7051|2
Beaglebone black中QNX操作系统LED驱动问题 [复制链接]
1芯积分
本人购买了Beaglebone black开发板,并从QNX官网下载了针对该板卡的BSP
http://community.qnx.com/sf/wiki ... i/TiAm335Beaglebone
仿照BSP中led.c文件中int doleds(unsigned char ch)
  1. BSP中led.c文件中的int doleds(unsigned char ch)
  2. int doleds(unsigned char ch)
  3. {
  4.         uintptr_t        gpio_base;
  5.         uint32_t        val;
  6.     // Map device registers
  7.     gpio_base = mmap_device_io(AM335X_GPIO_SIZE, AM335X_GPIO1_BASE);
  8.     if(gpio_base == MAP_DEVICE_FAILED)
  9.     {
  10.         perror("Can't map device I/O");
  11.         return 0;
  12.     }
  13.     // Read GPIO output enable register
  14.     //  0 The corresponding GPIO port is configured as an output.
  15.     //  1 The corresponding GPIO port is configured as an input.
  16.     val  = in32(gpio_base + GPIO_OE);
  17.     val &= ~(LED0|LED1|LED2|LED3);
  18.     out32(gpio_base + GPIO_OE, val);
  19.     // Write GPIO data output register
  20.     val  = in32(gpio_base + GPIO_DATAOUT);
  21.     val &= ~(LED0|LED1|LED2|LED3);
  22.     val |= (LEDS(ch));
  23.     out32(gpio_base + GPIO_DATAOUT, val);
  24.     munmap_device_io(gpio_base, AM335X_GPIO_SIZE);
  25.     return 1;
  26. }
复制代码
写了如下代码来驱动LED显示。
结果是报执行到val  = in32(gpio_base + GPIO_OE)有误,in32()调用有误。
我对比了自己写的代码和BSP中的代码,感觉自己的代码没有问题,求高手指点问题出在哪里了?
  1. #include <stdlib.h>
  2. #include <stdio.h>
  3. #include <errno.h>
  4. #include <stdio.h>
  5. #include <stddef.h>
  6. #include <stdlib.h>
  7. #include <unistd.h>
  8. #include <string.h>
  9. #include <sys/mman.h>
  10. #include <hw/inout.h>
  11. #include "am335x.h"
  12. #include <sys/iofunc.h>
  13. #include <sys/dispatch.h>
  14. #define LED0        (1<<21)
  15. #define LED1        (1<<22)
  16. #define LED2        (1<<23)
  17. #define LED3        (1<<24)
  18. #define LEDS(n)        ((n&0xf)<<21)
  19. int main(void)
  20. {
  21.     uintptr_t    gpio_base;
  22.     uint32_t    val;
  23.     unsigned char ch =10;
  24.     if (ThreadCtl(_NTO_TCTL_IO, 0) == -1) {
  25.                 perror("ThreadCtl");
  26.                 exit(EXIT_FAILURE);
  27.             }
  28.         // Map device registers
  29.        gpio_base = mmap_device_io(AM335X_GPIO_SIZE, AM335X_GPIO1_BASE);
  30.         if(gpio_base == MAP_DEVICE_FAILED)
  31.         {
  32.             perror("Can't map device I/O");
  33.             return 0;
  34.         }
  35.         // Read GPIO output enable register
  36.         //  0 The corresponding GPIO port is configured as an output.
  37.         //  1 The corresponding GPIO port is configured as an input.
  38.         val  = in32(gpio_base + GPIO_OE);
  39.         val &= ~(LED0|LED1|LED2|LED3);
  40.         out32(gpio_base + GPIO_OE, val);
  41.         // Write GPIO data output register
  42.         val  = in32(gpio_base + GPIO_DATAOUT);
  43.         val &= ~(LED0|LED1|LED2|LED3);
  44.         val |= (LEDS(ch));
  45.         out32(gpio_base + GPIO_DATAOUT, val);
  46.         munmap_device_io(gpio_base, AM335X_GPIO_SIZE);
  47. }
复制代码
使用shell命令看运行结果为:
按照贴的程序编译运行了一下,没有报错  详情 回复 发表于 2017-11-3 16:47
你使用debug模式一步一步跟踪看一下,到底是哪一行除了问题。
525
235
按照贴的程序编译运行了一下,没有报错
个人签名爱电子,爱生活
