_digital(0)
- sleep(interelement)
- elif c == "-":
- display.show(DASH)
- music.pitch(sidetone, dashlength)
- display.clear()
- elif c == " ":
- sleep(interletter)
- return
- def ReceiveCW():
- display.show(ANT)
- message = ''
- started = running_time()
- while True:
- waiting = running_time() - started
- received = radio.receive()
- if received:
- FlashMorse(EncodeMorse(received))
- message += received
- if button_b.is_pressed():
- return # breakin to immediate keying
- if pin2.is_touched():
- if button_a.was_pressed():
- display.scroll(message) # nb blocks receive while showing...
- message = ''
- if waiting > WORD_THRESHOLD * 2:
- display.show(ANT)
- if len(message) > 15: #keep message buffer short...
- message = message[1:16]
- if accelerometer.was_gesture("shake"):
- display.scroll("CW TRX by M0RVJ")
- def Keyer():
- buffer = ''
- message = ''
- while True:
- waited = running_time() - started
- key_down_time = None
- while button_b.is_pressed(): ## button B keying
- if not key_down_time:
- key_down_time = running_time()
- music.pitch(sidetone, -1, pin0, False)
- while True:
- if not button_b.is_pressed():
- music.stop()
- break
- while pin2.is_touched(): ## touch keying
- while True:
- if not pin2.is_touched():
- music.stop()
- break
- key_up_time = running_time()
- if key_down_time:
- duration = key_up_time - key_down_time
- if duration < DOT_THRESHOLD:
- buffer += '.'
- display.show(DOT)
- elif duration:
- buffer += '-'
- elif len(buffer) > 0 and waited > DASH_THRESHOLD:
- display.clear()
- character = decodemorse.get(buffer, '?')
- buffer = ''
- display.show(character)
- if txenabled:
- radio.send(character)
- message += character
- if waited > WORD_THRESHOLD * 2:
- return
- while True:
- Keyer()
- ReceiveCW()
复制代码
