2312|1
LAUNCHPADmsp430进入低功耗模式cpu停止,为什么灯还在闪 [复制链接]
/****CPU运行在VLO时钟下****/
#include "msp430g2553.h"
int main( void )
  WDTCTL = WDTPW + WDTHOLD;//关闭看门狗
  P1DIR = BIT6;//P1.6配置输出
  P1OUT = 0;//关闭LED
  BCSCTL3 |= LFXT1S_2;//LFXT1=VLO
  IFG1 &= (~OFIFG);//清除OSCFault标志
  __bis_SR_register(SCG1+SCG0);//关闭DCO 将SR里面的SCG1+SCG0置位
  BCSCTL2 |= SELM_3+DIVM_3;
  while(1)
    P1OUT = BIT6;
    __delay_cycles(100);
    P1OUT = 0;
    __delay_cycles(5000);
本帖最后由 LeoMe 于 2015-9-16 08:44 编辑 为什么不直接用头文件里的 LPM3;指令。。。/* Low Power Modes coded with Bits 4-7 in SR */ #ifndef __IAR_SYSTEMS_ICC__ /* Begin #defines for assembler */ #define LPM0                (CPUOFF) #define LPM1                (SCG0+CPUOFF) #define LPM2                (SCG1+CPUOFF) #define LPM3                (SCG1+SCG0+CPUOFF) #define LPM4                (SCG1+SCG0+OSCOFF+CPUOFF) /* End #defines for assembler */ #else /* Begin #defines for C */ #define LPM0_bits           (CPUOFF) #define LPM1_bits           (SCG0+CPUOFF) #define LPM2_bits           (SCG1+CPUOFF) #define LPM3_bits           (SCG1+SCG0+CPUOFF) #define LPM4_bits           (SCG1+SCG0+OSCOFF+CPUOFF) #include "in430.h" #define LPM0      __bis_SR_register(LPM0_bits)         /* Enter Low Power Mode 0 */ #define LPM0_EXIT __bic_SR_register_on_exit(LPM0_bits) /* Exit Low Power Mode 0 */ #define LPM1      __bis_SR_register(LPM1_bits)         /* Enter Low Power Mode 1 */ #define LPM1_EXIT __bic_SR_register_on_exit(LPM1_bits) /* Exit Low Power Mode 1 */ #define LPM2      __bis_SR_register(LPM2_bits)         /* Enter Low Power Mode 2 */ #define LPM2_EXIT __bic_SR_register_on_exit(LPM2_bits) /* Exit Low Power Mode 2 */ #define LPM3      __bis_SR_register(LPM3_bits)         /* Enter Low Power Mode 3 */ #define LPM3_EXIT __bic_SR_register_on_exit(LPM3_bits) /* Exit Low Power Mode 3 */ #define LPM4      __bis_SR_register(LPM4_bits)         /* Enter Low Power Mode 4 */ #define LPM4_EXIT __bic_SR_register_on_exit(LPM4_bits) /* Exit Low Power Mode 4 */ #endif /* End #defines for C */ 这是头文件里的相关定义 在IAR的msp430g2553.h里 看样子你好像少了CPUOFF   详情 回复 发表于 2015-9-16 08:41
379
#include "in430.h"
这是头文件里的相关定义
在IAR的msp430g2553.h里
看样子你好像少了CPUOFF
