4169|2
【上海】【安捷伦科技】【研发中心】【电子工程师】 [复制链接]
昨天的帖显示被删除?只好再发一遍。
简历请发至:eric_ge@agilent.com
hiring manager, not HR
Position: R&D Electrical Engineer
Job Description:
1. Create electronic structures to first prove the feasibility, and finally the practicality of the approach being followed to meet the design goals. Produce all documentation required for its fabrication by the service groups.
2. Theoretically analyze the system requirements and translate them into design spec. Carries out analysis and evaluations of successive version of hardware to ensure that fundamentals are fully understood, basic problems are solved and that the design is sufficiently robust to avoid future problems due to expected variations in component/environmental parameters.
3. Assists in integration, evaluation, modification of overall instrument / system. Provide tested functional hardware for same.
4. Ensures that all documentation is accomplished and in proper form including any important component specifications.
5. Demonstrated product development experience from circuit design (analog/digital), evaluation and manufacturing.
Internal Qualifications:
MUST:
1.       Master’s degree (or above) in electronic engineering or related scientific discipline or equivalent combination of education and experience.
2.       Strong verbal and written English communication skills.
3.       Strong interests and enthusiasm in electronic design. Solid and broad knowledge/experience on analog and/or digital circuit design in instrumentation.
4.       Demonstrate flexibility, independence and initiative to perform successfully in a rapidly changing environment.
5.       Demonstrate analytical problem solving skills.
6.       Demonstrate good interpersonal skill
WANT:
1.       Experience in high precision analog circuit design is a plus
2.       Experience in mechatronics design is a plus. Ex, motor control, flow control, thermal control…
3.       Experience in SoC design is a plus. Ex, Xilinx ZYNQ FPGA
此帖出自求职招聘论坛
葛爷是你吗?哈哈哈  详情 回复 发表于 2016-7-22 15:29
37
职位描述:
1。创建电子结构的第一个证明其可行性,最后的实用性被跟踪的方法来满足设计目标。生产所需的所有文档的制造服务团体。
2。从理论上分析了系统需求,把它们转换成设计规范。连续版本的硬件进行分析和评估,以确保基础被充分地理解,基本问题是解决了,足够强大的设计,以避免未来的问题由于预期组件/环境参数的变化。
3所示。协助整合,整体评价,修改仪表/系统。提供测试功能的硬件相同。
4所示。确保所有文档完成,以适当的形式包括任何重要组件规范。
5。展示了从电路设计产品开发经验(模拟/数字),评估和制造业。
内部条件:
必须:
1。硕士学位(或以上),电子工程或相关学科或同等教育和经验的结合。
2。良好的英语口头和书面沟通技巧。
3所示。电子设计中强烈的兴趣和热情。固体和广泛的知识/经验在仪表模拟和/或数字电路设计。
4所示。展示灵活性、独立性和主动性来执行成功地在一个快速变化的环境。
5。展示分析解决问题的能力。
6。具备良好的人际交往能力
想要:
1。高精密模拟电路设计经验优先
2。机电一体化设计经验优先。交货、运动控制、流量控制、热控制…
3所示。SoC设计经验优先。EX,Xilinx ZYNQ FPGA
此帖出自求职招聘论坛
葛爷是你吗?哈哈哈
此帖出自求职招聘论坛
中星联华&ADI明日直播
直播主题:大咖面对面,轻松玩转高速ADC性能测试
直播时间:3月25日(周二)14:00
活动奖励:京东卡、双肩包
