2896|0
[C5000 & C6000] TI C6748 BIOSPSP 例子程序uart 命令行下编译出错 [复制链接]
TI C6748 BIOSPSP 例子程序uart(从BIOS C6SDK 2. 0安装而来)命令行下编译出错 error: can't c
reate session manager can't find a JVM;
按提示设置了系统环境变量XDCTOOLS_JAVA_HOME为C:\Program Files\Java\jre6 依然有错误,编译输出结果如下
这该咋整呢???
D:\Program Files\Texas Instruments\pdk_C6748_2_0_0_0\biospsp_03_00_01_00>D:\ti\x
dctools_3_30_03_47_core\gmake uart_evm6748_sample
# Configuring XDC packages for evm6748_uart_sample:c6xdsp:debug
D:/ti/xdctools_3_30_03_47_core/gmake -C D:/PROGRA~1/TEXASI~1/pdk_C6748_2_0_0_0/b
iospsp_03_00_01_00/drivers\examples\evm6748\uart xdc_configuro PLATFORM=c6748-ev
m CORE=c6xdsp PROFILE_c6xdsp=debug
gmake[1]: Entering directory `D:/PROGRA~1/TEXASI~1/pdk_C6748_2_0_0_0/biospsp_03_
00_01_00/drivers/examples/evm6748/uart'
# Invoking configuro...
a+x maketemp_configuro_cmd_c6xdsp.bat
D:\PROGRA~1\TEXASI~1\pdk_C6748_2_0_0_0\biospsp_03_00_01_00\drivers\examples\evm6
748\uart>D:/ti/xdctools_3_30_03_47_core/xs xdc.tools.configuro --generationOnly
-o obj/c6748-evm/c6xdsp/debug/evm6748_uart_sample_configuro -t ti.targets.elf.C6
74 -p ti.platforms.evm6748 -r whole_program -c D:/ti/c6000_7.4.8 -b D:/PROGRA~1/
TEXASI~1/pdk_C6748_2_0_0_0/biospsp_03_00_01_00/config.bld uartsample.cfg
D:\ti\xdctools_3_30_03_47_core\D:/ti/xdctools_3_30_03_47_core/xs: error: can't c
reate session manager: can't find a JVM; try setting the environment variable 'X
DCTOOLS_JAVA_HOME' to the absolute path of any directory containing a 32-bit Jav
a Runtime Environment (1.6 or greater); e.g., 'C:\Program Files (x86)\Java\jre7'
gmake[1]: *** [xdc_configuro] Error 1
gmake[1]: Leaving directory `D:/PROGRA~1/TEXASI~1/pdk_C6748_2_0_0_0/biospsp_03_0
gmake: *** [evm6748_uart_sample] Error 2
