1578|0
6850
AD9850驱动程序--MSP430 [复制链接]
前段时间忙着画板子搞运放搞滤波了,程序更新的少,发现MSP430不是太好用,尤其Timer,不过也与我使用内部晶振有关,产生正玄波之前用MSP430发出PWM,再进行滤波变为正弦波太麻烦了,这次改用DDS芯片,今天板子回来一会就调了出来很方便。
AD9850为一款DDS芯片,这里不做什么详细介绍了,有两种接口:serial 和 parrel,两种接口驱动均完成
  • * AD9850.h
  • *  Created on: 2013-7-12
  • *      Author: Allen
  • #ifndef AD9850_H_
  • #define AD9850_H_
  • #include
  • #include    "MyType.h"
  • //AD9850:W_CLK P2.5
  • #define        AD9850_W_CLK_DIR            (P2DIR)
  • #define        AD9850_W_CLK_OUT            (P2OUT)
  • #define        AD9850_W_CLK_PIN_NUM        (BIT5)
  • #define        AD9850_W_CLK_IO_INIT        (Set_Bit(P2DIR,AD9850_W_CLK_PIN_NUM))
  • #define        AD9850_W_CLK_H                (Set_Bit(P2OUT,AD9850_W_CLK_PIN_NUM))
  • #define        AD9850_W_CLK_L                (Clr_Bit(P2OUT,AD9850_W_CLK_PIN_NUM))
  • //AD9850:FQ_UP P2.4
  • #define        AD9850_FQ_UP_DIR            (P2DIR)
  • #define        AD9850_FQ_UP_OUT            (P2OUT)
  • #define        AD9850_FQ_UP_PIN_NUM        (BIT4)
  • #define        AD9850_FQ_UP_IO_INIT        (Set_Bit(P2DIR,AD9850_FQ_UP_PIN_NUM))
  • #define        AD9850_FQ_UP_H                (Set_Bit(P2OUT,AD9850_FQ_UP_PIN_NUM))
  • #define        AD9850_FQ_UP_L                (Clr_Bit(P2OUT,AD9850_FQ_UP_PIN_NUM))
  • //AD9850:RESET P2.3
  • #define        AD9850_RESET_DIR            (P2DIR)
  • #define        AD9850_RESET_OUT            (P2OUT)
  • #define        AD9850_RESET_PIN_NUM        (BIT3)
  • #define        AD9850_RESET_IO_INIT        (Set_Bit(P2DIR,AD9850_RESET_PIN_NUM))
  • #define        AD9850_RESET_H                (Set_Bit(P2OUT,AD9850_RESET_PIN_NUM))
  • #define        AD9850_RESET_L                (Clr_Bit(P2OUT,AD9850_RESET_PIN_NUM))
  • //AD9850:BIT_DATA P1.7
  • #define        AD9850_BIT_DATA_DIR            (P1DIR)
  • #define        AD9850_BIT_DATA_OUT            (P1OUT)
  • #define        AD9850_BIT_DATA_PIN_NUM        (BIT7)
  • #define        AD9850_BIT_DATA_IO_INIT        (Set_Bit(P1DIR,AD9850_BIT_DATA_PIN_NUM))
  • #define        AD9850_BIT_DATA_H            (Set_Bit(P1OUT,AD9850_BIT_DATA_PIN_NUM))
  • #define        AD9850_BIT_DATA_L            (Clr_Bit(P1OUT,AD9850_BIT_DATA_PIN_NUM))
  • extern void AD9850_INIT_SERIAL(void);
  • extern void AD9850_RESET_SERIAL(void);
  • extern void AD9850_WR_SERIAL(unsigned char w0,double frequence);
  • extern void AD9850_INIT_PARREL(void);
  • extern void AD9850_RESET_PARREL(void);
  • extern void AD9850_WR_PARREL(unsigned char w0,double frequence);
  • #endif /* LED_H_ */
  • AD9850.h
[color=rgb(51, 102, 153) !important]复制代码
以上是头文件完成了pin定义与位操作,并口的数据线操作并没定义,到时候直接用port操作很方便,AD9850的D0-D7与MSP430的P1.0-P1.7对应,一次写入8位很简单。
其中使用了#include "MyType.h"中一些操作:
// C
#define  Set_Bit(val, bitn)  (val |= (/*1 <<*/(bitn)))
#define  Clr_Bit(val, bitn)  (val &= ~(/*1<<*/(bitn)))
#define  Get_Bit(val, bitn)  (val & (1<<(bitn)) )
先写的串口的程序:
  • void AD9850_INIT_SERIAL(void)
  •     AD9850_W_CLK_IO_INIT;
  •     AD9850_FQ_UP_IO_INIT;
  •     AD9850_RESET_IO_INIT;
  •     AD9850_BIT_DATA_IO_INIT;
  • AD9850_INIT_SERIAL
  • void AD9850_RESET_SERIAL(void)
  •     AD9850_W_CLK_L;
  •     AD9850_FQ_UP_L;
  •     //rest信号
  •     AD9850_RESET_L;
  •     AD9850_RESET_H;
  •     AD9850_RESET_L;
  •     //w_clk信号
  •     AD9850_W_CLK_L;
  •     AD9850_W_CLK_H;
  •     AD9850_W_CLK_L;
  •     //fq_up信号
  •     AD9850_FQ_UP_L;
  •     AD9850_FQ_UP_H;
  •     AD9850_FQ_UP_L;
  • AD9850_RESET_SERIAL
  • void AD9850_WR_SERIAL(unsigned char w0,double frequence)
  •     unsigned char i,w;
  •     long int y;
  •     double x;
  •     //计算频率的HEX值
  •     x=4294967295/20;//适合125M晶振
  •     //如果时钟频率不为20MHZ,修改该处的频率值,单位MHz  !!!
  •     frequence=frequence/1000000;
  •     frequence=frequence*x;
  •     y=frequence;
  •     //写w4数据
  •     w=(y>>=0);
  •     for(i=0;i<8;i++)
  • //       ad9850_bit_data=(w>>i)&0x01;
  •        if((w>>i)&0x01)
  •          AD9850_BIT_DATA_H;
  •        else
  •          AD9850_BIT_DATA_L;
  •        AD9850_W_CLK_H;
  •        AD9850_W_CLK_L;
  •     //写w3数据
  •     w=(y>>8);
  •     for(i=0;i<8;i++)
  •         if((w>>i)&0x01)
  •         else
  •         AD9850_W_CLK_H;
  •         AD9850_W_CLK_L;
  •     //写w2数据
  •     w=(y>>16);
  •     for(i=0;i<8;i++)
  •         if((w>>i)&0x01)
  •         else
  •         AD9850_W_CLK_H;
  •         AD9850_W_CLK_L;
  •     //写w1数据
  •     w=(y>>24);
  •     for(i=0;i<8;i++)
  •         if((w>>i)&0x01)
  •         else
  •         AD9850_W_CLK_H;
  •         AD9850_W_CLK_L;
  •     //写w0数据
  •     w=w0;
  •     for(i=0;i<8;i++)
  •         if((w>>i)&0x01)
  •         else
  •         AD9850_W_CLK_H;
  •         AD9850_W_CLK_L;
  •     //移入始能
  •     AD9850_FQ_UP_H;
  •     AD9850_FQ_UP_L;
  • AD9850_WR_SERIAL
串行连接时候需要注意pin2-4的连接:
  • void AD9850_INIT_PARREL(void)
  •     P1DIR=0xff;
  • AD9850_INIT_PARREL
  •     P1DIR=0xff;
  •     P1DIR=0xff;
主函数:
  • char mode=0; //0:serial   1:parrel
  • * main.c
  • int main(void) {
  •     WDTCTL = WDTPW | WDTHOLD;    // Stop watchdog timer
  •     mode=0;
  •     if(mode==0)
  •         AD9850_INIT_SERIAL();
  •         AD9850_RESET_SERIAL();
  •         AD9850_WR_SERIAL(0,18000);
  •     else if(mode==1)
  •         AD9850_INIT_PARREL();
  •         AD9850_RESET_PARREL();
  •         AD9850_WR_PARREL(0,25000);
  •     while(1)
  •     return 0;
  • main(void)
