2163|2
32
有没有人用sensor tile的spi [复制链接]
 打算用spi做一个数据外传,好像最方便的就是直接改datalog里往sd卡里写的那个程序,有没有小伙伴改写过求指点一下,或者有没有更好的数据外传的方法,主要是外传给另一个32的芯片
你是打算用怎样的SPI来做通讯呢?3线?4线?中断?轮循?  详情 回复 发表于 2017-3-28 10:40
9795
24
SensorTile的传感器应该就是用SPI实现的,代码你可以参考一下
  1. uint8_t Sensor_IO_SPI_CS_Init_All(void)
  2. {
  3.   GPIO_InitTypeDef GPIO_InitStruct;
  4.
  5.   GPIO_InitStruct.Speed = GPIO_SPEED_HIGH;
  6.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  7.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  8.
  9.   SENSORTILE_LSM6DSM_SPI_CS_GPIO_CLK_ENABLE();
  10.   GPIO_InitStruct.Pin = SENSORTILE_LSM6DSM_SPI_CS_Pin;
  11.   HAL_GPIO_Init(SENSORTILE_LSM6DSM_SPI_CS_Port, &GPIO_InitStruct);
  12.   HAL_GPIO_WritePin(SENSORTILE_LSM6DSM_SPI_CS_Port, SENSORTILE_LSM6DSM_SPI_CS_Pin, GPIO_PIN_SET);
  13.
  14.   SENSORTILE_LSM303AGR_X_SPI_CS_GPIO_CLK_ENABLE();
  15.   GPIO_InitStruct.Pin = SENSORTILE_LSM303AGR_X_SPI_CS_Pin;
  16.   HAL_GPIO_Init(SENSORTILE_LSM303AGR_X_SPI_CS_Port, &GPIO_InitStruct);
  17.   HAL_GPIO_WritePin(SENSORTILE_LSM303AGR_X_SPI_CS_Port, SENSORTILE_LSM303AGR_X_SPI_CS_Pin, GPIO_PIN_SET);
  18.
  19.   SENSORTILE_LSM303AGR_M_SPI_CS_GPIO_CLK_ENABLE();
  20.   GPIO_InitStruct.Pin = SENSORTILE_LSM303AGR_M_SPI_CS_Pin;
  21.   HAL_GPIO_Init(SENSORTILE_LSM303AGR_M_SPI_CS_Port, &GPIO_InitStruct);
  22.   HAL_GPIO_WritePin(SENSORTILE_LSM303AGR_M_SPI_CS_Port, SENSORTILE_LSM303AGR_M_SPI_CS_Pin, GPIO_PIN_SET);
  23.
  24.   SENSORTILE_LPS22HB_SPI_CS_GPIO_CLK_ENABLE();
  25.   GPIO_InitStruct.Pin = SENSORTILE_LPS22HB_SPI_CS_Pin;
  26.   HAL_GPIO_Init(SENSORTILE_LPS22HB_SPI_CS_Port, &GPIO_InitStruct);
  27.   HAL_GPIO_WritePin(SENSORTILE_LPS22HB_SPI_CS_Port, SENSORTILE_LPS22HB_SPI_CS_Pin, GPIO_PIN_SET);
  28.   return COMPONENT_OK;
  29. }
复制代码
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
46
