5495|0
编译遇到#10010错误 [复制链接]
在跑一个ti工程师给的pwm的程序。新建一个rtos的empty工程,导入后遇到以下错误。
Description Resource Path Location Type
#10010 errors encountered during linking; "12345.out" not built 12345 C/C++ Problem
#10234-D unresolved symbols remain 12345 C/C++ Problem
unresolved symbol heartBeatFxn, first referenced in C:\workspace_v6_1\12345\Debug\configPkg\package\cfg\main_pem3.oem3 12345 C/C++ Problem
unresolved symbol PWM_open, first referenced in ./main.obj 12345 C/C++ Problem
unresolved symbol PWM_Params_init, first referenced in ./main.obj 12345 C/C++ Problem
unresolved symbol PWM_setDuty, first referenced in ./main.obj 12345 C/C++ Problem
unresolved symbol PWM_start, first referenced in ./main.obj 12345 C/C++ Problem
#10229-D output section ".data" refers to load symbol "heartBeatFxn" and hence cannot be compressed; compression "rle" is ignored 12345 C/C++ Problem
