5128|5
关于stm32的定时器2的复用问题 [复制链接]
最近在用定时器实现编码器功能,然后tim2与tim5的io是一样的,就要用到afio,结果找了些资料,写了代码,发现定时器复用并没有实现。。。这代码是将tim2_ch1和ch2从PA0和PA1重映射到PA15和PB3,而计数器没有计数。。后来把代码里的tim2换成了tim3,从PA6PA7重映射到PC6PC7,然后测试结果是可以计数,于是就不理解,难道是tim2复用这部分有问题?
编码器的配置代码
void encoder_Count_Init(void )
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_ICInitTypeDef TIM_ICInitStructure;
        // Encoder unit connected to TIM3, 4X mode
        GPIO_InitTypeDef GPIO_InitStructure;
        NVIC_InitTypeDef NVIC_InitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
        // Enable GPIOA, clock
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO,ENABLE);
        GPIO_PinRemapConfig(GPIO_FullRemap_TIM2,ENABLE);
        GPIO_StructInit(&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
        TIM_DeInit(ENCODER_TIMER);
        TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
        TIM_TimeBaseStructure.TIM_Prescaler = 0x0; // No prescaling
        TIM_TimeBaseStructure.TIM_Period = 20000;
        TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(ENCODER_TIMER, &TIM_TimeBaseStructure);
        TIM_EncoderInterfaceConfig(ENCODER_TIMER, TIM_EncoderMode_TI12,TIM_ICPolarity_Rising, TIM_ICPolarity_Rising);
        TIM_ICStructInit(&TIM_ICInitStructure);
        //TIM_ICInitStructure.TIM_ICFilter = ICx_FILTER;
        TIM_ICInit(ENCODER_TIMER, &TIM_ICInitStructure);
        // Clear all pending interrupts
        TIM_ClearFlag(ENCODER_TIMER, TIM_FLAG_Update);
        TIM_ITConfig(ENCODER_TIMER, TIM_IT_Update, DISABLE);
        //Reset counter
        ENCODER_TIMER->CNT = 0;
        // ENC_Clear_Speed_Buffer();
        TIM_Cmd(ENCODER_TIMER, ENABLE);
买芯片bom2buy
此帖出自stm32/stm8论坛
感谢楼主的分享和分析,不过我并没有感觉到这段代码有多精妙! 首先这个并不是一个键盘扫描程序,而是一个处理函数,当然非要这么叫也能说的过去,比较这个函数没有涉及键值的处理,也算扫描。其次说这个程序只有三行有点儿标题党的意思了,因为这个显然用的是独立按键,独立按键的读取本来就简单,一句话就完了,下面的处理用的也是C语言的技巧而已,但这个技巧并不代表高的执行效率,也就是这样的简短并没有实际意义,还不如分行写清楚的好。我mei看过华为的一个编程规范,明确建议少用C语言技巧。再一个这个函数本事并没有滤波功能,因此算不上一个完整的键盘扫描函数。通过主函数实现滤波是稍微大一些应用中就不可取了,这个函数的用法优点在于按下按键之后只执行一次规定 操作,同时可以及时(按楼主说的就是20ms)发现按键松开。  详情 回复 发表于 2018-9-13 14:36
4008
你复用时钟没有开吧
此帖出自stm32/stm8论坛
pa15.pb3默认是调试借口的,你的失能扒,然后在从映射才起作用的
此帖出自stm32/stm8论坛
21
PA15脚默认是不是普通IO口得从新映射为普通口
JTAG下载不用的引脚B3,PB4当成普通IO口进行操作
具体步骤如下:
1、打开复用时钟:RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,EANBLE);
2、调用重映射函数: GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
进行上述配置后即可将JTAG下载引脚PB3,PB3当成普通GPIO来使用了!同时也可以用SWD方式进行程序的下载和调试
此帖出自stm32/stm8论坛
4008
tim2映射管脚有误
此帖出自stm32/stm8论坛
32
此帖出自stm32/stm8论坛
中星联华&ADI明日直播
直播主题:大咖面对面,轻松玩转高速ADC性能测试
直播时间:3月25日(周二)14:00
活动奖励:京东卡、双肩包
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 11
