小钢炮开发板带有HTS221温湿度传感器,这个温湿度传感器和STH22/si7002不同,不能直接读取温度和湿度,需要通过插值进行计算。
下面是我写的HTS221驱动,可以通过函数直接读取温度和湿度常数。
- # HTS221 Humidity and temperature micropython drive
- # Author: shaoziyang
- # 2016.4
- import pyb
- from pyb import I2C
- HTS_I2C_ADDR = 0x5F
- class HTS221(object):
- def __init__(self, i2cn):
- self.i2c = I2C(i2cn, I2C.MASTER, baudrate = 100000)
- # HTS221 Temp Calibration registers
- self.T0_OUT = self.get2Reg(0x3C)
- self.T1_OUT = self.get2Reg(0x3E)
- if self.T0_OUT>=0x8000 :
- self.T0_OUT -= 65536
- if self.T1_OUT>=0x8000 :
- self.T1_OUT -= 65536
- t1 = self.getReg(0x35)
- self.T0_degC = (self.getReg(0x32) + (t1%4)*256)/8
- self.T1_degC = (self.getReg(0x33)+ ((t1%16)/4)*256)/8
- # HTS221 Humi Calibration registers
- self.H0_OUT = self.get2Reg(0x36)
- self.H1_OUT = self.get2Reg(0x3A)
- self.H0_rH = self.getReg(0x30)/2
- self.H1_rH = self.getReg(0x31)/2
- # set av conf: T=4 H=8
- self.setReg(0x81, 0x10)
- # set CTRL_REG1: PD=1 BDU=1 ODR=1
- self.setReg(0x85, 0x20)
- def setReg(self, dat, reg):
- buf = bytearray(2)
- buf[0] = reg
- buf[1] = dat
- i2c = self.i2c
- i2c.send(buf, HTS_I2C_ADDR)
- def getReg(self, reg):
- i2c = self.i2c
- i2c.send(reg, HTS_I2C_ADDR)
- t = i2c.recv(1, HTS_I2C_ADDR)
- return t[0]
- def get2Reg(self, reg):
- a = self.getReg(reg)
- b = self.getReg(reg + 1)
- return a + b * 256
- def av(self, av=''):
- i2c = self.i2c
- if av != '':
- #buf = bytearray(2)
- #buf[0] = 0x10;
- #buf[1] = av;
- #i2c.send(buf, HTS_I2C_ADDR)
- self.setReg(av, 0x10)
- else:
- #i2c.send(0x10, HTS_I2C_ADDR)
- #t = i2c.recv(1, HTS_I2C_ADDR)
- #return t[0]
- return self.getReg(0x10)
- def T0_OUT(self):
- return self.T0_OUT
- def T1_OUT(self):
- return self.T1_OUT
- def T0_degC(self):
- return self.T0_degC
- def T1_degC(self):
- return self.T1_degC
- # calculate Temperature
- def getTemp(self):
- t = self.get2Reg(0x2A)
- return self.T0_degC + (self.T1_degC - self.T0_degC) * (t - self.T0_OUT) / (self.T1_OUT - self.T0_OUT)
- def H0_OUT(self):
- return self.H0_OUT
- def H1_OUT(self):
- return self.H1_OUT
- def H0_rH(self):
- return self.H0_rH
- def H1_rH(self):
- return self.H1_rH
- # calculate Humidity
- def getHumi(self):
- t = self.get2Reg(0x28)
- return self.H0_rH + (self.H1_rH - self.H0_rH) * (t - self.H0_OUT) / (self.H1_OUT - self.H0_OUT)
复制代码
先将hts221.py复制到小钢炮的PYFLASH磁盘,然后就可以使用函数读取温度湿度
- PYB: sync filesystems
- PYB: soft reboot
- MicroPython v1.7 on 2016-04-17; CANNON with STM32F401xE
- Type "help()" for more information.
- >>> from hts221 import HTS221
- >>> hts=HTS221(1)
- >>> hts.getTemp()
- 22.95221
- >>> hts.getHumi()
- 82.62943
复制代码
