4289|8
关于DSP builder里编译出错问题 [复制链接]
我的软件版本是 MATLAB 2010b + DSP 11.0 + QUATUS 11.0 (都是32位)。
现在破解完了,编译时点击compile 时报错:
Info: Generating HDL
Info: Analyzing Simulink model
Info: Analysis was successful
Error: Error during compilation: Synthesis failed
已经断断续续弄了一个月了,有哪位大神有过类似经历能帮忙解决一下?谢谢了
此帖出自FPGA/CPLD论坛
你这个问题解决没有啊?我也遇到了这个问题,想请教你是怎么解决的  详情 回复 发表于 2017-6-23 10:18
这是截图
此帖出自FPGA/CPLD论坛
自顶自顶
此帖出自FPGA/CPLD论坛
>> dos('lmutil lmdiag C4D5_512A')
lmutil - Copyright (c) 1989-2008 Acresso Software Inc. All Rights Reserved.
FLEXnet diagnostics on Fri 6/9/2017 09:48
License file: D:\license.dat
"C4D5_512A" v2088.12, vendor: alterad
  uncounted nodelocked license, locked to ethernet address "98e7f464a11b"  expires: 01-dec-2088
This is the correct node for this node-locked license
Enter to continue: "C4D5_512A" v2037.12, vendor: alterad
  uncounted nodelocked license, locked to ethernet address "98e7f464a11b"  expires: 01-dec-2037
Enter to continue: "C4D5_512A" v9999.12, vendor: alterad
  uncounted nodelocked license, locked to ethernet address "98e7f464a11b"  expires: 22-mar-2037
  TS_OK: Checkout permitted when client is using terminal client
Enter to continue: "C4D5_512A" v2050.01, vendor: alterad
  uncounted nodelocked license, locked to ethernet address "98e7f464a11b"  starts: 1-jan-1990,  no expiration date
ans =
此帖出自FPGA/CPLD论坛
33
把资料发给我。
此帖出自FPGA/CPLD论坛
什么资料
此帖出自FPGA/CPLD论坛
45
pengyongnet邀请您访问电子工程世界-论坛
https://home.eeworld.com.cn/?fromuser=pengyongnet
此帖出自FPGA/CPLD论坛
此帖出自FPGA/CPLD论坛
可能是需要32位系统,我换了个版本
此帖出自FPGA/CPLD论坛
