1953|0
888
linux kernel 实现多平台编译 (linux 内核调试) [复制链接]
1、在kconfig中添加编译平台
Index: arch/arm/mach-hi3516a/Kconfig
--- arch/arm/mach-hi3516a/Kconfig    (revision 106)
+++ arch/arm/mach-hi3516a/Kconfig    (working copy)
@@ -33,6 +33,17 @@
       please select HAVE_ARM_LOCAL_TIMER.
endchoice
+config MACH_UPANO_HI3516A_SENSOR
+        bool "hi3516a sensor module"
+    default y
+        depends on MACH_HI3516A
+config MACH_UPANO_HI3516A_MAIN
+        bool "hi3516a main module"
+    default y
config DEFAULT_BUSCLK
     int "DEFAULT_BUSCLK"
     default "50000000"
2、添加对应的.config文件
A  +    arch/arm/configs/hi3516a_test1_defconfig
A  +    arch/arm/configs/hi3516a_test2_defconfig
CONFIG_MACH_HI3516A=y
CONFIG_HAVE_SP804_LOCAL_TIMER_HI3516A=y
# CONFIG_HAVE_ARM_LOCAL_TIMER_HI3516A is not set
# CONFIG_MACH_HI3516A_TEST1 is not set
CONFIG_MACH_HI3516A_TEST2=y
在.config 中添加对应的平台配置
3、在kernel 启动的时候打印系统信息的时候,添加打印出板子的平台信息
Index: arch/arm/kernel/setup.c
--- arch/arm/kernel/setup.c    (revision 106)
+++ arch/arm/kernel/setup.c    (working copy)
@@ -474,6 +474,14 @@
     cpu_cache = *list->cache;
#endif
+#if defined(CONFIG_MACH_HI3516A_TEST1)
+    printk("BOARD_TYPE := HI3516A_TEST1\n");
+#elif defined(CONFIG_MACH_HI3516A_TEST2)
+    printk("BOARD_TYPE := HI3516A_TEST2\n");
+#else
+    printk("BOARD_TYPE := Unknown board\n");
+#endif
     printk("CPU: %s [%08x] revision %d (ARMv%s), cr=%08lx\n",
            cpu_name, read_cpuid_id(), read_cpuid_id() & 15,
            proc_arch[cpu_architecture()], cr_alignment);
4、更新内核启动信息
    init/main.c--->start_kernel--->setup_arch--->arch/arm/kernel/setup.c--->setup_arch--->setup_processor
个人签名邮箱:ternence.hsu@foxmail.com
