AD9850驱动程序--MSP430版本
前段时间忙着画板子搞运放搞滤波了,程序更新的少,发现MSP430不是太好用,尤其Timer,不过也与我使用内部晶振有关,产生正玄波之前用MSP430发出PWM,再进行滤波变为正弦波太麻烦了,这次改用DDS芯片,今天板子回来一会就调了出来很方便。
AD9850为一款DDS芯片,这里不做什么详细介绍了,有两种接口:serial 和 parrel,两种接口驱动均完成
- * AD9850.h
- * Created on: 2013-7-12
- * Author: Allen
- #ifndef AD9850_H_
- #define AD9850_H_
- #include
- #include "MyType.h"
- //AD9850:W_CLK P2.5
- #define AD9850_W_CLK_DIR (P2DIR)
- #define AD9850_W_CLK_OUT (P2OUT)
- #define AD9850_W_CLK_PIN_NUM (BIT5)
- #define AD9850_W_CLK_IO_INIT (Set_Bit(P2DIR,AD9850_W_CLK_PIN_NUM))
- #define AD9850_W_CLK_H (Set_Bit(P2OUT,AD9850_W_CLK_PIN_NUM))
- #define AD9850_W_CLK_L (Clr_Bit(P2OUT,AD9850_W_CLK_PIN_NUM))
- //AD9850:FQ_UP P2.4
- #define AD9850_FQ_UP_DIR (P2DIR)
- #define AD9850_FQ_UP_OUT (P2OUT)
- #define AD9850_FQ_UP_PIN_NUM (BIT4)
- #define AD9850_FQ_UP_IO_INIT (Set_Bit(P2DIR,AD9850_FQ_UP_PIN_NUM))
- #define AD9850_FQ_UP_H (Set_Bit(P2OUT,AD9850_FQ_UP_PIN_NUM))
- #define AD9850_FQ_UP_L (Clr_Bit(P2OUT,AD9850_FQ_UP_PIN_NUM))
- //AD9850:RESET P2.3
- #define AD9850_RESET_DIR (P2DIR)
- #define AD9850_RESET_OUT (P2OUT)
- #define AD9850_RESET_PIN_NUM (BIT3)
- #define AD9850_RESET_IO_INIT (Set_Bit(P2DIR,AD9850_RESET_PIN_NUM))
- #define AD9850_RESET_H (Set_Bit(P2OUT,AD9850_RESET_PIN_NUM))
- #define AD9850_RESET_L (Clr_Bit(P2OUT,AD9850_RESET_PIN_NUM))
- //AD9850:BIT_DATA P1.7
- #define AD9850_BIT_DATA_DIR (P1DIR)
- #define AD9850_BIT_DATA_OUT (P1OUT)
- #define AD9850_BIT_DATA_PIN_NUM (BIT7)
- #define AD9850_BIT_DATA_IO_INIT (Set_Bit(P1DIR,AD9850_BIT_DATA_PIN_NUM))
- #define AD9850_BIT_DATA_H (Set_Bit(P1OUT,AD9850_BIT_DATA_PIN_NUM))
- #define AD9850_BIT_DATA_L (Clr_Bit(P1OUT,AD9850_BIT_DATA_PIN_NUM))
- extern void AD9850_INIT_SERIAL(void);
- extern void AD9850_RESET_SERIAL(void);
- extern void AD9850_WR_SERIAL(unsigned char w0,double frequence);
- extern void AD9850_INIT_PARREL(void);
- extern void AD9850_RESET_PARREL(void);
- extern void AD9850_WR_PARREL(unsigned char w0,double frequence);
- #endif /* LED_H_ */
- AD9850.h
[color=rgb(51, 102, 153) !important]复制代码
以上是头文件完成了pin定义与位操作,并口的数据线操作并没定义,到时候直接用port操作很方便,AD9850的D0-D7与MSP430的P1.0-P1.7对应,一次写入8位很简单。 其中使用了#include "MyType.h"中一些操作: // C
#define Set_Bit(val, bitn) (val |= (/*1 <<*/(bitn)))
#define Clr_Bit(val, bitn) (val &= ~(/*1<<*/(bitn)))
#define Get_Bit(val, bitn) (val & (1<<(bitn)) ) 先写的串口的程序: - void AD9850_INIT_SERIAL(void)
- AD9850_W_CLK_IO_INIT;
- AD9850_FQ_UP_IO_INIT;
- AD9850_RESET_IO_INIT;
- AD9850_BIT_DATA_IO_INIT;
- AD9850_INIT_SERIAL
- void AD9850_RESET_SERIAL(void)
- AD9850_W_CLK_L;
- AD9850_FQ_UP_L;
- //rest信号
- AD9850_RESET_L;
- AD9850_RESET_H;
- AD9850_RESET_L;
- //w_clk信号
- AD9850_W_CLK_L;
- AD9850_W_CLK_H;
- AD9850_W_CLK_L;
- //fq_up信号
- AD9850_FQ_UP_L;
- AD9850_FQ_UP_H;
- AD9850_FQ_UP_L;
- AD9850_RESET_SERIAL
- void AD9850_WR_SERIAL(unsigned char w0,double frequence)
- unsigned char i,w;
- long int y;
- double x;
- //计算频率的HEX值
- x=4294967295/20;//适合125M晶振
- //如果时钟频率不为20MHZ,修改该处的频率值,单位MHz !!!
- frequence=frequence/1000000;
- frequence=frequence*x;
- y=frequence;
- //写w4数据
- w=(y>>=0);
- for(i=0;i<8;i++)
- // ad9850_bit_data=(w>>i)&0x01;
- if((w>>i)&0x01)
- AD9850_BIT_DATA_H;
- else
- AD9850_BIT_DATA_L;
- AD9850_W_CLK_H;
- AD9850_W_CLK_L;
- //写w3数据
- w=(y>>8);
- for(i=0;i<8;i++)
- if((w>>i)&0x01)
- else
- AD9850_W_CLK_H;
- AD9850_W_CLK_L;
- //写w2数据
- w=(y>>16);
- for(i=0;i<8;i++)
- if((w>>i)&0x01)
- else
- AD9850_W_CLK_H;
- AD9850_W_CLK_L;
- //写w1数据
- w=(y>>24);
- for(i=0;i<8;i++)
- if((w>>i)&0x01)
- else
- AD9850_W_CLK_H;
- AD9850_W_CLK_L;
- //写w0数据
- w=w0;
- for(i=0;i<8;i++)
- if((w>>i)&0x01)
- else
- AD9850_W_CLK_H;
- AD9850_W_CLK_L;
- //移入始能
- AD9850_FQ_UP_H;
- AD9850_FQ_UP_L;
- AD9850_WR_SERIAL
串行连接时候需要注意pin2-4的连接:
- void AD9850_INIT_PARREL(void)
- P1DIR=0xff;
- AD9850_INIT_PARREL
- P1DIR=0xff;
- P1DIR=0xff;
主函数:
- char mode=0; //0:serial 1:parrel
- * main.c
- int main(void) {
- WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer
- mode=0;
- if(mode==0)
- AD9850_INIT_SERIAL();
- AD9850_RESET_SERIAL();
- AD9850_WR_SERIAL(0,18000);
- else if(mode==1)
- AD9850_INIT_PARREL();
- AD9850_RESET_PARREL();
- AD9850_WR_PARREL(0,25000);
- while(1)
- return 0;
- main(void)
