2798|1
无刷云台研究记录——遥控:PWM脉冲宽度测量 [复制链接]
在了解遥控数据交换协议之前,首先对常用的协议有所了解,推荐一篇科普文章:
http://www.docin.com/p-680140417.html
若该链接无效可以搜索关键字“APM PX4飞控开发笔记-第五章:PWM、PPM与S.bus”
之后选择自己需要的协议进行设计,我用的是PWM,所以需要通过定时器对脉冲宽度进行读取。具体代码如下,这并不是我写的,但经测试,可以使用。
  1. // Hold onto the Channel 1 init structure -- we will use it to reverse
  2. // polarity on every edge interrupt.
  3. static TIM_ICInitTypeDef TIM_CH1_ICInitStructure;
  4.
  5. #define GPIO_AF_TIM2 GPIO_AF_2
  6.
  7. void ConfigPwmIn() {
  8. GPIO_InitTypeDef GPIO_InitStructure;
  9. TIM_ICInitTypeDef TIM_ICInitStructure;
  10. NVIC_InitTypeDef NVIC_InitStructure;
  11.
  12. TIM_DeInit(TIM2 );
  13.
  14. /* TIM2 clock enable */
  15. RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  16.
  17. /* GPIOC clock enable */
  18. RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOD, ENABLE);
  19.
  20. /* TIM2 GPIO pin configuration : CH1=PD3, C2=PD4, CH3=PD7, CH4=PD6 */
  21. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_7 | GPIO_Pin_6;
  22. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  23. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  24. GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  25. GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  26. GPIO_Init(GPIOD, &GPIO_InitStructure);
  27.
  28. /* Connect pins to TIM3 AF2 */
  29. GPIO_PinAFConfig(GPIOD, GPIO_PinSource3, GPIO_AF_TIM2 );
  30. GPIO_PinAFConfig(GPIOD, GPIO_PinSource4, GPIO_AF_TIM2 );
  31. GPIO_PinAFConfig(GPIOD, GPIO_PinSource7, GPIO_AF_TIM2 );
  32. GPIO_PinAFConfig(GPIOD, GPIO_PinSource6, GPIO_AF_TIM2 );
  33.
  34. NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  35. NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  36. NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  37. NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  38. NVIC_Init(&NVIC_InitStructure);
  39.
  40. /* Enable capture*/
  41. TIM_CH1_ICInitStructure.TIM_Channel = TIM_Channel_1;
  42. TIM_CH1_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  43. TIM_CH1_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  44. TIM_CH1_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  45. TIM_CH1_ICInitStructure.TIM_ICFilter = 0;
  46. TIM_ICInit(TIM2, &TIM_ICInitStructure);
  47. TIM_ICInitStructure.TIM_Channel = TIM_Channel_2;
  48. TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
  49. TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  50. TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  51. TIM_ICInitStructure.TIM_ICFilter = 0;
  52. TIM_ICInit(TIM2, &TIM_ICInitStructure);
  53. TIM_ICInitStructure.TIM_Channel = TIM_Channel_3;
  54. TIM_ICInit(TIM2, &TIM_ICInitStructure);
  55. TIM_ICInitStructure.TIM_Channel = TIM_Channel_4;
  56. TIM_ICInit(TIM2, &TIM_ICInitStructure);
  57.
  58. /* Enable TIM2 */
  59. TIM_Cmd(TIM2, ENABLE);
  60.
  61. /* Enable CC1-4 interrupt */
  62. TIM_ITConfig(TIM2, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 | TIM_IT_CC4, ENABLE);
  63.
  64. /* Clear CC1 Flag*/
  65. TIM_ClearFlag(TIM2, TIM_FLAG_CC1 | TIM_FLAG_CC2 | TIM_FLAG_CC3 | TIM_FLAG_CC4 );
  66. }
  67.
  68. static volatile uint32_t ccr[4];
  69. static volatile char pulseState = 0;
  70.
  71. void TIM2_IRQHandler() {
  72. if (TIM2 ->SR & TIM_IT_CC1 ) {
  73.   TIM2 ->SR &= (~TIM_IT_CC1 );
  74.
  75.   if (pulseState == 0) {
  76.    TIM_CH1_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling;
  77.
  78.    // Any time we get a rising edge on CH1, we reset the counter. All channels are
  79.    // phase aligned, so they all use this as a reference.
  80.    TIM_SetCounter(TIM2, 0);
  81.   } else {
  82.    TIM_CH1_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  83.
  84.    // Pull the value on the falling edge.
  85.    ccr[0] = TIM_GetCapture1(TIM2 );
  86.   }
  87.   pulseState = !pulseState;
  88.
  89.   // Reverse polarity.
  90.   TIM_ICInit(TIM2, &TIM_CH1_ICInitStructure);
  91. }
  92.
  93. if (TIM2 ->SR & TIM_IT_CC2 ) {
  94.   TIM2 ->SR &= (~TIM_IT_CC2 );
  95.   ccr[1] = TIM_GetCapture2(TIM2 );
  96. }
  97. if (TIM2 ->SR & TIM_IT_CC3 ) {
  98.   TIM2 ->SR &= (~TIM_IT_CC3 );
  99.   ccr[2] = TIM_GetCapture3(TIM2 );
  100. }
  101. if (TIM2 ->SR & TIM_IT_CC4 ) {
  102.   TIM2 ->SR &= (~TIM_IT_CC4 );
  103.   ccr[3] = TIM_GetCapture4(TIM2 );
  104. }
  105. }
复制代码
以上代码来自《stm32 pwm捕获学习笔记》,该Blog中列出了几种测量方式,可以根据需要选择合适的加以运用。
获取了PWM脉冲宽度,就可以归一化处理后加入控制。
此帖出自stm32/stm8论坛
不错  看看 :)   详情 回复 发表于 2015-8-28 10:16
565
513
裸片初长成(中级)
不错  看看 :)
此帖出自stm32/stm8论坛
