3134|0
stm32F SPI+DMA+Interrupt ? [复制链接]
这几天一直在搞SPI  DMA 通信.DMA设置成中断,定时器中断启动DMA,SPI无法发送数据,同时也无法产生DMA中断。具体SPI 和DMA的配置如下:
SPI2 初始化
void SPI2_PeriphInit (void)
    GPIO_InitTypeDef GPIO_InitStructure;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    //GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_SPI2);        //PB12 NSS
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_SPI2);        //PB13 SCK
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource14, GPIO_AF_SPI2);        //PB14 MISO
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource15, GPIO_AF_SPI2);        //PB15 MOSI
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
    GPIO_SetBits(GPIOB, GPIO_Pin_12);
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_DOWN;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_15;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
    SPI_InitTypeDef SPI_InitStructure;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2, ENABLE);
    SPI_I2S_DeInit(SPI2);
    SPI_InitStructure.SPI_Direction= SPI_Direction_2Lines_FullDuplex;
    SPI_InitStructure.SPI_DataSize = SPI_DataSize_16b;
    SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
    SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
    SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
    SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
    SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
    SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
    SPI_InitStructure.SPI_CRCPolynomial = 7;
    SPI_Init(SPI2, &SPI_InitStructure);
    SPI_CalculateCRC(SPI2, DISABLE);
    SPI_Cmd(SPI2, ENABLE);
DMA初始化
void SPI2_DMAInit (void)
    DMA_InitTypeDef DMA_InitStructure;
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE);
    DMA_DeInit(DMA1_Stream3);
    DMA_DeInit(DMA1_Stream4);
    DMA_InitStructure.DMA_Channel  = DMA_Channel_0;
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&(SPI2->DR));
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)ad7657_revbuf[0];    //ad7657_revbuff 为2维数组 , 2 x 6
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
    DMA_InitStructure.DMA_BufferSize = AD7656REVDATALEN;                            //宏定义为6
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
    DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
    DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
    DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
    DMA_Init(DMA1_Stream3, &DMA_InitStructure);
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)ad7657_send;       //数组,6个字节
    DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
    DMA_InitStructure.DMA_BufferSize = AD7656SENDLEN;                               //宏定义 6
    DMA_InitStructure.DMA_Priority = DMA_Priority_Low;
    DMA_Init(DMA1_Stream4, &DMA_InitStructure);
    SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);
    SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, ENABLE);
    DMA_ITConfig(DMA1_Stream3, DMA_IT_TC | DMA_IT_TE, ENABLE);
    DMA_ITConfig(DMA1_Stream4, DMA_IT_TC | DMA_IT_TE, ENABLE);
    NVIC_InitTypeDef  NVIC_InitStructure;
    NVIC_InitStructure.NVIC_IRQChannel = DMA1_Stream3_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannel =ENABLE;
    NVIC_Init(&NVIC_InitStructure);
    DMA_Cmd(DMA1_Stream3, DISABLE);
    DMA_Cmd(DMA1_Stream4, DISABLE);
定时触发DMA 发送数据
void TIM2_IRQHandler(void)
    if (TIM_GetITStatus (TIM2, TIM_IT_Update) == SET)
        TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
        GPIO_ResetBits(GPIOB, GPIO_Pin_12);
        while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET);
        DMA_SetCurrDataCounter(DMA1_Stream3, 6);
        DMA_SetCurrDataCounter(DMA1_Stream4, 6);
        DMA_Cmd(DMA1_Stream4, ENABLE);
        DMA_Cmd(DMA1_Stream3, ENABLE);
DMA 产生中断
void DMA1_Stream3_IRQHandler (void)
    if (DMA_GetITStatus(DMA1_Stream3, DMA_IT_TCIF3) == SET)
        DMA_ClearFlag(DMA1_Stream3, DMA_IT_TC);
        DMA_ClearFlag(DMA1_Stream4, DMA_IT_TC);
        DMA_ClearITPendingBit(DMA1_Stream3, DMA_IT_TCIF3);
        DMA_ClearITPendingBit(DMA1_Stream4, DMA_IT_TCIF4);
        SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, DISABLE);
        SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, DISABLE);
此帖出自stm32/stm8论坛
