[ 0.000000]Booting Linux on physical CPU 0xf00
[ 0.000000]Initializing cgroup subsys cpuset
[ 0.000000]Initializing cgroup subsys cpuacct
[ 0.000000]Linux version 4.0.9-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303(prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #807SMP PREEMPT Fri Jul 24 15:21:02 BST 2015
[ 0.000000] CPU:ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing datacache, VIPT aliasing instruction cache
[ 0.000000]Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma:Reserved 8 MiB at 0x3a800000
[ 0.000000]Memory policy: Data cache writealloc
[ 0.000000] Onnode 0 totalpages: 241664
[ 0.000000]free_area_init_node: node 0, pgdat 808424c0, node_mem_map b9fa6000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000][bcm2709_smp_init_cpus] enter (8660->f3003010)
[ 0.000000][bcm2709_smp_init_cpus] ncores=4
[ 0.000000]PERCPU: Embedded 11 pages/cpu @b9f6d000 s16128 r8192 d20736 u45056
[ 0.000000]pcpu-alloc: s16128 r8192 d20736 u45056 alloc=11*4096
[ 0.000000]pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000]Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000]Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1792 bcm2708_fb.fbheight=952bcm2709.boardrev=0xa01041 bcm2709.serial=0x61e53599smsc95xx.macaddr=B8:27:EB:E5:35:99 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200console=tty1 root=/dev/mmcblk0p6 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PIDhash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000]Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000]Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000]Memory: 939656K/966656K available (5885K kernel code, 378K rwdata, 1788Krodata, 404K init, 757K bss, 18808K reserved, 8192K cma-reserved)
[ 0.000000]Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072kB)
[ 0.000000] vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
[ 0.000000] lowmem : 0x80000000 - 0xbb000000 ( 944MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16MB)
[ 0.000000] .text : 0x80008000 - 0x80786860 (7675 kB)
[ 0.000000] .init : 0x80787000 - 0x807ec000 ( 404 kB)
[ 0.000000] .data : 0x807ec000 - 0x8084aa64 ( 379 kB)
[ 0.000000] .bss : 0x8084aa64 - 0x809081cc ( 758 kB)
[ 0.000000]SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000]Preemptible hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed withstalls.
[ 0.000000]NR_IRQS:608
[ 0.000000]Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000014]sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000037]Switching to timer-based delay loop, resolution 52ns
[ 0.000323]Console: colour dummy device 80x30
[ 0.002072]console [tty1] enabled
[ 0.002135]Calibrating delay loop (skipped), value calculated using timer frequency..38.40 BogoMIPS (lpj=192000)
[ 0.002236]pid_max: default: 32768 minimum: 301
[ 0.002610]Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002679]Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.004009]Initializing cgroup subsys blkio
[ 0.004088]Initializing cgroup subsys memory
[ 0.004155]Initializing cgroup subsys devices
[ 0.004215]Initializing cgroup subsys freezer
[ 0.004291]Initializing cgroup subsys net_cls
[ 0.004406] CPU:Testing write buffer coherency: ok
[ 0.004530]ftrace: allocating 20020 entries in 59 pages
[ 0.053400]CPU0: update cpu_capacity 1024
[ 0.053481]CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.053529][bcm2709_smp_prepare_cpus] enter
[ 0.053685]Setting up static identity map for 0x54f130 - 0x54f164
[ 0.113300][bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.113612][bcm2709_secondary_init] enter cpu:1
[ 0.113665]CPU1: update cpu_capacity 1024
[ 0.113674]CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.133279][bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.133532][bcm2709_secondary_init] enter cpu:2
[ 0.133562]CPU2: update cpu_capacity 1024
[ 0.133570]CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.153323] [bcm2709_boot_secondary]cpu:3 started (0) 18
[ 0.153568][bcm2709_secondary_init] enter cpu:3
[ 0.153596]CPU3: update cpu_capacity 1024
[ 0.153604]CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.153694]Brought up 4 CPUs
[ 0.153829] SMP:Total of 4 processors activated (153.60 BogoMIPS).
[ 0.153871] CPU:All CPU(s) started in SVC mode.
[ 0.154912]devtmpfs: initialized
[ 0.174634] VFPsupport v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.175880]pinctrl core: initialized pinctrl subsystem
[ 0.180646] NET:Registered protocol family 16
[ 0.186444] DMA:preallocated 4096 KiB pool for atomic coherent allocations
[ 0.187676]bcm2709.uart_clock = 3000000
[ 0.192577]hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.192648]hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.192821]Serial: AMBA PL011 UART driver
[ 0.193040]3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011rev2
[ 0.673056] console [ttyAMA0] enabled
[ 0.677512]bcm2708_vcio 3f00b880.mailbox: mailbox at f300b880
[ 0.755654]bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000,dmachans=0x7f35
[ 0.765006]bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.771912]bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.777297]bcm_power: Broadcom power driver
[ 0.781592]bcm_power_open() -> 0
[ 0.784924]bcm_power_request(0, 8)
[ 0.814110]bcm_mailbox_read -> 00000080, 0
[ 0.818317]bcm_power_request -> 0
[ 0.822390] SCSIsubsystem initialized
[ 0.826429]usbcore: registered new interface driver usbfs
[ 0.832034]usbcore: registered new interface driver hub
[ 0.837532]usbcore: registered new device driver usb
[ 0.844556]Switched to clocksource arch_sys_counter
[ 0.879446]FS-Cache: Loaded
[ 0.882712]CacheFiles: Loaded
[ 0.897388] NET:Registered protocol family 2
[ 0.903070] TCPestablished hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.910336] TCP bind hash table entries: 8192(order: 4, 65536 bytes)
[ 0.917046] TCP:Hash tables configured (established 8192 bind 8192)
[ 0.923528] TCP:reno registered
[ 0.926817] UDPhash table entries: 512 (order: 2, 16384 bytes)
[ 0.932812]UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.939668] NET:Registered protocol family 1
[ 0.944482] RPC:Registered named UNIX socket transport module.
[ 0.950501] RPC:Registered udp transport module.
[ 0.955253] RPC:Registered tcp transport module.
[ 0.959977] RPC:Registered tcp NFSv4.1 backchannel transport module.
[ 0.967553] hwperfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.977216]futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.998953] VFS:Disk quotas dquot_6.5.2
[ 1.003268] VFS:Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.013093]FS-Cache: Netfs 'nfs' registered for caching
[ 1.019639] NFS:Registering the id_resolver key type
[ 1.024819] Key type id_resolver registered
[ 1.029026] Keytype id_legacy registered
[ 1.035784]Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.043422] ioscheduler noop registered
[ 1.047457] ioscheduler deadline registered (default)
[ 1.052937] ioscheduler cfq registered
[ 1.059369]BCM2708FB: allocated DMA memory fac00000
[ 1.064395]BCM2708FB: allocated DMA channel 0 @ f3007000 [ 1.097859]Console: switching to colour frame buffer device 224x59
[ 1.121411]Serial: 8250/16550 driver, 0 ports, IRQ sharing disabled
[ 1.128210]uart-pl011 3f201000.uart: no DMA platform data
[ 1.134902]vc-cma: Videocore CMA driver
[ 1.138913]vc-cma: vc_cma_base = 0x00000000
[ 1.143704]vc-cma: vc_cma_size = 0x00000000 (0MiB)
[ 1.149230]vc-cma: vc_cma_initial = 0x00000000 (0MiB)
[ 1.154990]vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.179010] brd:module loaded
[ 1.191662]loop: module loaded
[ 1.195980] vchiq: vchiq_init_state: slot_zero= 0xbac80000, is_master = 0
[ 1.203976]Loading iSCSI transport class v2.0-870.
[ 1.210007]usbcore: registered new interface driver smsc95xx
[ 1.215976]dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.422170] CoreRelease: 2.80a
[ 1.425439]Setting default values for core params
[ 1.430362]Finished setting default values for core params
[ 1.636445]Using Buffer DMA mode
[ 1.639832]Periodic Transfer Interrupt Enhancement - disabled
[ 1.645792]Multiprocessor Interrupt Enhancement - disabled
[ 1.651468] OTGVER PARAM: 0, OTG VER FLAG: 0
[ 1.655933]Dedicated Tx FIFOs mode
[ 1.659864]WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xbac14000 dma =0xfac14000 len=9024
[ 1.669929] FIQFSM acceleration enabled for :
[ 1.669929]Non-periodic Split Transactions
[ 1.669929]Periodic Split Transactions
[ 1.669929]High-Speed Isochronous Endpoints
[ 1.700744]dwc_otg: Microframe scheduler enabled
[ 1.700818]WARN::hcd_init_fiq:412: FIQ on core 1 at 0x803f3da8
[ 1.711396]WARN::hcd_init_fiq:413: FIQ ASM at 0x803f4104 length 36
[ 1.722292]WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89a000
[ 1.732960]dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.742570]dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.754570]dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 1.764780]Init: Port Power? op_state=1
[ 1.773253]Init: Power Port (0)
[ 1.781310] usbusb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.792790] usbusb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.804698] usbusb1: Product: DWC OTG Controller
[ 1.814016] usbusb1: Manufacturer: Linux 4.0.9-v7+ dwc_otg_hcd
[ 1.824578] usbusb1: SerialNumber: 3f980000.usb
[ 1.834660] hub1-0:1.0: USB hub found
[ 1.842984] hub1-0:1.0: 1 port detected
[ 1.851856]dwc_otg: FIQ enabled
[ 1.851870]dwc_otg: NAK holdoff enabled
[ 1.851882]dwc_otg: FIQ split-transaction FSM enabled
[ 1.851925]Module dwc_common_port init
[ 1.852331]usbcore: registered new interface driver usb-storage
[ 1.863137]mousedev: PS/2 mouse device common for all mice
[ 1.874214]bcm2835-cpufreq: min=600000 max=900000
[ 1.883890]Driver 'mmcblk' needs updating - please use bus_type methods
[ 1.895246]sdhci: Secure Digital Host Controller Interface driver
[ 1.905971]sdhci: Copyright(c) Pierre Ossman
[ 1.915279]mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 1.925658]mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 1.974922]sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.990201]ledtrig-cpu: registered to indicate activity on CPUs
[ 2.001087]hidraw: raw HID events driver (C) Jiri Kosina
[ 2.011436]usbcore: registered new interface driver usbhid
[ 2.021695]usbhid: USB HID core driver
[ 2.031561] TCP:cubic registered
[ 2.039475]Initializing XFRM netlink socket
[ 2.044714]Indeed it is in host mode hprt0 = 00021501
[ 2.059109] NET:Registered protocol family 17
[ 2.070464] Keytype dns_resolver registered
[ 2.079961]Registering SWP/SWPB emulation handler
[ 2.090399]registered taskstats version 1
[ 2.099258]vc-sm: Videocore shared memory driver
[ 2.108610] [vc_sm_connected_init]:start
[ 2.118129][vc_sm_connected_init]: end - returning 0
[ 2.129882]Waiting for root device /dev/mmcblk0p6...
[ 2.143395]mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.158275]mmc0: new high speed SDHC card at address 0007
[ 2.168912]mmcblk0: mmc0:0007 SD32G 29.3 GiB
[ 2.181474] mmcblk0: p1 p2 < p5 p6 > p3
[ 2.224708] usb1-1: new high-speed USB device number 2 using dwc_otg
[ 2.235916]Indeed it is in host mode hprt0 = 00001101
[ 2.248430]EXT4-fs (mmcblk0p6): INFO: recovery required on readonly filesystem
[ 2.260335]EXT4-fs (mmcblk0p6): write access will be enabled during recovery
[ 2.444988] usb1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.456389] usb1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.468995] hub1-1:1.0: USB hub found
[ 2.477378] hub1-1:1.0: 5 ports detected
[ 2.764824] usb1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.875116] usb 1-1.1:New USB device found, idVendor=0424, idProduct=ec00
[ 2.886698] usb1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.901658]smsc95xx v1.0.4
[ 2.968966]smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xxUSB 2.0 Ethernet, b8:27:eb:e5:35:99
[ 3.064835] usb1-1.5: new high-speed USB device number 4 using dwc_otg
[ 3.175409] usb1-1.5: New USB device found, idVendor=0bda, idProduct=8179
[ 3.187158] usb1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.199247] usb1-1.5: Product: 802.11n NIC
[ 3.208169] usb1-1.5: Manufacturer: Realtek
[ 3.217177] usb1-1.5: SerialNumber: 00E04C0001
[ 10.105843]EXT4-fs (mmcblk0p6): orphan cleanup on readonly fs
[ 10.117035] EXT4-fs(mmcblk0p6): 1 orphan inode deleted
[ 10.126972]EXT4-fs (mmcblk0p6): recovery complete
[ 11.296722]EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 11.309629] VFS:Mounted root (ext4 filesystem) readonly on device 179:6.
[ 11.330033]devtmpfs: mounted
[ 11.338462]Freeing unused kernel memory: 404K (80787000 - 807ec000)
[ 12.451010]udevd[178]: starting version 175
[ 12.580815]random: nonblocking pool is initialized
[ 12.900005]spi-bcm2835 3f204000.spi: no tx-dma configuration found - not using dma mode
[ 12.986757] spispi0.0: setting up native-CS0 as GPIO 8
[ 13.058296] spispi0.1: setting up native-CS1 as GPIO 7
[ 13.095077]bcm2708_i2c 3f804000.i2c: BSC1 Controller at 0x3f804000 (irq 79) (baudrate100000)
[ 13.219869]r8188eu: module is from the staging directory, the quality is unknown, you havebeen warned.
[ 13.255931] ChipVersion Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 13.319132]usbcore: registered new interface driver r8188eu
[ 15.106397]EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 15.413336]EXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
[ 20.395365] MACAddress = c8:e7:d8:e7:c7:7b
[ 20.480181]smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 21.827602]R8188EU: ERROR assoc success
[ 22.563921]cfg80211: Calling CRDA to update world regulatory domain
[ 24.059470]Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
