选择实验板为00ic_DSP_TMS320F28335,仿真器为100v3,编译器为ccsv6.1
关于28335的DA输出模块,主要硬件由DSP和TLV5620组成,DSP提供了SIMO和SCLK、C3TRIP 信号给TLV5620,且C3TRIP信号是用来做片DAC信号的更新和锁 **
存的,这里大家要参照我们所提供的TLV5602的手册,4个信道 的DAC输出分别引了出来,方便大家来检测.这里还要说明的一点的是我们用了其中的两个信道DACA和DACB作为ADC的输入, 大家看电路便知。
实验结果:用万用表测试TLV5620的输出电压值0.8,然后输出的电压通过ACINA1转换后,通过观察发现Vin=0.8V
- // As supplied, this project is configured for "boot to SARAM"
- // operation. The 2833x Boot Mode table is shown below.
- // $Boot_Table:
- // GPIO87 GPIO86 GPIO85 GPIO84
- // XA15 XA14 XA13 XA12
- // PU PU PU PU
- // 1 1 1 1 Jump to Flash
- // 1 1 1 0 SCI-A boot
- // 1 1 0 1 SPI-A boot
- // 1 1 0 0 I2C-A boot
- // 1 0 1 1 eCAN-A boot
- // 1 0 1 0 McBSP-A boot
- // 1 0 0 1 Jump to XINTF x16
- // 1 0 0 0 Jump to XINTF x32
- // 0 1 1 1 Jump to OTP
- // 0 1 1 0 Parallel GPIO I/O boot
- // 0 1 0 1 Parallel XINTF boot
- // 0 1 0 0 Jump to SARAM <- "boot to SARAM"
- // 0 0 1 1 Branch to check boot mode
- // 0 0 1 0 Boot to flash, bypass ADC cal
- // 0 0 0 1 Boot to SARAM, bypass ADC cal
- // 0 0 0 0 Boot to SCI-A, bypass ADC cal
- // Boot_Table_End$
- #include "DSP2833x_Device.h" // DSP2833x Headerfile Include File
- #include "DSP2833x_Examples.h" // DSP2833x Examples Include File
- /*这里使用了宏定义来控制更新锁存信号的功能,重点就是在时序上*/
- #define SetLOAD GpioDataRegs.GPADAT.bit.GPIO17=1; //将LOAD置高
- #define ClrLOAD GpioDataRegs.GPADAT.bit.GPIO17=0; //将LOAD置低
- void WriteDAC(unsigned char add,unsigned char rng,unsigned char vol);
- void delay(unsigned int t);
- void spi_xmit(Uint16 a);
- void spi_fifo_init(void);
- void spi_init(void);
- // ADC start parameters
- #define ADC_MODCLK 0x5 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*4) = 15MHz
- // for 60 MHz devices: HSPCLK = 60/(2*4) = 7.5 MHz
- #define ADC_CKPS 0x1 // ADC module clock = HSPCLK/2*ADC_CKPS = 15MHz/(1*2) = 7.5MHz
- #define ADC_SHCLK 0xf // S/H width in ADC module periods = 16 ADC clocks
- #define AVG 100 // Average sample limit
- #define ZOFFSET 0x00 // Average Zero offset
- #define BUF_SIZE 2048 // Sample buffer size
- // Global variable for this example
- Uint16 SampleTable[BUF_SIZE];
- float Vin=0;
- void main(void)
- int temp;
- Uint16 i;
- Uint32 Sum=0;
- /*初始化系统*/
- InitSysCtrl();
- // Specific clock setting for this example:
- EALLOW;
- SysCtrlRegs.HISPCP.all = ADC_MODCLK; // HSPCLK = SYSCLKOUT/(2*ADC_MODCLK)=15MHZ
- EDIS;
- /*初始化GPIO;*/
- InitSpiaGpio();
- ///初始化IO口
- EALLOW;
- GpioCtrlRegs.GPAMUX2.bit.GPIO17 = 0; // 配置GPIO17为GPIO口
- GpioCtrlRegs.GPADIR.bit.GPIO17 = 1; // 定义GPIO17输出引脚
- GpioCtrlRegs.GPAPUD.bit.GPIO17 = 0; // 禁止上啦 GPIO17引脚
- EDIS;
- /* 关中断 */
- DINT;
- IER = 0x0000;
- IFR = 0x0000;
- /* 初始化PIE控制寄存器 */
- InitPieCtrl();
- /* 初始化PIE参数表 */
- InitPieVectTable();
- // 步骤 4.初始化片内外设:
- InitAdc(); // For this example, init the ADC
- ///初始化SPI
- spi_init(); // 初始化SPI
- EINT; // Enable Global interrupt INTM
- ERTM; // Enable Global realtime interrupt DBGM
- // Specific ADC setup for this example:
- AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK;//设置采样窗口时间:(15+1)*ADCCLK
- AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS;//ADC内核时钟分频:HSPCLK/2=6.25MHZ
- AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; // 1选择级联模式
- AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x1; //通道选择ADCAIN1
- AdcRegs.ADCTRL1.bit.CONT_RUN = 1; // 设置为连续运行
- // 采样表清0
- for (i=0; i<BUF_SIZE; i++)
- SampleTable[i] = 0;
- SetLOAD; //把刷新锁存控制信号拉高
- temp=47;//REF=2.2V;VO(DACA|B|C|D) =REF* CODE/256
- WriteDAC(0,0,temp); //0.4V
- WriteDAC(1,0,temp*2); //0.8V
- WriteDAC(2,0,temp*3); //1.2V
- WriteDAC(3,0,temp*4); //1.6V
- // 软件启动SEQ1
- AdcRegs.ADCTRL2.all = 0x2000;
- for (i=0; i<AVG; i++)
- while (AdcRegs.ADCST.bit.INT_SEQ1== 0) {} // 等待中断
- AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;
- SampleTable[i] =((AdcRegs.ADCRESULT0>>4) );
- for (i=0;i<AVG;i++)
- Sum+=SampleTable[i];
- Sum=Sum/2;
- //输入电压和AD值之间的关系Vin/Sum=3/4096;
- Vin=(float)(Sum*3)/4096; //采样的电压值
- delay(1500); //在此设断点,观察变量Vin的值,另外可以用万用表直接测量ADCA1电压值
- unsigned short int data;
- data=0x0000;
- ///大家要知道这里所定义的各个变量的含义,add是4个通道的地址(00,01,10,11)
- /// RNG是输出范围的倍数,可以是0或1。
- /// VOL是0~256数据
- data = ((add<<14) | (rng<<13) | (vol<<5));
- //注意这里的有效数据是11位,SPI初始化中也进行了定义
- while(SpiaRegs.SPISTS.bit.BUFFULL_FLAG ==1); //判断SPI的发送缓冲区是否是空的,等于0可写数据
- SpiaRegs.SPITXBUF = data; //把发送的数据写如SPI发送缓冲区
- while( SpiaRegs.SPISTS.bit.BUFFULL_FLAG==1); //当发送缓冲区出现满标志位时,开始琐存数据
- delay(1500);//同通过一负跳变琐存要发送的数据,看TLV5620数据手册即可得知
- ClrLOAD;
- delay(150);
- SetLOAD;
- delay(1500);
- while(t>0)
- t--;
- //初始化SPI函数
- void spi_init()
- SpiaRegs.SPICCR.all =0x0a;///进入初始状态,数据在上升沿输出,自测禁止,11位数据模式
- SpiaRegs.SPICTL.all =0x0006; // 使能主机模式,正常相位,使能主机发送,禁止接收
- //溢出中断,禁止SPI中断;
- SpiaRegs.SPIBRR =0x0031; //SPI波特率=37.5M/50 =0.75MHZ;
- SpiaRegs.SPICCR.all =0x8a; //退出初始状态;
- SpiaRegs.SPIPRI.bit.FREE = 1; // 自由运行
- // No more.
复制代码
