3863|5
37
关于OpenPilot的问题1 [复制链接]
各位高手,小弟获得了OpenPilot的源代码,想安装开发工具。在源码目录下,运行“make all_sdk_install”命令,出现以下错误,请教其中的原因。谢谢!
NOTE        Use 'make all_sdk_distclean' to remove installation files
NOTE        Use 'make all_sdk_version' to check toolchain versions
NOTE        Add 'V=1' to make command line to diagnose make problems
NOTE        Add 'BATCH=1' to make command line to disable progress reporting during downloads
CLEAN       tools/gcc-arm-none-eabi-4_9-2014q4
VERIFY      downloads/gcc-arm-none-eabi-4_9-2014q4-20141203-linux.tar.bz2
make: *** [arm_sdk_install] 错误 2
两变量没设置 NOTE        Add 'V=1' to make command line to diagnose make problems NOTE        Add 'BATCH=1' to make command line to disable progress reporting during downloads 另,查证一下 gcc版本和sdk版本对不对得上  详情 回复 发表于 2016-7-8 10:13
61
不错,路过看看,学习一下
7815
56
裸片初长成(中级)
它都给你指示了,连命令都写出来了,真贴心
乖,照着做就行
强者为尊,弱者,死无葬身之地
7815
56
裸片初长成(中级)
两变量没设置
7815
56
裸片初长成(中级)
两变量没设置
强者为尊,弱者,死无葬身之地
37
谢谢辛昕,这2个变量该怎么设置呢?
