2784|0
2721
【RX62N】RX62N介绍 [复制链接]
此内容由EEWORLD论坛网友suoma原创,如需转载或用于商业用途需征得作者同意并注明出处
接上一篇帖子
【RX62N】上电 - 【瑞萨电子MCU】 - 电子工程世界-论坛 https://bbs.eeworld.com.cn/thread-525007-1-1.html
开发板全名:The Renesas Demonstration Kit for RX62N,内嵌µC/OS-III实时系统,TCP-IP协议栈,见下
主要资源如下
特性
  • 96MHz RX62N MCU board with integrated debugger and huge peripheral set including Ethernet, CAN, and USB
  • USB Mini A/B to Host Cable
  • USB Debugger Cable
  • Installation CD containing:
    • High-Performance Embedded Workshop (HEW) with updated Project Generator
    • RX Family C/C++ Toolchains (Renesas 128K evaluation version, Full KPIT GNU version, IAR Embedded WorkBench 2.30)
    • Quick-Start Guide (x4)
    • RX62N Sample Projects (IAR and PG)
    • Documentation (User's Manual, Data Sheets, and more)
