* MSP430 CODE EXAMPLE DISCLAIMER
* MSP430 code examples are self-contained low-level programs that typically
* demonstrate a single peripheral function or device feature in a highly
* concise manner. For this the code may rely on the device's power-on default
* register values and settings such as the clock configuration and care must
* be taken when combining code from several examples to avoid potential side
* effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
* for an API functional library-approach to peripheral configuration.
* --/COPYRIGHT--*/
// MSP430F552x Demo - USCI_B0 I2C Master RX single bytes from MSP430 Slave
// Description: This demo connects two MSP430's via the I2C bus. The master
// reads from the slave. This is the MASTER CODE. The data from the slave
// transmitter begins at 0 and increments with each transfer. The received
// data is in R5 and is checked for validity. If the received data is
// incorrect, the CPU is trapped and the P1.0 LED will stay on. The USCI_B0
// RX interrupt is used to know when new data has been received.
// ACLK = n/a, MCLK = SMCLK = BRCLK = default DCO = ~1.045MHz
// ***to be used with "MSP430F55xx_uscib0_i2c_05.c" ***
// MSP430F5529 10k 10k MSP430F5529
// slave | | master
// -|XIN P3.0/UCB0SDA|<-|----+->|P3.0/UCB0SDA XIN|-
// | | | | | 32kHz
// -|XOUT | | | XOUT|-
// | P3.1/UCB0SCL|<-+------>|P3.1/UCB0SCL |
// | | | P1.0|--> LED
// Bhargavi Nisarga
// Texas Instruments Inc.
// April 2009
// Built with CCSv4 and IAR Embedded Workbench Version: 4.21
