FTTH皮线光缆|1芯皮线光缆|2芯皮线光缆|室内蝶形光缆|室外蝶形光缆|FTTH蝶形引入光缆|FTTH蝶形光缆|TAC隐形光缆|皮线光缆|FTTH自承式皮线光缆|FTTH室内皮线光缆|蝶形引入光缆生产基地!共为通信FTTH 自承式蝶形引入光缆(GJYXFCH、GJYXFCV、GJYXCH、GJYXCV皮线光缆、GYTA、GYTS、GYXTW室外光缆!) 1.特种耐弯光纤,提供更大的带宽,增强网络传输特性;
Secial low-bend-sensitivity fiber provides high bandwidth and excellent communication transmission property 2.两根平行FRP使光缆具有良好的抗压性能,保护光纤;
Two parallel FRP strength members ensure good performance of crush resistance to protect the fiber 3.钢丝附加加强元件,使光缆具有良好的抗拉性能;
Steel wire as the additional strength member ensures good performance of tensile strength 4.光缆结构简单,重量轻,实用性强;
Simple structure, light weight and high practicability 5.独特的凹槽设计,易剥离,方便接续,简化安装和维护;
Novel flute design, easily strip and splice, simplify the installation and maintenance 6.低烟无卤阻燃护套,环保.
Low smoke, zero halogen and flame retardant sheath 光学特性Optical Characteristics 光纤类型 | 衰减 | 满注入带宽(OFL) | 有效模式 带宽 | 10 G以太网链路长度 SX | 最小弯曲半径 | 条件 | 1310/1550nm | 850/1300nm | 850/1300nm | 850nm | 850nm | / | 典型值 | 最大值 | 典型值 | 最大值 | 单位 | dB/km | dB/km | dB/km | dB/km | MHZ.km | MHZ.km | m | mm | G657A1 | 0.36/0.22 | 0.5/0.4 | --- | --- | --- | --- | --- | 10 | G657A2 | 0.36/0.22 | 0.5/0.4 | --- | --- | --- | --- | --- | 7.5 | OM3 | --- | --- | 3.0/1.0 | 3.5/1.5 | ≥1500/500 | ≥2000 | ≤300 | 30 | OM4 | --- | --- | 3.0/1.0 | 3.5/1.5 | ≥3500/500 | ≥4700 | ≤550 | 30 |
接入网用蝶形引入光缆系列 Bow-type drop cable Series Cable描述System Description 随着通讯业务飞速发展,人们对通讯网络的传输和交换能力不断提出要求,传统的接入方式已不能满足带宽的需求。从干网到小区、家庭间的最后一公里接入网阶段,铜线带宽只能达到1兆到2兆,但使用光纤,带宽可轻易达每秒100兆之多。光纤到户(FTTH), 直接使用光纤,将通讯线路从局端直接接入用户家庭,在带宽方面具有无与伦比的优势,可实现多种业务的综合接入。作为宽带接入的最终解决方案,随着技术和市场条件日益成熟,FTTH将成为通信的未来。
With the rapid development of communication service, the people have an increasing demand on the communication transmission and exchange capacity. Traditional copper-based access solution will not comply with the request of high bandwidth any longer. In the last mile access, from the backbone network to the village or the home, the copper wire bandwidth only can reach 1M to 2M, but the optical fiber bandwidth may easily reach 100M. Fiber to the home (FTTH), using the optical fiber, directly connects the communication line from the LAN to the user. Due to its excellent advantage in bandwidth, FTTH network can support full communication services. With the development of technology and market, FTTH network is deemed to be the "access technology of the future".技术优势Technical 支持宽带、有限电视和电话三网合一;
Support the internet, CATV and telephone;
高带宽,轻易可达100兆;
High bandwidth, easily reach 100M;
网络结构灵活,降低运营建设和维护成本,便于管理;
Flexible network construction, reduce the cost of installation and maintenance, convenient for network management;
设备端口利用率高,易于接入用户的增加和逐步扩容;
Usable equipment ports, easy to increase the users and expand accommodates gradually;
支持将来更多网络增值业务的接入。
Support more network increment service in future.
接入网用蝶形引入光缆系列产品由光通信单元、加强件和外护套组成;其中,加强件设置在光通信单元两侧,外护套包在光通信单元和加强件外部。
a). 光通信单元有光纤、紧套纤、光纤带等形式,灵活可选,可根据实际应用需要,设置一根或平行数根; br />b).加强件有金属与非金属之分,既可在光通信单元两侧各设置一根,也可纵向再附加设置;
c). 外护套采用黑色或彩色低烟无卤材料,可满足IEC332-1标准。
bow-type drop series cable consists of optical fiber unit, strength member and outer sheath, in which the strength members are placed at the two sides of the optical fiber unit and all of them are finally covered with the outer sheath.
a).The optical fiber unit shall be fiber, tight buffer fiber or fiber ribbon. One or above fiber count is available upon request.
b).The strength member shall be metallic or non-metallic. They are applied at the two sides of the optical fibers respectively, and another one or more might be added longitudinally,
c).The sheath is made of black or color LSZH material, which complies with standard IEC332-1.品应用Application 接入网,光纤到户
Access network, fiber to the home
很多人对室内外光缆光纤的规格都比较陌生,所以提供以下规格给您,如果有用到室内外光缆光纤可以联系我们; 习惯叫法 | 主要型式 | 全 称 | 敷设方式及用途 | 中 心 管 式 光 缆 | GYXTY | 室外通信用、金属加强构件、中心管、全填充、夹带加强件聚乙烯护套光缆 | 架空、农话 | GYXTS | 室外通信用、金属加强构件、中心管、全填充、钢-聚乙烯粘结护套光缆 | 架空、农话 | GYXTW | 室外通信用、金属加强构件、中心管、全填充、夹带平行钢丝的钢-聚乙烯粘结护套光缆 | 架空、管道、农话 | 层 绞 式 光 缆 | GYTA | 室外通信用、金属加强构件、松套层绞、全填充、铝-聚乙烯粘结护套光缆 | 架空、管道 | GYTS | 室外通信用、金属加强构件、松套层绞、全填充、钢-聚乙烯粘结护套光缆 | 架空、管道、 也可直埋 | GYTA53 | 室外通信用、金属加强构件、松套层绞、全填充、铝-聚乙烯粘结护套、皱纹钢带铠装聚乙烯外护层光缆 | 直埋 | GYTY53 | 室外通信用、金属加强构件、松套层绞、全填充、聚乙烯护套、皱纹钢带铠装聚乙烯外护层光缆 | 直埋 | GYTA33 | 室外通信用、金属加强构件、松套层绞、全填充、铝-聚乙烯粘结护套、单细钢丝铠装聚乙烯外护层光缆 | 爬坡直埋 | 层 绞 式 光 缆 | GYTY53+33 | 室外通信用、金属加强构件、松套层绞、全填充、聚乙烯护套、皱纹钢铠装聚乙烯套+单细钢丝铠装聚乙烯外护层光缆 | 直埋、水底 | GYTY53+333 | 室外通信用、金属加强构件、松套层绞、全填充、聚乙烯护套、皱纹钢带铠装聚乙烯套+双细钢丝铠装聚乙烯外护层光缆 | 直埋、水底 | 习惯叫法 | 主要型式 | 全 称 | 敷设方式及用途 | 光 纤 带 光 缆 | GYDXTW | 室外通信用、金属加强构件、光纤带中心管、全填充、夹带平行钢丝的钢-聚乙烯粘结护层光缆 | 架空、管道、 接入网 | GYDTY | 室外通信用、金属加强构件、光纤带、松套层绞、全填充聚乙烯护层光缆 | 架空、管道、 接入网 | GYDTY53 | 室外通信用、金属加强构件、光纤带松套层绞、全填充、聚乙烯护套、皱纹钢带铠装聚乙烯外护层光缆 | 直埋、接入网 | GYDGTZY | 室外通信用、非金属加强构件、光纤带、骨架、全填充、钢-阻燃聚烯烃粘结护层光缆 | 架空、管道、 接入网 | 非 金 属 光 缆 | GYFTY | 室外通信用、非金属加强构件、松套层绞、全填充、聚乙烯护层光缆 | 架空、 高压电感应区域 | GYFTY05 | 室外通信用、非金属加强件、松套层绞、全填充、聚乙烯护套、无铠装、聚乙烯保护层光缆 | 架空、槽道、 高压感应区域 | GYFTY03 | 室外通信用、非金属加强构件、松套层绞、全填充、无铠装、聚乙烯套光缆 | 架空、槽道、 高压感应区域 | GYFTCY | 室外通信用、非金属加强件、松套层绞、全填充、自承式聚乙烯护层光缆 | 自承悬挂于高压电塔上 | 电力光缆 | GYTC8Y | 室外通信用、金属加强构件、松套层绞、全填充、聚乙烯套8字形自承式光缆 | 自承悬挂于杆塔上 | 阻燃光缆 | GYTZS | 室外通信用、金属加强构件、松套层绞、全填充、钢-阻燃聚烯烃粘结护层光缆 | 架空、管道、 无卤阻燃场合 | 防 蚁 光 缆 | GYTA04 | 室外通信用、金属加强构件、松套层绞、全填充、聚乙烯护套、无铠装、聚乙烯护套加尼龙外护层光缆 | 管道、防蚁场合 | GYTY54 | 室外通信用、金属加强构件、松套层绞、全填充、聚乙烯护套、皱纹钢带铠装、聚乙烯套加尼龙外护层光缆 | 直埋、防蚁场合 | 室 内 光 缆 | GJFJV | 室外通信用、非金属加强件、紧套光纤、聚氯乙烯护层光缆 | 室内尾纤或跳线 | GJFJZY | 室外通信用、非金属加强件、紧套光纤、阻燃、聚烯烃护层光缆 | 室内布线或尾缆 | GJFDBZY | 室外通信用、非金属加强件、光纤带、扁平型、阻燃聚烯烃护层光缆 | 室内尾缆或跳线
共为通信为适应三网融合、FTTx的推广,共为通信推出从局端一直到用户桌面的FTTX光配线网络解决方案。产品主要包括光纤配线架、光缆交接箱,光缆分纤箱,分光分纤箱,光缆分线盒,光缆接头盒,光缆终端盒,冷接子,快速连接器,光纤跳线,配线光缆、皮线光缆、市内布线光缆、无源器件、线路辅助设施等。
户外工程介于局端机房和用户大楼之间,在FTTB/FTTH中,用于连接从局端引出的馈线光缆与用户大楼引入的分配光缆。在FTTC中,用于连接从局端引出的光缆与用户电缆。户外工程涉及光缆交接箱和光缆配线箱、光缆接头盒、宽度户外机柜等产品
共为通信FTTX布线应有尽有、质量保证!随时欢迎您前来咨询!!!
宁波共为通信科技有限公司一贯坚持“企业以人为本,人以责任为先” 的发展理念,高标准、零缺陷、顾客的期望是我们追求的目标。完善自我、超越自我、为客户创造更多价值是企业宗旨,创新、团结、敬业、守信是公司精神,用“心”突破传统,用“光”引领未来,公司将锲而不舍、持之以恒地走创新发展之路,与社会各界朋友及客户、合作伙伴共同建设“宽带中国”的美好明天! (以下报价不含税(含税加10点)含运费)以下报价没有备注的均为空箱价格、图片只做参考! 本公司产品可以按客户要求订制(logo免费印刷) 产品图片 | 产品名称 | 产品规格 | 产品单价 | 备注 | GPX-GF(PC光纤分光箱) | | GPX-GF8 | 空箱:25元 满配:75元 | PC/ABS合金料 | | 1分16光分路器箱 | GPX-GF16 | 空箱:40元 满配:140元 | PC/ABS合金料 | | 1分16光分路器箱 | GPX-GF16C | 空箱:45元 空箱:145元 | PC/ABS合金料 | | 1分16光分路器箱 | GPX-GF16B | 空箱:38元 满配:138元 | PC/ABS合金料 | | 1分16光分路器箱 | GPX-GF16A | 空箱:45元 满配:145元 | PC/ABS合金料 | | 1分32光分路器箱 | GPX-GF32 | 空箱:55元 满配:255元 | PC/ABS合金料 | | 2芯光纤分纤箱 | GPX-GF-2 | 空箱:22元 | PC/ABS合金料 | | 4芯光纤分纤箱 | GPX-GF-4 | 空箱:23元 | PC/ABS合金料 | | 12芯光纤分纤箱 | GPX-GF-12 | 空箱:25元 满配:61元 | PC/ABS合金料 | | 24芯光纤分纤箱 | GPX-GF-24 | 空箱:40元 满配:105元 | PC/ABS合金料 | | 24芯分纤箱 | GPX-GF-24A | 空箱:45元 满配:110元 | PC/ABS合金料 | | 24芯分纤箱 | GPX-GF-24C | 空箱:45元 满配:115元 | PC/ABS合金料 | | 36芯分纤箱 | GPX-GF36 | 空箱:55元 满配:150元 | PC/ABS合金料 | | 48芯分纤箱 | GPX-GF48 | 空箱:55元 满配:185元 | PC/ABS合金料 | GPX6-01型(钣金室外光纤配线箱) | | 12芯配线箱 | GPX6-01 | 空箱:75元 满配:110元 | 1.2板材 (冷轧板) | | 24芯配线箱 | GPX6-01 | 空箱:75元 满配:145元 | 1.2板材 (冷轧板) | | 48芯配线箱 | GPX6-01 | 空箱:95元 满配:225元 | 1.2板材 (冷轧板) | | 48芯配线箱 | GPX6-01 | 空箱:95元 满配:225元 | 1.2板材 (冷轧板) | | 72芯配线箱 | GPX6-01 | 空箱:130元 满配:320元 | 1.2板材 (冷轧板) | | 96芯配线箱 | GPX6-01 | 空箱:165元 满配:420元 | 1.2板材 (冷轧板) | | 144芯配线箱 | GPX6-01 | 空箱:210元 满配:590元 | 1.2板材 (冷轧板) | GPX-02(光分路器箱/光纤楼箱)SMC | | 8芯光分路器箱 | GPX02-8 | 空箱:55元 满配:100元 | SMC(玻璃钢) | | 12芯光纤楼道箱 | GPX02-12 | 空箱:65元 满配:98元 | SMC(玻璃钢) | | 1分16光分路器箱 | GPX02-16E | 空箱:95元 满配:195元 | SMC(玻璃钢) | | 1分16光分路器箱 | GPX02-16 | 空箱:75元 满配:175元 | SMC(玻璃钢) | | 24芯光纤分纤箱 | GPX02-24 | 空箱:75元 满配:140元 | SMC(玻璃钢) | | 1分32光分路器箱 | GPX02-32E | 空箱:105元 满配:305元 | SMC(玻璃钢) | | 1分32光分路器箱 | GPX02-32 | 空箱:105元 满配:305元 | SMC(玻璃钢) | | 48芯光纤分纤箱 | GPX02-48 | 空箱:105元 满配:235元 | SMC(玻璃钢) | | 1分64光分路器箱 | GPX02-64E | 空箱:140元 满配:540元 | SMC(玻璃钢) | | 72芯光纤分纤箱 | GPX02-72 | 空箱:140元 满配:331元 | SMC(玻璃钢) | GPX03-VIII(三网融合箱) | | 24芯三网合一箱 | GPX03-VIII24 | 空箱:185元 | 1.2板材 (冷轧板) | | 48芯三网合一箱 | GPX03-VIII 48 | 空箱:185元 | 1.2板材 (冷轧板) | | 72芯三网合一箱 | GPX03-VIII 72 | 空箱:195元 | 1.2板材 (冷轧板) | | 96芯三网合一箱 | GPX03-VIII 96 | 空箱:225元 | 1.2板材 (冷轧板) | | 144芯三网合一箱 | GPX03-VIII 144 | 空箱:225元 | 1.2板材 (冷轧板) | | 三网合一直熔箱 | GPX03-VII | 空箱:185元 | 1.2板材 (冷轧板) | | 四网合一箱 | GPX03-VIIIA | 空箱:250元 | 1.2板材 (冷轧板) | GPX04(钣金光分路器箱) | | 1分16光分路器箱 | GPX04-16A | 满配:95元 满配:185元 | 1.2板材 (冷轧板) | | 1分32光分路器箱 | GPX04-32A | 空箱:110元 满配:290元 | 1.2板材 (冷轧板) | | 1分64光分路器箱 | GPX04-64A | 空箱:150元 满配:510元 | 1.2板材 (冷轧板) | GXF05(光缆交接箱) | | 288芯/432芯 三网融合光交箱 | GXF05-VIII288 GXF05-VIII432 | 空箱:2100元 空箱:2100元 | SMC(玻璃钢) | | 576三网融合光交箱 | GXF05-VIII576A | 空箱:2200元 | SMC玻璃钢 | | 576芯/648芯/720芯864芯 三网融合光交箱 | GXF05-VIII576 GXF05-VIII648 GXF05-VIII720 GXF05-VIII864 | 空箱:2800元 空箱:2800元 空箱:2800元 空箱:2800元 | SMC(玻璃钢) | | 96芯免跳纤/传统光缆交接箱 | GXF05-I96 | 空箱:580元 | SMC(玻璃钢) | | 144芯 免跳纤/传统 光缆交接箱 | GXF05-I144 | 空箱:680元 | SMC(玻璃钢) | | 288芯 免跳纤/传统 光缆交接箱 | GXF05-I288 | 空箱:1650元 | SMC(玻璃钢) | | 576芯 免跳纤/传统 光缆交接箱 | GXF05-VI576 | 空箱:2250元 | SMC(玻璃钢) | | 576芯 传统交接箱 | GXF05-VI576A | 空箱:4800元 | SMC(玻璃钢) | | 1152芯传统 光缆交接箱 | GXF05-VI1152 | 空箱:6500元 | SMC(玻璃钢) | | 144芯不锈钢 光缆交接箱 | GXF05-VII144 | 201板材:1500元/台(空箱) | 不锈钢 | 304板材:2500元/台(空箱) | | 288芯不锈钢 光缆交接箱 | GXF05-VII288 | 201板材:2650元/台(空箱) | 不锈钢 | 304板材:2950元/台(空箱) | | 576芯不锈钢 光缆交接箱 | GXF05-VII576 | 201板材:3700元/台(空箱) | 不锈钢 | 304板材:4200元/台(空箱) | | 1152芯不锈钢 光缆交接箱 | GXF05-VII1152 | 201板材:4800元/台(空箱) | 不锈钢 | 304板材:5500元/台(空箱) | GPX2000-VIII(三网融合光纤配线柜) | | 288芯/576芯/720芯 三网融合光纤配线柜 | GPX97-III | 1600元/台
1600元/台1600元/台 (空箱) | 1.2钣金 (冷轧板) | | 720芯三网融合光纤配线架 | GPX2000-IIIB | 2550元/台 (空箱) | 1.2钣金 (冷轧板) | | 1440芯三网融合光纤配线架 | GPX2000-VIII | 2550元/台 (空箱) | 1.2钣金 (冷轧板) | | 2160芯三网融合光纤配线架 | GPX2000-IIIA | 2650元/台 (空箱) | 1.2钣金 (冷轧板) | GPX2000-VI(直插式光纤配线架) | | 288芯/576芯/720芯/792芯 光纤配线柜 | GPX2000-I
| 1350元/台 1350元/台 1350元/台 1350元/台 | 1.2钣金 (冷轧板) | | 288芯/576芯 | GPX2000-VI | 1650元/台 | 1.2钣金(冷轧板) | | 288芯/720芯光纤配线架 | CT-GPX09T | 1850元/台 | | | 1152芯/1200芯/1440芯光纤配线柜 | GPX2000-IV | 2550元/台 | 1.2钣金(冷轧板) | GPX2000-II光纤配线架 | | 288芯/576芯/720芯 光纤配线架 | GPX2000-II
| 1350元/台 | 1.2钣金 (冷轧板) | GPX2200VIIA(半封闭式光纤配线架) | | 288芯/576芯/720芯 光纤配线架 | GPX2200-VII
| 1950元/台 1950元/台 1950元/台 | 1.2钣金 (冷轧板) | GPX81E-VII型(OMDF光总配线架) | | 576芯、648芯、720芯、792芯 光总配线架 | GPX81A-576 GPX81A-648 GPX81A-720 GPX81A-792 | 3100元/台 3100元/台 3100元/台 3100元/台 | 1.5钣金 (冷轧板) | GPX2000-81E型(OMDF光纤总配线架) | | 576芯、648芯、720芯、792芯 | GPX2200-81E | 2250元/台 2550元/台 2550元/台 2550元/台 | 1.5钣金 (冷轧板) | GPX167G-VIIIJ型(OMDF光纤总配线架) | | 576芯、648芯、720芯 | GPX167G-VIIIJ | 2350元/台 2350元/台 2350元/台 | 1.5钣金 (冷轧板) |
GXT19型(ODF单元箱) | | 12芯 | GXT19-12 | 75元/台 | 1.2钣金(冷轧板) | | 24芯 | GXT19-24 | 85元/台 | 1.2钣金 (冷轧板) | | 48芯 | GXT19-48 | 95元/台 | 1.2钣金 (冷轧板) | | 72芯 | GXT19-72 | 110元/台 | 1.2钣金 (冷轧板) | | 96芯 | GXT19-96 | 135元/台 | 1.2钣金 (冷轧板) | | 144芯 | GXT19-144 | 155元/台 | 1.2钣金(冷轧板) | GPX19J型(机架式光纤盒) | | 12口光纤盒 | GPX19J-12 | 45元/台 | 1.2钣金 (冷轧板) | | 24口光纤盒 | GPX19J-24 | 45元/台 | 1.2钣金 (冷轧板) | | 48口光纤盒 | GPX19J-48 | 75台 | 1.2钣金 (冷轧板) | GPX19C型(抽拉式光纤盒) | | 12口光纤盒 | GPX19C-12 | 85元/台 | 1.2钣金 (冷轧板) | | 24口光纤盒 | GPX19C-24 | 115元/台 | 1.2钣金 (冷轧板) | | 48口光纤盒 | GPX19C-48 | 250元/台 | 1.2钣金 (冷轧板) | TW-TP(一体化托盘) | | 12芯一体化托盘 | TW-TP-V2.0 | 7元/个 | | | 12芯一体化托盘 | TW-TP-V3.0 | 7元/个 | | | 12芯一体化托盘 | TW-TP-12M | 7元/个 | | file:///C:/Users/ADMINI~1/AppData/Local/Temp/msohtmlclip1/01/clip_image158.jpg | 12芯一体化托盘 | TW-TP-12H | 7元/个 | | | 16芯一体化托盘 | TW-TP-16型 | 12元/个 | | | 32芯一体化托盘 | TW-TP-32型 | 18元/个 | | | 12芯一体化托盘 | TW-TP-12S | 15元/个 | | | 12芯一体化托盘 | TW-TP-12T | 9元/个 | | | 24芯一体化托盘 | TW-TP-24型 | 25元/个 | |
产品质量承诺
一、产品质量承诺:
1、产品的制造和检测均有质量记录和检测资料。
2、对产品性能的检测,我们诚请用户亲临对产品进行全过程、全性能检查,待产品被确认合格后再装箱发货。
二、产品价格承诺:
1、为了保证产品的高可靠性和先进性,系统的选材均选用国内或国际优质名牌产品。
2、在同等竞争条件下,我公司在不以降低产品技术性能、更改产品部件为代价的基础上,真诚以***优惠的价格提供给贵方。
三、交货期承诺:
1、产品交货期:尽量按用户要求,若有特殊要求,需提前完工的,我公司可特别组织生产、安装,力争满足用户需求。
四、售后服务承诺:
1、服务宗旨:快速、果断、准确、周到、彻底
2、服务目标:服务质量赢得用户满意
