4724|7
TM4C129 的ADC误差为什么那么大? [复制链接]
1芯积分
以下是我的ADC初始化程序
SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);//开启ADC时钟
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);//开启相应ADC引脚时钟
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);//开启相应ADC引脚时钟
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);//开启相应ADC引脚时钟
SysCtlPeripheralEnable(SYSCTL_PERIPH_EEPROM0);
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3 | GPIO_PIN_2 | GPIO_PIN_1 | GPIO_PIN_0);//通道引脚初始化
GPIOPinTypeADC(GPIO_PORTD_BASE, GPIO_PIN_7 | GPIO_PIN_6 | GPIO_PIN_5 | GPIO_PIN_4);//通道引脚初始化
ADCSequenceConfigure(ADC0_BASE, ADC_SS0, ADC_TRIGGER_PROCESSOR, 0);//ADC模式配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS0, 0, ADC_CTL_CH0);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS0, 1, ADC_CTL_CH1);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS0, 2, ADC_CTL_CH2);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS0, 3, ADC_CTL_CH3);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS0, 4, ADC_CTL_CH4);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS0, 5, ADC_CTL_CH5);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS0, 6, ADC_CTL_CH6);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS0, 7, ADC_CTL_CH7 | ADC_CTL_IE | ADC_CTL_END);//采样通道配置
ADCSequenceEnable(ADC0_BASE, ADC_SS0); //使能采样序列
ADCIntClear(ADC0_BASE, ADC_SS0); //清除中断标志
ADCIntRegister(ADC0_BASE, ADC_SS0,ADC_SS0_pfnIntHandler);//注册ADC中断函数
ADCIntEnable(ADC0_BASE, ADC_SS0);
IntEnable(INT_ADC0SS0);
/*****ADC0_SS2初始化******/
GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_5 | GPIO_PIN_4);//通道引脚初始化
GPIOPinTypeADC(GPIO_PORTB_BASE, GPIO_PIN_5 | GPIO_PIN_4);//通道引脚初始化
ADCSequenceConfigure(ADC0_BASE, ADC_SS2, ADC_TRIGGER_PROCESSOR, 0);//ADC模式配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS2, 0, ADC_CTL_CH8);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS2, 1, ADC_CTL_CH9);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS2, 2, ADC_CTL_CH10);//采样通道配置
ADCSequenceStepConfigure(ADC0_BASE, ADC_SS2, 3, ADC_CTL_CH11 | ADC_CTL_IE | ADC_CTL_END);//采样通道配置
ADCSequenceEnable(ADC0_BASE, ADC_SS2); //使能采样序列
ADCIntClear(ADC0_BASE, ADC_SS2); //清除中断标志
ADCIntRegister(ADC0_BASE, ADC_SS2,ADC_SS2_pfnIntHandler);//注册ADC中断函数
ADCIntEnable(ADC0_BASE, ADC_SS2);
IntEnable(INT_ADC0SS2);
IntMasterEnable();
开启了ADC0的12个通道同时采集,发现检测值与实际值越差越大。下图可作对比:
红色是检测值,蓝色是万用表测的。
请问这是什么原因?
精度12位的只要数据稳定,说明ADC采集的数据是正确的。和实际值相比有差距是正常的。  详情 回复 发表于 2018-9-12 16:00
点赞 关注(1)
ADC采样值到电压的计算是根据这个公式:ADCValue*3300/4096。
918
TIVA 应该是没有内部的 REF 的,所以受  VDDA 的稳定性影响。如果使用外部参考源或者给 VDDA 从 VDD 隔离出来。应该会提高精度。另外开启过采样,或者做一些线性校正也可以。
参考一下:
http://e2e.ti.com/support/microc ... _arm/f/908/t/280012
academic 发表于 2017-6-2 15:47
TIVA 应该是没有内部的 REF 的,所以受  VDDA 的稳定性影响。如果使用外部参考源或者给 VDDA 从 VDD 隔离出 ...
非常感谢,的确是参考电压的问题。硬件电路里VDDA前边给接了电阻,改成0欧就好了。
最好用REF基准电压源,直接从电源拉过来电源电压也会有波动的可能
查看本帖全部讨论,请登录或者注册
查看本帖全部讨论,请登录或者注册
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
