大致以CCS的官方例程做了一个UART输出的基本程序,可是不知道为什么输出端收到的不是0x00,0xFF,0xAA,0x55,这样一个我预先设定好的循环。用eaglecom看输出的循环是01 00 00 FF AA 55 05 00 这样一个,逐步分析的时候可以看见是string[i]的取值取了0、1、5这些的值,各位前辈能给我指点指点是为什么吗?
程序部分如下:
#include
int string2[4]={0x00,0xFF,0xAA,0x55};
char string1[8]={'1','2','3','4','5','6','7','8'};
char i;
char j = 0;
int main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P1DIR = 0xFF; // All P1.x outputs
P1OUT = 0; // All P1.x reset
P2DIR = 0xFF; // All P2.x outputs
P2OUT = 0; // All P2.x reset
P1SEL = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
P1SEL2 = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
P3DIR = 0xFF; // All P3.x outputs
P3OUT = 0; // All P3.x reset
UCA0CTL1 |= UCSSEL_1; // CLK = ACLK
UCA0BR0 = 0x03; // 32kHz/9600 = 3.41
UCA0BR1 = 0x00; //
UCA0MCTL = UCBRS1 + UCBRS0; // Modulation UCBRSx = 3
UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
_EINT();
for(;;)
if (i == sizeof string2)
i=0;
// __delay_cycles(50);
IE2 |= UCA0TXIE; // Enable USCI_A0 RX interrupt
// __bis_SR_register(LPM3_bits + GIE); // Enter LPM3, interrupts enabled
// USCI A0/B0 Transmit ISR
#if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
#elif defined(__GNUC__)
void __attribute__ ((interrupt(USCIAB0TX_VECTOR))) USCI0TX_ISR (void)
#else
#error Compiler not supported!
#endif
UCA0TXBUF = string2[i++]; // TX next character
// if (i == sizeof string2) // TX over?
IE2 &= ~UCA0TXIE; // Disable USCI_A0 TX interrupt
