HAL_StatusTypeDef HAL_SPI_Transmit(SPI_HandleTypeDef *hspi, uint8_t *pData, uint16_t Size, uint32_t Timeout) { uint32_t tickstart = HAL_GetTick(); HAL_StatusTypeDef errorcode = HAL_OK; assert_param(IS_SPI_DIRECTION_2LINES_OR_1LINE(hspi->Init.Direction)); /* Process Locked */ __HAL_LOCK(hspi); if(hspi->State != HAL_SPI_STATE_READY) { errorcode = HAL_BUSY; goto error; } if((pData == NULL ) || (Size == 0)) { errorcode = HAL_ERROR; goto error; } /* Set the transaction information */ hspi->State = HAL_SPI_STATE_BUSY_TX; hspi->ErrorCode = HAL_SPI_ERROR_NONE; hspi->pTxBuffPtr = pData; hspi->TxXferSize = Size; hspi->TxXferCount = Size; hspi->pRxBuffPtr = (uint8_t *)NULL; hspi->RxXferSize = 0; hspi->RxXferCount = 0; /* Configure communication direction : 1Line */ if(hspi->Init.Direction == SPI_DIRECTION_1LINE) { SPI_1LINE_TX(hspi); } /* Reset CRC Calculation */ if(hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE) { SPI_RESET_CRC(hspi); } /* Check if the SPI is already enabled */ if((hspi->Instance->CR1 & SPI_CR1_SPE) != SPI_CR1_SPE) { /* Enable SPI peripheral */ __HAL_SPI_ENABLE(hspi); } /* Transmit data in 16 Bit mode */ if(hspi->Init.DataSize > SPI_DATASIZE_8BIT) { /* Transmit data in 16 Bit mode */ while (hspi->TxXferCount > 0) { /* Wait until TXE flag is set to send data */ if((hspi->Instance->SR & SPI_FLAG_TXE) == SPI_FLAG_TXE) { hspi->Instance->DR = *((uint16_t *)hspi->pTxBuffPtr); hspi->pTxBuffPtr += sizeof(uint16_t); hspi->TxXferCount--; } else { /* Timeout management */ if((Timeout == 0) || ((Timeout != HAL_MAX_DELAY) && ((HAL_GetTick()-tickstart) >= Timeout))) { errorcode = HAL_TIMEOUT; goto error; } } } } /* Transmit data in 8 Bit mode */ else { while (hspi->TxXferCount > 0) { /* Wait until TXE flag is set to send data */ if((hspi->Instance->SR & SPI_FLAG_TXE) == SPI_FLAG_TXE) { if(hspi->TxXferCount > 1) { /* write on the data register in packing mode */ hspi->Instance->DR = *((uint16_t*)hspi->pTxBuffPtr); hspi->pTxBuffPtr += sizeof(uint16_t); hspi->TxXferCount -= 2; } else { *((__IO uint8_t*)&hspi->Instance->DR) = (*hspi->pTxBuffPtr++); hspi->TxXferCount--; } } else { /* Timeout management */ if((Timeout == 0) || ((Timeout != HAL_MAX_DELAY) && ((HAL_GetTick()-tickstart) >= Timeout))) { errorcode = HAL_TIMEOUT; goto error; } } } } /* Enable CRC Transmission */ if(hspi->Init.CRCCalculation == SPI_CRCCALCULATION_ENABLE) { hspi->Instance->CR1|= SPI_CR1_CRCNEXT; } /* Check the end of the transaction */ if(SPI_EndRxTxTransaction(hspi,Timeout) != HAL_OK) { hspi->ErrorCode = HAL_SPI_ERROR_FLAG; } /* Clear overrun flag in 2 Lines communication mode because received is not read */ if(hspi->Init.Direction == SPI_DIRECTION_2LINES) { __HAL_SPI_CLEAR_OVRFLAG(hspi); } if(hspi->ErrorCode != HAL_SPI_ERROR_NONE) { errorcode = HAL_ERROR; } error: hspi->State = HAL_SPI_STATE_READY; /* Process Unlocked */ __HAL_UNLOCK(hspi); return errorcode; } |
