2023|0
37
关于MICO智能硬件的问题3 [复制链接]
各位高手,小弟正在基于庆科micokit-3165开发板和MICO操作系统开发应用。正在调试micokit_enjoy工程。运行完成“uint32_t activate_retry_interval = 3;”后,查看activate_retry_interval的值为2779096485,请教activate_retry_interval的值为什么不等于3?谢谢!部分代码如下:
   void fogcloud_main_thread(void *arg)
OSStatus err = kUnknownErr;
app_context_t* inContext = (app_context_t *)arg;
MVDResetRequestData_t devResetRequestData;
#ifdefENABLE_FOGCLOUD_AUTO_ACTIVATE
MVDActivateRequestData_t devDefaultActivateData;
#endif
/* wait for station on */
while(!inContext->appStatus.isWifiConnected){
   mico_thread_msleep(500);
//--- create msg recv queue, NOTE: just push msg pionter into queue, somsg memory must be freed after used.
if(NULL == msg_recv_queue_mutex){
   err = mico_rtos_init_mutex(&msg_recv_queue_mutex);
require_noerr_action(err,exit,fogcloud_log("ERROR: mico_rtos_init_mutex
(msg_recv_queue_mutex)failed, err=%d.", err));
