8863|2
刚想用ccs试一下example project 却弹出来这个 [复制链接]
刚想用ccs试一下example project 却弹出来这个:IcePick_C_0: Error initializing emulator: (Error -2083 @ 0x0) Unable to communicate with the debug probe. Confirm debug probe configuration and connections, reset the debug probe, and retry the operation. (Emulation package 6.0.407.3)
求问怎么办啊
仿真器选对了没   详情 回复 发表于 2016-9-26 11:25
2700
仿真器选对了没
果真选错了 现在改成xds100v2 多谢!
