3398|0
111
CC2538片内温度读取实验 TinyOS如何直接使用C文件 [复制链接]
使用过CC2530的朋友肯定对TI的片内温度不陌生;下面带来2538的片内温度读取;先看实验结果:
代码部分:选择使用TinyOS来实现此处的实验是向大家展示如何TinyOS如何直接使用C(h)文件,打消大家认为TiinyOS编程只能用nesC的误区
1,温度读取函数 tinyos-main-release_tinyos_2_1_2\tos\chips\cc2538\adc 下的cc2538_temp_sensor.c和cc2538_temp_sensor.h
cc2538_temp_sensor.h文件:
  1. #ifndef CC2538_TEMP_SENSOR_H_
  2. #define CC2538_TEMP_SENSOR_H_
  3.
  4. #define CONST 0.58134 //(VREF / 2047) = (1190 / 2047), VREF from Datasheet
  5. #define OFFSET_DATASHEET_25C 827 // 1422*CONST, from Datasheet
  6. #define TEMP_COEFF (CONST * 4.2) // From Datasheet
  7. #define OFFSET_0C (OFFSET_DATASHEET_25C - (25 * TEMP_COEFF))
  8. uint16_t  Get_CC2538_Temp(void);
  9. #endif
复制代码
cc2538_temp_sensor.c文件:
  1. #include <stdbool.h>
  2. #include <stdint.h>
  3. #include <stdio.h>
  4. #include "hw_memmap.h"
  5. #include "gpio.h"
  6. #include "hw_ioc.h"
  7. #include "ioc.h"
  8. #include "interrupt.h"
  9. #include "adc.h"
  10. #include "sys_ctrl.h"
  11. #include "hw_sys_ctrl.h"
  12. #include "systick.h"
  13. #include "hw_rfcore_xreg.h"
  14. #include "hw_cctest.h"
  15. #include "cc2538_temp_sensor.h"
  16.
  17. uint16_t  Get_CC2538_Temp(void)
  18. {
  19.     uint16_t ui16Dummy;
  20.
  21.     //
  22.     // Enable RF Core (needed to enable temp sensor)
  23.     //
  24.     SysCtrlPeripheralEnable(SYS_CTRL_PERIPH_RFC);
  25.     //
  26.     // Connect temp sensor to ADC
  27.     //
  28.     HWREG(CCTEST_TR0) |= CCTEST_TR0_ADCTM;
  29.
  30.     //
  31.     // Enable the temperature sensor
  32.     //
  33.     HWREG(RFCORE_XREG_ATEST) = 0x01;
  34.
  35.     //
  36.     // Configure ADC, Internal reference, 512 decimation rate (12bit)
  37.     //
  38.     SOCADCSingleConfigure(SOCADC_12_BIT, SOCADC_REF_INTERNAL);
  39.
  40.
  41.     //
  42.     // Trigger single conversion on internal temp sensor
  43.     //
  44.     SOCADCSingleStart(SOCADC_TEMP_SENS);
  45.
  46.     //
  47.     // Wait until conversion is completed
  48.     //
  49.     while(!SOCADCEndOfCOnversionGet()){
  50.     }
  51.
  52.     //
  53.     // Get data and shift down based on decimation rate
  54.     //
  55.     ui16Dummy = SOCADCDataGet() >> SOCADC_12_BIT_RSHIFT;
  56.     return ui16Dummy;
  57.
  58.
  59. }
复制代码
2,编写TinyOS例程:Adc_TempAppC.nc,Adc_TempC.nc,makefile文件:
Makefile文件:
  1. COMPONENT=Adc_TempAppC
  2. CFLAGS += -DUSE_TIMER_HANDLER
  3. CFLAGS += -DNOT_USE_PRINTFC_BUT_USE_PRINT
  4. include $(MAKERULES)
复制代码
Adc_TempAppC.nc文件
  1. configuration Adc_TempAppC
  2. {
  3. }
  4. implementation
  5. {
  6.   components MainC, Adc_TempC;
  7.   components new TimerMilliC() as Timer1;
  8.
  9.   Adc_TempC -> MainC.Boot;
  10.   Adc_TempC.Timer1 -> Timer1;
  11. }
复制代码
Adc_TempC.nc文件:
  1. /*******************************************************************
  2. *实验附加----CC2538片内温度读取
  3. *节点需求数1
  4. *编译命令make cc2538cb
  5. ********************************************************************/
  6.
  7. #include "Timer.h"
  8. #include "printf.h"
  9. #include "cc2538_temp_sensor.h"
  10.
  11. module Adc_TempC
  12. {
  13.    uses interface Timer<TMilli> as Timer1;
  14.    uses interface Boot;
  15. }
  16. implementation
  17. {
  18.   task void time1_Task();
  19.   uint16_t ui16Dummy=0;
  20.
  21.   /***************************************************
  22.   *启动事件
  23.   ****************************************************/
  24.   event void Boot.booted()
  25.   {
  26.     /**开启一秒的周期性定时器(单位毫秒)  Timer1**/
  27.     call Timer1.startPeriodic( 1000 );
  28.
  29.   }
  30.
  31.   /***************************************************
  32.   *任务time1_Task
  33.   ****************************************************/
  34.   task void time1_Task()
  35.   {
  36.       double dOutputVoltage;
  37.
  38.
  39.       ui16Dummy = Get_CC2538_Temp();
  40.       printf("ADC raw readout: %d\n", ui16Dummy);
  41.
  42.       //温度计算
  43.       dOutputVoltage = ui16Dummy * CONST;
  44.       dOutputVoltage = ((dOutputVoltage - OFFSET_0C) / TEMP_COEFF);
  45.       ui16Dummy = dOutputVoltage * 10;
  46.
  47.       printf("Temperature: %d", ui16Dummy/10);
  48.       printf(".%d", ui16Dummy%10);
  49.       printf(" C\n");
  50.   }
  51.
  52.   /***************************************************
  53.   *Timer1定时时间到事件
  54.   ****************************************************/
  55.   event void Timer1.fired()
  56.   {
  57.     /****提交time1_Task任务***/
  58.     post time1_Task();
  59.   }
  60.
  61. }
复制代码
大家可以看到Adc_TempC.nc文件中
  1. #include "cc2538_temp_sensor.h"
  2. ui16Dummy = Get_CC2538_Temp();
复制代码
这些不就是直接使用了C文件了吗?nesC只是C的方言,相信即使没有nesC语言基础的朋友应该也能大概看懂代码干了什么;就是1秒采集一次片内温度然后串口打印
至此可以引申如果是需要给TinyOS引入其他的传感器呢,呵呵,其实就是拿来厂家提供的C源码直接
使用即可,不用去写成nesC;
此帖出自RF/无线论坛
个人签名https://open6lowpan.taobao.com/
