1098
至上芯片
81
老外做的7个LED的旋转电子钟
三。软件编程
  因学的是C51(不懂汇编)这里只提供C语言源程序,并限制为无遥控功能。也可提供带遥控功能的hex文件。
#include
sbit gate11=P3^0;
sbit gate12=P3^1;
#define unit unsigned int
#define uchar unsigned char
uchar data BUFFER[]={0,0,0,0,1,1,7};
uchar data M[]={31,28,31,30,31,30,31,31,30,31,30,31};
uchar code NUM1[] =
0x80,0x7F,0xC0,0xFF,0x40,0x90,0x40,0x8C,                // -0-
0x40,0x82,0xC0,0xFF,0x80,0x7F,0x00,0x00,
0x00,0x00,0x00,0x81,0x80,0x81,0xC0,0xFF,                // -1-
0xC0,0xFF,0x00,0x80,0x00,0x80,0x00,0x00,
0x80,0xE0,0xC0,0xF0,0x40,0x98,0x40,0x8C,                // -2-
0x40,0x86,0xC0,0xC3,0x80,0xC1,0x00,0x00,
0x80,0x40,0xC0,0xC0,0x40,0x84,0x40,0x84,                // -3-
0x40,0x84,0xC0,0xFF,0x80,0x7B,0x00,0x00,
0x00,0x0C,0x00,0x0E,0x00,0x0B,0x80,0x89,                // -4-
0xC0,0xFF,0xC0,0xFF,0x00,0x88,0x00,0x00,
0xC0,0x47,0xC0,0xC7,0x40,0x84,0x40,0x84,                // -5-
0x40,0x8C,0x40,0xFC,0x40,0x78,0x00,0x00,
0x00,0x7F,0x80,0xFF,0xC0,0x84,0x40,0x84,                // -6-
0x40,0x84,0x00,0xFC,0x00,0x78,0x00,0x00,
0xC0,0x00,0xC0,0x00,0x40,0xF0,0x40,0xF8,                // -7-
0x40,0x0C,0xC0,0x07,0xC0,0x03,0x00,0x00,
0x80,0x7B,0xC0,0xFF,0x40,0x84,0x40,0x84,                // -8-
0x80,0x03,0xC0,0x87,0x40,0x84,0x40,0x84,                // -9-
0x40,0xC4,0xC0,0x7F,0x80,0x3F,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x63,                // -:-
0x00,0x63,0x00,0x00,0x00,0x00,0x00,0x00,
uchar code NUM2[]=
                  0x00,0x00,0x7f,0x80,0xff,0xc0,0x82,0x40,                // -0-
                  0x8c,0x40,0x90,0x40,0xff,0xc0,0x7f,0x80,
                  0x00,0x00,0x00,0x00,0x20,0x40,0x60,0x40,                // -1-
                  0xff,0xc0,0xff,0xc0,0x00,0x40,0x00,0x40,
                  0x00,0x00,0x41,0xc0,0xc3,0xc0,0x86,0x40,                // -2-
                  0x8c,0x40,0x98,0x40,0xf0,0xc0,0x60,0xc0,
                  0x00,0x00,0x40,0x80,0xc0,0xc0,0x88,0x40,                // -3-
                  0x88,0x40,0x88,0x40,0xff,0xc0,0x77,0x80,
                  0x00,0x00,0x0c,0x00,0x1c,0x00,0x34,0x00,                // -4-
                  0x64,0x40,0xff,0xc0,0xff,0xc0,0x04,0x40,
                  0x00,0x00,0xf8,0x80,0xf8,0xc0,0x88,0x40,                // -5-
                  0x88,0x40,0x8c,0x40,0x8f,0xc0,0x87,0x80,
                  0x00,0x00,0x3f,0x80,0x7f,0xc0,0xc8,0x40,                // -6-
                  0x88,0x40,0x88,0x40,0x0f,0xc0,0x07,0x80,
                  0x00,0x00,0xc0,0x00,0xc0,0x00,0x83,0xc0,                // -7-
                  0x87,0xc0,0x8c,0x00,0xf8,0x00,0xf0,0x00,
                  0x00,0x00,0x77,0x80,0xff,0xc0,0x88,0x40,                // -8-
                  0x00,0x00,0x70,0x00,0xf8,0x40,0x88,0x40,                // -9-
                  0x88,0x40,0x88,0xc0,0xff,0x80,0x7f,0x00,
                  0x00,0x00,0x00,0xc0,0x01,0x80,0x03,0x00,                // -/-
                  0x06,0x00,0x0c,0x00,0x18,0x00,0x30,0x00,
unit disp1,disp2,key1,key2;
unit ii,jj;
unit i,sw,xz;
void Delay(unit ms){
                ms=ms*3;
                while(--ms);
void num_led(int kk, int tt)
int jj;
for(jj=0;jj<8;jj++){
                gate11=key1; gate12=key2;
                P2=~NUM1[kk+jj*2];P1=~NUM1[kk+1+jj*2];
                Delay(20);
                P1=0xff;P2=0xff;
                gate11=key2; gate12=key1;
                P2=~NUM2[tt+15-jj*2];P1=~NUM2[tt+14-jj*2];
                Delay(20);
                P1=0xff;P2=0xff;
void display_clock(void)
                key1=!key1;key2=!key2;
                disp1=BUFFER[3]/10;disp2=BUFFER[4]-(BUFFER[4]/10)*10;
                ii=disp1*16;jj=disp2*16;
                num_led(ii,jj);
                P2=0xff;P1=0xff;Delay(60);
                disp1=BUFFER[3]-disp1*10;disp2=BUFFER[4]/10;
                num_led(ii,jj);
                ii=160;jj=160;
                num_led(ii,jj);
                disp1=BUFFER[2]/10;disp2=BUFFER[5]-(BUFFER[5]/10)*10;
                num_led(ii,jj);
                disp1=BUFFER[2]-disp1*10;disp2=BUFFER[5]/10;
                num_led(ii,jj);
                ii=160;jj=160;
                num_led(ii,jj);
                disp1=BUFFER[1]/10;disp2=BUFFER[6]-(BUFFER[6]/10)*10;
                num_led(ii,jj);
                disp1=BUFFER[1]-disp1*10;disp2=BUFFER[6]/10;
                num_led(ii,jj);
void timer0(void)                interrupt 1 using 1
                TMOD=0x11;
                TH0=-(5000/256);
                TL0=-(5000%256);
                TR0=1;
                BUFFER[0]=BUFFER[0]+1;
                if (BUFFER[6]%4==0) M[1]=M[1]+1;
                if (BUFFER[0]>201+xz){
                  BUFFER[0]=0;
                  BUFFER[1]=BUFFER[1]+1;
if (BUFFER[1]==60){
                 BUFFER[1]=0;
                 BUFFER[2]=BUFFER[2]+1;
                 if (BUFFER[2]==60){
                BUFFER[2]=0;
                BUFFER[3]=BUFFER[3]+1;
                if (BUFFER[3]==24){
                  BUFFER[3]=0;
                        BUFFER[4]=BUFFER[4]+1;
                        if (BUFFER[4]>M[BUFFER[5]-1]){
                          BUFFER[4]=1;
                          BUFFER[5]=BUFFER[5]+1;
                          if (BUFFER[5]>12){
                            BUFFER[5]=1;
                            BUFFER[6]=BUFFER[6]+1;
                            if(BUFFER[6]>99) {
                  BUFFER[6]=0;
                              M[1]=M[1]-1;
void intersvr0(void)                interrupt 0
sw=1;
void main(void)
                 xz=8;
                 key1=1;key2=0;
                 EA=1;
                 IT0=1;EX0=1;
                 IT1=1;ET0=1;
                 TMOD=0x11;
                 TH0=-5000/256; TL0=-5000%256;
                 TR0=1;
for(;;){
                 Delay(10);
                 if(sw==1) {display_clock();sw=0;}
1098
至上芯片
82
老外做的7个LED的旋转电子钟
四。运行效果
  从开机,调整到最后完成。
1098
至上芯片
83
老外做的7个LED的旋转电子钟
调时状态
1098
至上芯片
84
老外做的7个LED的旋转电子钟
正常运行状态
85
我也来QQ122135996
龙章浒
广东省东莞市樟木头镇金河工业区金岭路68号  万码
邮编:523628
mob:13392742788
82
86
我很有兴趣
我很相做,请联系我,QQ78150656  wuzhiwen2@yahoo.com.cn
87
ding dingd ing ding ding
88
大家好呀,
我也想加入呀,可惜不懂编程呀
89
pic我比较熟悉,玩玩
98
90
太漂亮了 我也想做啊
98
91
能发块电路板来吗 我就是那个有点问题 自己做的不好啊
92
93
meilirichu7889@163.com
QQ:542650073
交流一下!!!
1098
至上芯片
94
回复 94楼 的帖子
我觉的的大家应该多写些制作过程中的心得体会的东西吧,资料都给大家递完了啊
95
我也想做
各位兄弟好;我是个新手我对这个很感兴趣,希望能得到大家的指点.QQ117466252   gzrjxsf@163.com
96
回复 95楼 的帖子
对于好像给的下在线电路板不太明白,能给明示哈嘛?
97
我是新手~~对这个东西很感兴趣~~~有空希望能交流交流!QQ:76092703
98
应该不难做,结构搞好的话就基本上没什么问题了
99
我也算一个的了
我也算上一个的了
有什么的好玩的都玩玩了
278150697QQ
216
老外真会做这个嘛!!
