5612|3
MSP430FR5994 LaunchPad [复制链接]
写了个最最简单的代码  blink LED,下载到MSP430FR5994 LaunchPad,出现如下问题:
1。 format配置为other,下载
出现如下问题
2. format配置为Debug information for C-SPY
log window 出现:
Tue Mar 07, 2017 13:26:25: Illegal register  LEASCIE.LEASCTIE  in interrupt description:
LEA_SC_VECTOR  0x24  2  LEASCIE.LEASCTIE  LEASCIFG.LEASCTIFG
Tue Mar 07, 2017 13:26:48: Warning: Finished loading interrupt definitions. There were 1 error(s), see the log window.
板子电压都正常,然后IAR调试代码,IAR观察P1.0都输出正常,但是板子上等不亮,我自己换个IO外接LED 也是没反应。。
到底是怎么回去啊
贴代码:
#include "msp430fr5994.h"
int main(void)
    WDTCTL = WDTPW | WDTHOLD;               // Stop WDT
    // Configure GPIO
    P1OUT &= ~BIT0;                         // Clear P1.0 output latch for a defined power-on state
    P1DIR |= BIT0;                          // Set P1.0 to output direction
    PM5CTL0 &= ~LOCKLPM5;                   // Disable the GPIO power-on default high-impedance mode
                                            // to activate previously configured port settings
    while(1)
        P1OUT ^= BIT0;                      // Toggle LED
        __delay_cycles(100000);
我今天早上剛剛練習了這個範例: //****************************************************************************** //  MSP430FR5x9x Demo - Toggle P1.0 using software // //  Description: Toggle P1.0 using software. //  ACLK = n/a, MCLK = SMCLK = default DCO // //           MSP430FR5994 //         --------------- //     /|\|               | //      | |               | //      --|RST            | //        |               | //        |           P1.0|-->LED //        |           P1.1|-->LED //        |               | // // //   William Goh //   Texas Instruments Inc. //   October 2015 //   Built with IAR Embedded Workbench V6.30 & Code Composer Studio V6.1 //****************************************************************************** #include int main(void) {     WDTCTL = WDTPW | WDTHOLD;               // Stop WDT     // Configure GPIO     P1OUT &= ~BIT0;                         // Clear P1.0 output latch for a defined power-on state     P1DIR |=  BIT0;                         // Set P1.0 to output direction     PM5CTL0 &= ~LOCKLPM5;                   // Disable the GPIO power-on default high-impedance mode                                             // to activate previously configured port settings     while(1)     {         P1OUT ^= BIT0;                      // Toggle LED         __delay_cycles(100000);     } } 提供給大家參考 !!!  详情 回复 发表于 2017-9-15 16:58
1059
你的时钟没有配置,配置时钟,iar设置参考官方工程配置即可
我觉得是中断向量的问题,XCL文件中断向量INTC从0xFF90开始,5994头文件中断向量第一个是0xFFB4
99
我今天早上剛剛練習了這個範例:
//           MSP430FR5994
//      --|RST            |
//        |           P1.0|-->LED
//        |           P1.1|-->LED
//   William Goh
//   October 2015
#include
int main(void)
    // Configure GPIO
    while(1)
提供給大家參考 !!!
