3082|3
266
【NUCLEO-F410RB】2.给nucleo移植上ucos-ii,用信号量实现led闪烁 [复制链接]
     虽然管理员寄过来的板子不能用,但是还得完成任务。所以抽出时间把ucos-ii移植上另外一块Nucleo板子上,奉上工程源码,供大家享用~~
  1. int main(void)
  2. {
  3.
  4.     CPU_INT08U  os_err;
  5. #if (CPU_CFG_NAME_ERR == DEF_ENABLED)
  6.     CPU_ERR     cpu_err;
  7. #endif
  8.     //CPU_Init();
  9.     BSP_IntDisAll();                                            /* Disable all interrupts.                              */
  10.     OSInit();                                                   /* Initialize "uC/OS-II, The Real-Time Kernel"          */
  11.     OSTaskCreateExt((void (*)(void *)) AppTaskStart,            /* Create the start task                                */
  12.                     (void           *) 0,
  13.                     (OS_STK         *)&AppTaskStartStk[APP_CFG_TASK_START_STK_SIZE - 1],
  14.                     (INT8U           ) APP_CFG_TASK_START_PRIO,
  15.                     (INT16U          ) APP_CFG_TASK_START_PRIO,
  16.                     (OS_STK         *)&AppTaskStartStk[0],
  17.                     (INT32U          ) APP_CFG_TASK_START_STK_SIZE,
  18.                     (void           *) 0,
  19.                     (INT16U          )(OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR));
  20. #if (OS_TASK_NAME_EN > 0)
  21.     OSTaskNameSet((INT8U     )APP_CFG_TASK_START_PRIO,
  22.                   (INT8U    *)"Start_Task",
  23.                   (INT8U    *)&os_err);
  24. #endif
  25.     OSStart();                                                  /* Start multitasking (i.e. give control to uC/OS-II)   */
  26.     return (1);
  27. }
  28. /*
  29. *********************************************************************************************************
  30. *                                          STARTUP TASK
  31. *
  32. * Description : This is an example of a startup task.  As mentioned in the book's text, you MUST
  33. *               initialize the ticker only once multitasking has started.
  34. *
  35. * Arguments   : p_arg   is the argument passed to 'AppTaskStart()' by 'OSTaskCreate()'.
  36. *
  37. * Returns     : none
  38. *
  39. * Notes       : 1) The first line of code is used to prevent a compiler warning because 'p_arg' is not
  40. *                  used.  The compiler should not generate any code for this statement.
  41. *********************************************************************************************************
  42. */
  43. void  AppTaskStart (void *p_arg)
  44. {
  45.    (void)p_arg;                                                /* Note #1                                             */
  46.     OS_CPU_SysTickInit(OS_TICKS_PER_SEC);                       /* Initialize tick counter                              */
  47.     Bsp_Init();                                                 /* Initialize BSP functions                             */
  48.     CPU_Init();                                                 /* Initialize the uC/CPU services                       */
  49.     BSP_Tick_Init();                                            /* Start Tick Initialization                            */
  50. #if (OS_TASK_STAT_EN > 0)
  51.     OSStatInit();                                               /* Determine CPU capacity                               */
  52. #endif
  53.
  54.     AppEventCreate();                                           /* Create Application Events                             */
  55.
  56.     AppTaskCreate();                                            /* Create application tasks                              */
  57.     while (1)                                                   /* Task body, always written as an infinite loop.       */
  58.                         {
  59.
  60.               OSSemPost(Led3_SEM);
  61.               OSTimeDlyHMSM(0, 0,0,800);
  62.         OSSemPost(Led4_SEM);
  63.
  64.               OSTimeDlyHMSM(0, 0,0,800);
  65.
  66.       }
  67. }
  68. /*
  69. *********************************************************************************************************
  70. *                                      AppTaskEventCreate()
  71. *
  72. * Description : Create the application Events
  73. *
  74. * Argument(s) : none.
  75. *
  76. * Return(s)   : none.
  77. *
  78. * Caller(s)   : App_TaskStart()
  79. *
  80. * Note(s)     : none.
  81. *********************************************************************************************************
  82. */
  83. void  AppEventCreate (void)
  84. {
  85.    Led3_SEM=OSSemCreate(0);
  86.    Led4_SEM=OSSemCreate(0);
  87.
  88. }
  89. /*
  90. *********************************************************************************************************
  91. *                                      AppTaskCreate()
  92. *
  93. * Description : Create the application tasks.
  94. *
  95. * Argument(s) : none.
  96. *
  97. * Return(s)   : none.
  98. *
  99. * Caller(s)   : App_TaskStart()
  100. *
  101. * Note(s)     : none.
  102. *********************************************************************************************************
  103. */
  104. void  AppTaskCreate (void)
  105. {
  106. #if (OS_TASK_NAME_EN > 0)
  107.     CPU_INT08U  os_err;
  108. #endif
  109.     OSTaskCreateExt((void (*)(void   *))AppTaskLED3,            /* Create the task for LED3 semaphore blinking          */
  110.                     (void            *) 0,
  111.                     (OS_STK          *)&AppTaskLED3Stk[APP_CFG_TASK_LED3_STK_SIZE - 1],
  112.                     (INT8U            ) APP_CFG_TASK_LED3_PRIO,
  113.                     (INT16U           ) APP_CFG_TASK_LED3_PRIO,
  114.                     (OS_STK          *)&AppTaskLED3Stk[0],
  115.                     (INT32U           ) APP_CFG_TASK_LED3_STK_SIZE,
  116.                     (void            *) 0,
  117.                     (INT16U           )OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR);
  118. #if  (OS_TASK_NAME_EN > 0)
  119.      OSTaskNameSet((INT8U   )APP_CFG_TASK_LED3_PRIO,
  120.                    (INT8U  *)"App Task LED3",
  121.                    (INT8U  *)&os_err);
  122. #endif
  123.     OSTaskCreateExt((void (*)(void   *))AppTaskLED4,            /* Task creation for LED 4 queue control with LED 3 too */
  124.                     (void            *) 0,
  125.                     (OS_STK          *)&AppTaskLED4Stk[APP_CFG_TASK_LED4_STK_SIZE - 1],
  126.                     (INT8U            ) APP_CFG_TASK_LED4_PRIO,
  127.                     (INT16U           ) APP_CFG_TASK_LED4_PRIO,
  128.                     (OS_STK          *)&AppTaskLED4Stk[0],
  129.                     (INT32U           ) APP_CFG_TASK_LED4_STK_SIZE,
  130.                     (void            *) 0,
  131.                     (INT16U           ) OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR);
  132. #if  (OS_TASK_NAME_EN > 0)
  133.      OSTaskNameSet((INT8U   )APP_CFG_TASK_LED4_PRIO,
  134.                    (INT8U  *)"App Task LED4",
  135.                    (INT8U  *)&os_err);
  136. #endif
  137. }
  138. /*
  139. *********************************************************************************************************
  140. *                                         AppTaskLED3()
  141. *
  142. * Description : Task to activate and toggle LED2 after timer tick system expires.
  143. *
  144. * Argument(s) : p_arg   is the argument passed to 'AppTaskLED2()' by 'OSTaskCreate()'.
  145. *
  146. * Return(s)   : none.
  147. *
  148. * Caller(s)   : none.
  149. *
  150. * Note(s)     : none.
  151. *********************************************************************************************************
  152. */
  153. void  AppTaskLED3(void *p_arg)
  154. {
  155.           CPU_INT08U  err;
  156.     (void)p_arg;
  157.     while(1)
  158.                         {
  159.                          OSSemPend(Led3_SEM,0,&err);
  160.        Bsp_Led_On(3);
  161.                          Bsp_Led_Off(4);
  162.        OSTimeDly(500);
  163.        OSTimeDly(500);
  164.                         }
  165. }
  166. /*
  167. *********************************************************************************************************
  168. *                                         AppTaskLED4()
  169. *
  170. * Description : Toggle LED3 using semaphore services.
  171. *
  172. * Argument(s) : p_arg   is the argument passed to 'AppTaskLED3()' by 'OSTaskCreate()'.
  173. *
  174. * Return(s)   : none.
  175. *
  176. * Caller(s)   : none.
  177. *
  178. * Note(s)     : Calls the LED function to activate LED 3.
  179. *********************************************************************************************************
  180. */
  181. void  AppTaskLED4(void *p_arg)
  182. {
  183.           CPU_INT08U  err;
  184.     (void)p_arg;
  185.     while (1)
  186.                         {
  187.                                 OSSemPend(Led4_SEM,0,&err);
  188.         Bsp_Led_On(4);
  189.                                 Bsp_Led_Off(3);
  190.         OSTimeDly(500);
  191.         OSTimeDly(500);
  192.                   }
  193. }
复制代码
哈哈,,用MDK5编译的哦!
最后附上源代码:
f030r8_ucosii_demo.zip (2.22 MB, 下载次数: 8)
查看本帖全部内容,请登录或者注册
此帖出自stm32/stm8论坛
非常感谢分享  详情 回复 发表于 2018-12-1 16:38
点赞 关注(1)
gitee/casy
1158
66666点赞!
此帖出自stm32/stm8论坛
191
谢谢分享。。。
此帖出自stm32/stm8论坛
非常感谢分享
此帖出自stm32/stm8论坛
Vicor 有奖下载 | 在48V架构中使用高密度功率转换器构建更好的机器人
活动时间:即日起-4月28日
活动奖励:螺丝刀套装、充电套装、电风扇
