2471|1
6423
High Performance, FPGA-Optimized LDPC for Storage [复制链接]
LDPC and Error Correcting Codes
  • BCH codes are running out of steam
• Can’t take advantage of soft-data
• Performance is limited to the Shannon limit for a hard channel
  • LDPC codes
• Near Shannon-limit performance
• Take advantage of soft-data
• Good implementations of LDPC codes are low power and cost effective
  • No standards for LDPC in storage space
  • Code “growth” technology with best-in-class coding performance
at very low cost
Sub-system block diagram
DSP work is focused on the LDPC encoder, decoder and statistics processing below
Xilinx LDPC Features
  • Best-in-class code performance near Shannon limit
  • Achieved low error floor under 10-15 with proprietary optimization method
  • Support for code rate change on-the-fly
  • Support both hard decision and soft decision decoding
  • High throughput and low latency performance
  • Scalable architecture supporting various options
  • FPGA optimized for minimal area/power
  • Provides decoder status and statistics interfaces
Xilinx LDPC Specifications
Raw BER v.s. Frame Error Rate
  • Advanced code construction methodology for best code performance
  • Achieved low error floor using proprietary optimization technique
  • Near Shannon limit performance
LDPC v.s. BCH Performance
Error Floor Free Performance
Error Correction Capability
LDPC Implementation
  • Single LDPC instance for easy integration
  • Achieve 400 MHz on 7 series and UltraScale™ FPGAs
  • Small footprint – low LUT counts
Hardware Reference Board
Summary
Xilinx offers LDPC with industry-leading
performance in all aspects:
• Error floor
• Resource utilization
• BER performance
• Throughput
此帖出自FPGA/CPLD论坛
个人签名training
6423
20150813_S303G_Tarn.pdf (164.44 KB, 下载次数: 3)
此帖出自FPGA/CPLD论坛
个人签名training
