1988|0
6991
用msp430单片机的内部ADC芯片驱动模块c语言程序分享一下 [复制链接]
  • //mod p5.3
  • //wr p5.0
  • //rd p5.1
  • //ce p5.2
  • #include "msp430x44x.h"
  • #define uchar unsigned char
  • #define uint unsigned int
  • uint i=0;
  • Out_com(uchar com)
  • {P5OUT=0XF9;
  • P1DIR=0x00;
  • while((P1IN&0x03)!=0x03);
  • P1DIR=0xff;
  • P5OUT=0XFA;
  • P1OUT=com;
  • Out_data(uchar dat)
  • {P5OUT=0XF9;
  • P1DIR=0x00;
  • P1DIR=0xff;
  • P5OUT=0XF2;
  • P1OUT=dat;
  • Out_data2_com(uchar dat1,uchar dat2,uchar com1)
  • {Out_data(dat1);
  • Out_data(dat2);
  • Out_com(com1);
  • Chars_dis(uchar Line_num,uchar Rank_num,uchar *s)
  • {uchar i;
  • Out_data2_com(Line_num*16+Rank_num,0x00,0x24);
  • Out_com(0xb0);
  • for(i=0;s!='\0';i++)
  • Out_data(s-0x20);
  • Out_com(0xb2);
  • Chars_dic(uchar Line_num,uchar Rank_num,uint i)
  • {uchar s[10]="0123456789";
  • Out_com(0xb0);
  • Out_data(s[i/1000]-0x20);
  • Out_data(s[i/100%10]-0x20);
  • Out_data(s[i/10%10]-0x20);
  • Out_data(s[i%10]-0x20);
  • Out_com(0xb2);
  • Chars_dit(uchar Line_num,uchar Rank_num,uchar *s)
  • {uchar m;
  • for(m=0;m<32;m++)
  •      {if(m%2==0)
  •          {Out_com(0xb2);
  •           Out_data2_com(2*Rank_num+16*m/2,0x04+Line_num,0x24);
  •           Out_com(0xb0);
  •       Out_data(s[m]);
  • Out_com(0xb2);
  • Clear()
  • {uint i;
  • Out_data2_com(0x00,0x00,0x24);
  • Out_com(0xb0);
  • for(i=0;i<129;i++)
  •     Out_data(0x00);
  • Out_com(0xb2);
  • Out_data2_com(0x00,0x04,0x24);
  • Out_com(0xb0);
  • for(i=0;i<1025;i++)
  •     Out_data(0x00);
  • Out_com(0xb2);
  • void main()
  • {WDTCTL = WDTPW + WDTHOLD;
  • P3OUT=0x00;
  • P5DIR=0xff;
  • Out_data2_com(0x00,0x00,0x40);
  • Out_data2_com(0x10,0x00,0x41);
  • Out_data2_com(0x00,0x04,0x42);
  • Out_data2_com(0x10,0x00,0x43);
  • Out_com(0x80);
  • Out_com(0x9c);
  • Clear();
  • P6SEL|=0x07;
  • ADC12CTL1=SHP+CONSEQ_1;
  • ADC12MCTL0=INCH_0;
  • ADC12MCTL1=INCH_1;
  • ADC12MCTL2=INCH_2+EOS;
  • ADC12CTL0=ADC12ON+ENC+MSC;
  • while(1)
  • {ADC12CTL0|=ADC12SC;
  • while(~ADC12IFG & BIT2);
  • Chars_dic(1,0,ADC12MEM0);
  • Chars_dic(2,0,ADC12MEM1);
  • Chars_dic(3,0,ADC12MEM2);
