我自己板子上485模块接的是usart1,PB6与PB7脚,我仿照原子开发板的485通讯例程,把串口2改成了串口1,和电脑可以通讯,但发送五个数据电脑只接受到两个,而且两个都是错的,接收也不行,我仔细看了配置应该没什么问题,这是为什么?哪里可能有问题?搞了两天了。愁死了。我的485控制脚是PB5,低电平为发送,高电平为接收。
//初始化IO 串口1
//bound:波特率
void RS485_Init(u32 bound)
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE); //使能GPIOB时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//使能USART1时钟
//串口1引脚复用映射
GPIO_PinAFConfig(GPIOB,GPIO_PinSource6,GPIO_AF_USART1); //GPIOB6复用为USART1
GPIO_PinAFConfig(GPIOB,GPIO_PinSource7,GPIO_AF_USART1); //GPIOB7复用为USART1
//USART1端口配置
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7; //GPIOA6与GPIOA7
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //速度50MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PA9,PA10
//PB5推挽输出,485模式控制
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //GPIOB5
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz; //速度100MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽输出
GPIO_Init(GPIOB,&GPIO_InitStructure); //初始化PB5
//USART1 初始化设置
USART_InitStructure.USART_BaudRate = bound;//波特率设置
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式
USART_Init(USART1, &USART_InitStructure); //初始化串口1
USART_Cmd(USART1, ENABLE); //使能串口1
//USART_ClearFlag(USART1, USART_FLAG_TC);
#if EN_USART1_RX
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启接受中断
//Usart1 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//抢占优先级3
NVIC_InitStructure.NVIC_IRQChannelSubPriority =3; //子优先级3
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器、
#endif
RS485_TX_EN=1; //默认为接收模式
//RS485发送len个字节.
//buf:发送区首地址
//len:发送的字节数(为了和本代码的接收匹配,这里建议不要超过64个字节)
void RS485_Send_Data(u8 *buf,u8 len)
u8 t;
RS485_TX_EN=0; //设置为发送模式
for(t=0;t
while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==RESET){}//等待发送结束
USART_SendData(USART1,buf[t]); //发送数据
while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==RESET); //等待发送结束
RS485_RX_CNT=0;
RS485_TX_EN=1; //设置为接收模式
