1、概述 MSP430F149有三个时钟源:外部LF(XT1一般为32.768K),HF(XT2一般为8M),内部DCO。从时钟系统模块可得到三种时钟信号:MCLK,SMCLK,ACLK。 上电默认状况下MCLK,SMCLK信号来自DCO,ACLK来自LF。根据官方PDF说法默认状况下DCO模块配置为RSELX=4,DCO=3,因此DCO应为1M,但示波器实测MCLK/SMCLK为680K,测试温度约25摄氏度。 标注:MCLK主时钟、SMCLK子时钟、ACLK活动时钟。 P5.4,P5.5,P5.6的第二功能分别对应MCLK,SMCLK,ACLK时钟信号,可用示波器测量。测试时发现频率后两位一直在跳动,频率稳定度很差。 MSP430系列单片机选择晶振为时钟源时,时钟周期就是晶振周期。一个机器周期 =一个时钟周期,即430每个动作都能完成一个基本操作; 一个指令周期 = 1~6个机器周期,具体根据具体指令而定。 如果选择8M晶振,则一个机器周期为125ns。51单片机选择12M晶振,它的机器周期是时钟周期/12,一个机器周期为1us,可见 MSP430的的速度是51的8倍。 2、使用方法概述 2.1 程序架构 一般在系统初始化关闭看门狗后要配置系统时钟,配置步骤为: 1、打开晶振; 2、等待晶振起振。清除OFIFG,延时,判断OFIFG是否为0,为0则晶振正常起振,退出判断; 3、选择MCLK/SMCLK时钟源; uchar iq0; BCSCTL1&=~XT2OFF; //打开XT2振荡器 do { IFG1 &= ~OFIFG; // 清除振荡器失效标志 for (iq0 = 0xFF; iq0 > 0; iq0--); // 延时,等待XT2起振 } while ((IFG1 & OFIFG) != 0); // 判断XT2是否起振 BCSCTL2 =SELM_2+SELS; //选择MCLK、SMCLK为XT2 2.2 细节描述 对于DCO可以通过配置电阻和DCO得到不同的频率。电阻可配置片内或片外(DCOR一般片内),片内电阻有8中选择(RSELX),DCO有8中选择(DCOX)。 3、相关寄存器 1、DCOCTL DCOx Bits 7-5 DCO frequency select. These bits select which of the eight discrete DCO frequencies of the RSELx setting is selected. 2、BCSCTL0 XT2OFF Bit 7 XT2 off. This bit turns off the XT2 oscillator 0 XT2 is on 1 XT2 is off if it is not used for MCLK or SMCLK. RSELx Bits 2-0 Resistor Select. The internal resistor is selected in eight different steps. The value of the resistor defines the nominal frequency. The lowest nominal frequency is selected by setting RSELx=0. 3、BCSCTL0 SELMx Bits 7-6 Select MCLK. These bits select the MCLK source. 00 DCOCLK 01 DCOCLK 10 XT2CLK when XT2 oscillator present on-chip. LFXT1CLK when XT2 oscillator not present on-chip. 11 LFXT1CLK SELS Bit 3 Select SMCLK. This bit selects the SMCLK source. 0 DCOCLK 1 XT2CLK when XT2 oscillator present on-chip. LFXT1CLK when XT2 oscillator not present on-chip. DCOR Bit 0 DCO resistor select 0 Internal resistor 1 External resistor 4、实例 4.1 配置MCLK/SMCLK 见本节2.1。 4.2配置DCO void main(void) { WDTCTL = WDTPW +WDTHOLD; // Stop Watchdog Timer DCOCTL = DCO0 + DCO1 + DCO2; // Max DCO BCSCTL1 = RSEL0 + RSEL1 + RSEL2; // XT2on, max RSEL BCSCTL2 |= SELS; // SMCLK = XT2 P5DIR |= 0x70; // P5.6,5,4 outputs P5SEL |= 0x70; // P5.6,5,5 options while(1) { } } 实测DCO最低128K,最高4.58M。
