2136|2
2721
【NUCLEO-F412ZG】开箱 [复制链接]
今天收到了NUCLEO-F412ZG,高兴
开箱,和STM32L432包装比,虽然都是M4,秒杀
拿出来比
正面照,引脚双排列
反面照
NUCLEO-F412ZG是ST公司推出的一款针对STM32F4系列设计的Cortex-M4开发板,具有 mbed 功能,支持Arduino。同时还提供 ST Morpho 扩展排针,可连接微控制器的所有周边外设。开发板基于STM32F412ZG设计,开发板还集成了ST-LINK/V2仿真下载器(但仅对外提供SWD接口),免除您另外采购仿真器或下载器的麻烦。并且具备Arduino接口,可接入 Arduino 巨大生态系统的各种 Shield 扩展板,让您能够轻松快速增加特殊功能。ST提供丰富的示例程序,让您更快速的入门STM32F4单片机。
F412,首款125摄氏度芯片,给力
官网介绍
The STM32 Nucleo-144 board provides an affordable and flexible way for users to try out new concepts and build prototypes with the STM32 microcontroller, choosing from the various combinations of performance, power consumption and features. The ST Zio connector, which is an extension of Arduino™ Uno V3, provides access to more peripherals and ST morpho headers make it easy to expand the functionality of the Nucleo open development platform with a wide choice of specialized shields. The STM32 Nucleo-144 board does not require any separate probe, as it integrates the ST-LINK/V2-1 debugger/programmer and it comes with the STM32 comprehensive software HAL library, together with various packaged software examples, as well as a direct access to the ARM®mbed™online resources at http://mbed.org.
Key Features
  • STM32 microcontroller in LQFP144 package
  • Two types of extension resources:
    • ST Zio connector including: support for Arduino Uno V3 connectivity (A0 to A5, D0 to D15) and additional signals exposing a wide range of peripherals
    • ST morpho extension pin header footprints for full access to all STM32 I/Os
  • ARM® mbed -enabled (see http://mbed.org)
  • On-board ST-LINK/V2-1 debugger/programmer with SWD connector:
    • Selection-mode switch to use the kit as a standalone ST-LINK/V2-1
    • USB re-enumeration capability. Three different interfaces supported on USB: virtual COM port, mass storage, debug port
  • Flexible board power supply:
    • 5 V from ST-LINK/V2-1 USB VBUS
    • External power sources: 3.3 V and 7 - 12 V on ST Zio or ST morpho connectors, 5 V on ST morpho connector
  • USB OTG or full-speed device with Micro-AB connector (depending on STM32 support)
  • IEEE-802.3-2002 compliant Ethernet connector (depending on STM32 support)
  • Three user LEDs
  • Two push-buttons: USER and RESET
  • LSE crystal:
    • 32.768 KHz crystal oscillator
  • Comprehensive free software HAL library including a variety of software examples
  • Support of wide choice of Integrated Development Environments (IDEs) including IAR , Keil® , GCC-based IDEs, ARM® mbed
此帖出自stm32/stm8论坛
nucleo系列一般都没有屏 功能比较简答 discovery系列有的是带lcm和TP的 评估板的功能最为强大  详情 回复 发表于 2016-11-26 11:32
2721
要是有个屏就好了
此帖出自stm32/stm8论坛
165
此帖出自stm32/stm8论坛
个人签名好好学习,天天向上
