2219|2
HR202L 测试湿度,stm32 [复制链接]
请大家指正
uint8_t en_tnSRHCharge = 0;
uint8_t cnt_charge = 0;
uint16_t tn_discharge = 0;//s
uint32_t tn_charge  = 0;
uint16_t tn_srhwait = 0;
float res_hr;
uint32_t time_high = 0;
uint32_t time_test = 0;
//uint32_t com_res = 0;
uint32_t tn_refcharge = 0;
uint32_t tn_hrcharge = 0;
void  Humidity_tntest(void)
        //放电
        Set_SRH_Charge(0);
        Set_SRH_R_Charge(0);
        Set_SRH_IOtest(0);//output
        GPIO_ResetBits(SRH_Charge);//
        GPIO_ResetBits(SRH_R_Charge);//
        GPIO_ResetBits(SRH_IOtest);
        tn_discharge = 40;//延时10ms
        while(tn_discharge);
        //标准电阻充电
        Set_SRH_Charge(1);
        Set_SRH_IOtest(1);//比较器口
        en_tnSRHCharge = 1; //使能PWM,充电
        GPIO_SetBits(SRH_R_Charge);
        cnt_charge = 0;
        time_high = 0;
        tn_charge = 0;
        TIM_SetCounter(TIM1,0);
        while( !COMP_GetOutputLevel(COMP_Selection_COMP1));
        tn_charge =  TIM_GetCounter(TIM1);
        en_tnSRHCharge = 0;
        tn_refcharge = tn_charge;
        tn_charge = 0;
        //放电
        Set_SRH_Charge(0);
        //hr202l充电
        Set_SRH_Charge(0);
        Set_SRH_R_Charge(1);
        GPIO_SetBits(SRH_Charge);
        cnt_charge = 0x80;
        time_high = 0;
        tn_charge = 0;
        while( !COMP_GetOutputLevel(COMP_Selection_COMP1)) ;
        en_tnSRHCharge = 0;
        tn_hrcharge = tn_charge;
        tn_charge = 0;
        //计算电阻,10K电阻
        res_hr = 10 * 1000 * (float)tn_hrcharge / tn_refcharge;
        if(res_hr>99000)
        res_hr = 0.803*res_hr+5.298 ;
        res2humidity(res_hr);
void TIM2_IRQHandler(void)
        if(TIM_GetFlagStatus(TIM2, TIM_IT_Update))
                TIM_ClearFlag(TIM2, TIM_IT_Update);
                if(en_tnSRHCharge)
                        cnt_charge++;
                        if(cnt_charge & 0x80)
                                if(cnt_charge >= 0x86) //0x84
                                        cnt_charge = 0x80;
                                else if(cnt_charge >= 0x81)
                        else
                                if(cnt_charge == 0x01)
                                else if(cnt_charge == 0x06) //4
                                        cnt_charge = 0x00;
                if(tn_discharge)tn_discharge--;
此帖出自stm32/stm8论坛
不描述需求,不描述遇到的问题,不描述现象。让别人毫无根据的去猜测一切?  详情 回复 发表于 2016-6-30 20:16
3471
此帖出自stm32/stm8论坛
只是分享经验,看看你们使用hr202L有其他的方法没
此帖出自stm32/stm8论坛
