3952|1
1310
"删繁就简" 像PLC一样的上升沿 [复制链接]
嘿嘿,我来水一把,说错了莫怪!
在嵌入式控制器上,用C语言来实现像PLC一样的上升沿/下降沿检测
volatile  unsigned char pedge_flag;
volatile  unsigned char nedge_flag;
int main (void)
unsigned char pedge_temp = 0;
unsigned char nedge_temp = 0;
unsigned char input_signal;
add  user's code
pedge_flag = 0;
nedge_flag = 0;
while(1)
  input_signal = input_signal_read();//读取当前输入状态
  if( input_signal && (!pedge_temp) )//检查当前状态与上一周期状态
   pedge_flag = 1;//上升沿置位
  else
   pedge_flag = 0;//上升沿复位
  pedge_temp = input_signal;//当前输入状态并存储
  if( (!input_signal) && nedge_temp )
   nedge_flag = 1;//下降沿置位
  else
   nedge_flag = 0;//下降沿复位
    nedge_temp = input_signal;//当前输入状态存储
  add user's code
  //delay(1);
此帖出自编程基础论坛
其实就是记录状态的变化啊,由1->0   由0->1   详情 回复 发表于 2016-10-20 12:28
RTEMS
466
此帖出自编程基础论坛
