2717|1
采集不到数据,是为什么?求助 [复制链接]
10芯积分
#include  "msp430g2553.h"
#include  "OLED_SSD1306.h"
long temp;
long display_data_01;
void OLED_SSD1306_DisplayVoltage()
  unsigned char Display_val[5]={0,0,0x2e,0,0};
  OLED_SSD1306_Init();
  while(1)
    Display_val[0] =display_data_01/100+0x30;
    Display_val[1] =(display_data_01%100/10)+0x30;
    Display_val[3] =(display_data_01%10)+0x30;
    OLED_SSD1306_Display8x16Str(0,0, "U");
    OLED_SSD1306_Display8x16Str(0,8, "");
    OLED_SSD1306_Display8x16Str(0,16, "_");
    OLED_SSD1306_Display8x16Str(0,24, "01:");
    OLED_SSD1306_Display8x16Str(0,56, &Display_val[0]);
    OLED_SSD1306_Display8x16Str(0,96, "V");
    __delay_cycles(10000);
void ADC10_Init()
  P1SEL&=0x02;
  ADC10CTL0=ADC10SHT_1+ADC10ON+SREF_1+REF2_5V+REFON+MSC;
  ADC10CTL1=INCH_1+ADC10DIV_1+CONSEQ_2;
  ADC10AE0|=BIT1;
void PWM_Init()
P1DIR |= BIT6+BIT0;
P1DIR &=~BIT3;       //P1.3作为按键输入
P1SEL |= BIT6;       //P1.6作为PWM输出
P1IE |= BIT3;                         // P1.3 interrupt enabled
P1IES |= BIT3;                          // P1.3 Hi/lo edge
P1REN |= BIT3;                          // P1.3 pullup
P1OUT|=BIT0;       //P1.0作为一个指示灯输出
_EINT();
TACTL = TASSEL_2 + MC_1+ID_3;// MCLK, up mode,适用于高频率
CCR0 = 511;// PWM 周期  =(CCRO+1)/1048576,频率=1.048576MHz/(CCRO+1))
CCTL1 = OUTMOD_7;// CCR1 reset/set
CCR1 = 33;// CCR1 PWM 占空比% = (CCR1+1)/(CCRO+1)
#pragma vector=PORT1_VECTOR
__interrupt void PORT1_ISR(void)
P1OUT ^= BIT0;    //每读一次中断,指示灯状态取反
TACCR1=TACCR1+1 ;
if(TACCR1==49)
  TACCR1=33;
    P1IFG &= ~BIT3;                       // P1.3 IFG cleared
void main(void)
  WDTCTL=WDTPW+WDTHOLD;
  ADC10_Init();
  PWM_Init();
    while(1)
  ADC10CTL0 |= ENC+ADC10SC;
  temp=ADC10MEM;
  display_data_01=temp*250/1023;
  OLED_SSD1306_DisplayVoltage();
引脚功能配置不对,改一下配置,建议在开头配置一下系统时钟  详情 回复 发表于 2017-6-4 20:50
1059
